Question about Palm Treo 755p Smartphone
Selected com port not available
Today when trying to Hotsync, the connection between the handheld and the desktop could not be established. I'm getting a message in Setup saying the selected com1 port is unavailable. An hour later it worked, but now it's not connecting again and the com port error message comes up. So it may be intermittent. THis has not happened before, at least not for any length of time because I've always been able to sync over the last couple years and with my Dell XP purchased in January. Any ideas ??
  • tpontrello Jun 20, 2008
    All of a sudden my palm won't sync to outlook. When I push the sync button on the phone it goes to the menu on the phone but nothing happens on the computer. The last succesful sync was on June 17th.
  • mucho Jul 30, 2008
    Trying to Hutsync my phone I get Port, com1 not Avaailable the Hotsynch Manager will continue once com1 becomes available
We are having the same problem hotsyncing treo 755p with vista home premium for months. No help from Palm or Sprint. Have uninstalled and reinstalled desktop Access 6.2.2 repeatedly without success. Handheld will still hotsync with older XP computer. Hellllp
Posted on Aug 05, 2008
  • 53 Answers
Please un-install and re-install the software,, that should fix the problem,
Posted on Jun 09, 2008
Unable to connect hotsync with desktop
Palm 515 Hotsync unable to connect to Desktop - Expansys ... > Forums > Palm > Palm m515
Jun 29, 2004 - 6 posts - ‎5 authors
I get the messsage "The connection between your handheld computer and thedesktop could not be established. Please check your setup and ...
Setting Up Palm OS Hot syncing with Windows 7 or Vista 64bit
Download Palm Desktop 6.2; Install Aceeca 64 Bit driver; Install ... Product Support; If you have Windows 7, 8 or 10 32-bit you should be able to Hotsync now.
unable to connect to computer to hotsync via network or cable > ... > Device Manufacturers > Palm > Palm TX
Jul 30, 2008 - 10 posts - ‎6 authors
i haven't been able to hotsync since i sent my laptop in for 'repair' a while ago. ... Make sure you do NOT connect the TX to the computer (even ... Cannot hotsync Palm lllxe with USB to Serial Adaptor ...
Jan 24, 2011
Hotsync problem - unable to establish desktop ...
1 post
Oct 19, 2004
Unable to Hotsync - Identifying user? ' ...
Mar 16, 2004
Unable to Hotsync Palm IIIxe with a USB connection ...
Dec 18, 2002
More results from
Jan 03, 2016 | Palm Tungsten Tx Handheld Pda 312mhz 128mb...
Garmin hotsync issue
Hey uninstall the program, download the newest one available and try again.
Sep 08, 2008 | Garmin iQue 3600 GPS Receiver
Can't sync my palm z22 to my computer
I had this problem recently and once I checked all of my settings, and adjusted a couple, it worked fine. To do that, on the desktop computer, open Palm Desktop and go to HotSync and then, under that is Setup. When the set up window opens, click on connections and be sure the type of connection you use is selected. In my case, I use the USB cable. Close that window. On the handheld, click on the hotsync image and be sure the connection method matches what you set up. Local or modem are your choices. My selection is local. Go to Preferences on the handheld and select Communication. Select connection and a window opens.From that list, I selected cradle/cable. Hopefully that will work for you. Try doing a hotsync at that point, and see if the problem is fixed. Mine was.
Jun 24, 2010 | Palm Z22 Handheld
I am unable to HotSync and cannot load HotSync manager
Reinstall Hotsync manager and make sure selected port is correct. Use alternate method to sync like Infrared
May 29, 2009 | Sony CLIE PEG-TJ37 Handheld
I reinstaled the Palm Desktop again it worked....
Sep 20, 2008 | Sony CLIE PEG-TJ37 Handheld
Can not find an available Com port for Hotsync
Right click on the Hotsync icon in the taskbar (usually at the bottom-right hand corner of the screen) and select "USB" sync, while unchecking "Serial" or "Com" options. Then, initiate the hotsync from your palm handheld, rather than computer. Hopefully this will help!
Oct 07, 2007 | Palm Tungsten E Handheld
Hotsync problem
With a USB 1.1 machine .. try this ...My work around - disconnect ALL USB devices from the computer, NO multiport hubs, make a direct USB connection to one of the available open ports, then reboot the computer. Upon gaining control, then try to hotsync. If I had any other items connected or ran any other programs prior to hotsync, I was not able to perform a successful hotsync. The qwerks of the T5 and the sync conduits. Hope this helps Bob
Aug 09, 2007 | Palm TX Handheld
Ibm workpad sync & port issues help!
You have your Hotsync software set to use a com port instead of USB. Right Click on the Hotsync icon on the lower right part of your PC desktop and change it to USB and you should be good to go. The IBM Workpad is just like a Palm. I have the Workpad C500 which is actually a Palm M500. If you have a Workpad C505 it is a Palm M505. Anything you can buy for a Palm M500 will work with a C500 and anything you get for a M505 will work with a C505. If you do NOT have a USB Sync cable for your Workpad I suggest you do what I did... Just get a combination Sync and charge USB cable at Staples or Best Buy for your M500 or M505 and use it. It was about 20 but you can get them cheaper on the Net. I hope this helps you!
Sep 14, 2005 | IBM WorkPad z50
Vx to Outlook 2002 failed - no connection Established
hi, on ur palm tap on home , u would see hotsync icon tap on that , on the hotsync page , u would see ur name on top or just welcome , make sure u see direct serial on the same page , tap on the top left corner where it says hotsync in words , in the drop down , tap on lan sync prefs , make sure local hotsync is darker in shade. on the pc make sure u see the hotsync manager at the bottom right corner , if not , click on start , click on all programs , choose palm desktop , inside that u would see hotsync manager , left double click on that , if it doesnt appear at the bottom right corner , try 4times , then if it still persists , restart the pc and try again. Once u see the hotsync manager at the bottom right corner , right click on that , left click on setup , left click on local , choose a different com port , reduce the speed to 9600 , click on ok restart ur pc and try hotsyncin , if it doesnt work try the previous step again and do not forget to restart ur pc , and then perform a hs , it will work .... Regards
Sep 11, 2005 | Palm Vx Handheld
Palm Treo 755p Smartphone Logo
267 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
