Question about Garmin GPSMAP 172 GPS Receiver
Garmin 178c map system. sonar stopped working. Chart plotter says sonar turned off. Sonar unit is getting power and blinking red.
5 Suggested Answers
SOURCE: Sonar Problem
Try a soft reset first, if that doesn't correct it try a hard reset. BE SURE and Save Data before th eHard Reset, it clears all waypoints and such.
Soft Reset Hard Reset
LCX 15mt Reset 1. Turn unit OFF 1. Turn unit OFF 2. Press and hold the PAGES key 2. Press and hold the ZIN&ZOUT Keys at the same time 3. Press and hold the PWR key 3. Press and hold the PWR key 4. Release both buttons when the USA map appears 4. Release both buttons when the USA map appears
Posted on Aug 29, 2008
  • 1584 Answers
SOURCE: garmin 178c turns off on it's own.
Hi
Sounds very much like the wiring plug connections in the back, always overlooked but so important that connections are tight and contacting.
Posted on Aug 13, 2009
MarineTech1
  • 76 Answers
SOURCE: I have a garmin gpsmap 440s that will only read
Sounds like the transducer is installed at the wrong angle or in such a way that it is getting a lot of air from something on the hull. If it is a transom mount, check that it is angled correctly and not too close to the motor or aft of some kind of thru-hull fitting that will cause turbulence.
Posted on Aug 22, 2009
pabloloco
  • 2335 Answers
SOURCE: GPS operation freeze up
Upgrading the system software of your GPSMAP 545s will most likely fix your freezing up problem.
I hope that helps.
Posted on Jan 31, 2010
Ironfist109
  • 3018 Answers
SOURCE: I have a Garmin 182c
If you nicked it good enough yes it can. If the receiver doesn't detect the transducer, a digital message on the display will indicate this.
Posted on Mar 18, 2011
Can you change a GPS navigation system from street name to postcode
I am not sure what you mean by " post code" but a gps uses maps that are stored on the unit itself. In order to make a change on how it shows locations, it would mean that the maps would have to be edited. Any change like you are suggesting would involve a lot of work with computer programming. Since it is not a standard method of locating, it would not be marketed.
Jan 06, 2017 | GPS
I can't adjust bluetooth,there is no "bluetooth" icon.
The Nuvi 755T does not have bluetooth capability. See this link to see the specifications of the 755T from the Garmin website:
https://buy.garmin.com/en-US/US/prod14933.html
Bluetooth wireless technology No
You would have to have a Nuvi 765T to have bluetooth
https://buy.garmin.com/en-US/US/prod14926.html
Bluetooth wireless technology Yes (with A2DP technology)
Aug 13, 2013 | Garmin nuvi 755T Car GPS Receiver
Screen comes up with updating bluetooth firmware & stays at 45%.
Your unit if locatiing a cell phone close by, could be yours or a friends in the car, on standing near you.
I would disable Bluetooth first, to do that go to Tools...Settings.... Bluetooth.... under Bluetooth disable then re-do your Bluetooth connection
Tools....Settings... Bluetooth .. under Connection you can remove the connection there also
If you don't have a Bluetooth connection you want to use just disable it
Nov 01, 2010 | Garmin Nuvi 760 Car GPS Receiver
Programming the Garvin to work with a Bluetooth phone
as far as i remember there is no bluetooth on this unit.
May 04, 2010 | Garmin nuvi 255W GPS Receiver
Bluetooth icon missing
The Nuvi 750 does NOT include bluetooth capability. I don't know what you saw, or what you think you saw, but Garmin's website is very clear on this issue. NO BLUETOOTH WITH THE NUVI 750
Feb 07, 2009 | Garmin Nuvi 660 GPS Receiver
I have a garmin nuvi and the cable that you put into your cigarette lighter will not work. I changed the fuse and it still will not keep the unit charged. I can charge it on my computer with a usb cable....
Do you see a lightning bolt symbol over the battery bar graph? This indicates that its charging. If it's under warranty, please contact Garmin on their website. www.garmin.com and call them. No need to worry about this if its under warranty. Send them your charger too.
- Jim
Dec 12, 2008 | GPS
Bluetooth enabling
Does it work properly otherwise? Is this the only place it gets stuck?
Sep 16, 2007 | Garmin StreetPilot c550 GPS Receiver
Missing bluetooth software
The 300 does NOT have bluetooth. See this Garmin link:
https://buy.garmin.com/shop/shop.do?pID=339
The 360 has bluetooth. In order to have bluetooth, you must have the main board inside that has the bluetooth circuitry AND the firmware to support it. The 300 does NOT have the circuitry for bluetooth.
- Jim
Sep 08, 2007 | Garmin n vi 300 GPS Receiver
Garmin GPSMAP 172 GPS Receiver Logo
90 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
