Question about Maytag Washing Machines
Can't get the agitator off washer
Model WWA5552VAS........ I think. I'm looking at it via mirror.
I need to retrieve something under the agitotor. How can I get if off please.
    Genius:
  • 1,224 Answers
On top cap this should be held in by screw or nut or clipped in this should look like this
Posted on Jun 10, 2008
  • Christophe Thompson
    Christophe Thompson Jun 10, 2008
    once unbolted pull agitator up
Sm8280871 washer. How do you take agitator out?
Are you sure this is a model number? It looks more like a Serial number. Model should be on a tag with serial number. Usually starts with letters then about 4 numbers and more letters. Providing that would likely get you better assistance.
Feb 17, 2015 | Roper Washing Machines
Frigidaire Top Load Washer Won't Agitate FWS645GFS1
i guess you may be right
or maybe the motor
is not rotating with the ussuall speed pls inspect it..............
and ask for a technician .......
Sep 15, 2008 | Frigidaire CWS3600AS Top Load Washer
The bolt has come free from the shaft and is inside the agitator. I have the agitator off and the cap to it off. It is solid under the cap. how do I seperate the two halves of the agitator to retrieve the...
You will need to hook something in the hole the bolt was in and pull real hard. the agitator coupler is still in the agitatorif you notice there are plastic fingers around the coupler and you can pry those back a little to aid in your getting the coupler out.
Jan 22, 2011 | GE WCCB1030 Top Load Washer
Hi, how do i get change out from under the agitator? Is there a way to get it out? Is there something down there that collects all the stuff that falls in there? Please and thank you.
You have to pull the agitator. It is a pressed fitting, meaning that you will need to carefully pry on the bottom while pulling up on the agitator. It will pop off, then you can retrieve your items. There is not a collection can or anything like that. Please rate
Jun 04, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer was filling but not aggitating,
remove the dispenser in the top of agit . under it is a bolt. remove bolt. it holds it down . if it won't pull by hand then we use a ( agi tamer. this is a split inner tube type/very flat with a split in it . slide under agit and add water and up it comes . 5 min. .. i don't think something is under the agit I belive the trans is failing . but you need to look . . agit needs to be removed to repl trans anyway ..mm
Dec 12, 2009 | Maytag PAV2300 Top Load Washer
We have a Kenmore washer/dryer stacked unit, model 417.94802301, that we need to replace the agitator on. Can someone tell me how to remove the agitator? Underneath the dispenser, it just a solid piece...
GO TO SEARSPARTSDIRECT.COM FOR A BREAKDOWN. yOU SHOULD BE ABLE TO GRAB THE TAB ON THE "WHITE THING" AND PULL IT STRAIGHT UP. tHE SCREW IS HIDDEN UNDER IT.
Nov 20, 2009 | Kenmore Washing Machines
Washer won't agitate
First, see the Sears parts site for washer model # 110.22952100 which I believe is your model.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.22952100+
Look at the section containing the agitator and you should see how the parts fit.
Also see the following for an illustrated description of replacing the "dogs"
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136&osCsid=71493d5cab3d7784ad8aa7cde8e5e5d4
Nov 17, 2009 | Kenmore Washing Machines
I think something is stuck under the washer basin I don't know how to remove agitator
on the old type you turn the centre top to unscrew it. pull up the agitator and replace the same way
May 09, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
AGITOTOR COGS ARE SHOT NEED TO PEPLACE " HOW!"
you can find avideo on you tube, search whirpool washer repair, but youll need to remove the agitaptr. 7/16 screw down the center shaft of agitator, then remove the agitator and split into 2 parts to reveal the agitaotr dogs they simoly slip back into place, part number 80040 in case you havent ordered them yet
Feb 27, 2009 | Whirlpool Washing Machines
Shoestrings wrapped under agitator
You will have to remove the agitator. Remove the softener dispenser from the top of the agitator and when you look down the agitator, you will see a 10mm stainless steel bolt. You will need to remove this bolt to remove the agitator. If there is no bolt, try pulling the agitator up and out.
Nov 03, 2007 | GE WPRB9220D Top Load Washer
Washing Machines Logo
24 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
