Kenmore Elite HE4 Electric Dryer Logo
Posted on Oct 28, 2010
The CONTROLS LOCKED button is lit and will not go out. I turned off breaker to dryer and light was still on when I turned breaker back on. What needs to be done to turn the CONTROALS LOCKED light off?
Anonymous
Level 1:
New Friend:
  • Contributor 32 Answers
  • Posted on Oct 28, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
32
Questions
Helped
4073
Points
87
There should be a button with a lock icon on it or around it...press it and hold it for 5 to 10 seconds.
tip
The front light lit on my Whirlpool dryer is showing control locked
Hi.
If the front light lit is control locked, that means that your Whirlpool electric dryer had been set in control lock mode.
Control lock is a special mode that will prevent user from changing settings or using control until the dryer gets unlocked again.
The machine is set to control lock mode by holding down the CONTROL LOCK/UNLOCK button for several seconds. In the same way you can stop the control lock mode when the machine is already set to Control Lock.
When the dryer is running and Control Locked is on, the dryer can still be stopped by pressing the Pause/Cancel button, but cannot be restarted until the control is unlocked.
If the front light lit is control locked but the dryer door opens and it does not turn off, then you are probably in this situation. In that case, the door will be opening , but the machine still stays locked.
Disconnecting the machine from power, either unplugging power cord or tripping circuit breaker, won't help. The control lock system is designed to stay on in case of power failure.
If the machine is control locked, try unlocking it with the following procedure.
To unlock: Press and hold the CONTROL LOCK/UNLOCK button for 3 to 5 seconds to turn the control lock feature off.
If that does not work, try disconnecting power for five minutes to reset the machine, and eventually do unlock again. As said, cutting power alone will not cause the machine to unlock.
If the machine is still not responding, the lights stay on all the time, the dryer panel does not respond to control unlock procedure, and the door does not lock anymore, then it may be a defective control board.
If you are in this situation, before replacing the control board more parts, including the door lock must be tested. In that case the best option may be contacting the Whirlpool support number listed on the Dryer use and care manual, usually in the last pages.
In this case try resetting control lock as explained above, as told the dryer is more likely control locked and then stopped.
Regards.
Ginko.
I have quasar microwave and my grandchildren pushed several buttons and locked it up. All of the lights on the screen is lit up. I cant get it unlocked.
Unplug it from the power source and than plug it back in. If it is hard wired, turn off the circuit breaker and turn it back on.
1helpful
My control locked light on my dryer will stay lit for an hour or so, you can't turn it off by hitting the cancel button, once it goes off by itself, it wont come back on for another while...then when it...
Hi
Thanks for using FixYa. To unlock the controls you’ll need to press and hold the END OF CYCLE button for 10-15 seconds. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
1helpful
"Controls Locked" light lit, unlock button has no effect
Have you tried unplugging the machine for awhile to let the board reset?
2helpful
Controls locked status light stays on and dryer cannot be used
To enable the control lock feature:
Press and hold the CYCLE SIGNAL button for 3 seconds. The
CONTROLS LOCKED icon lights up, and a single beep tone is
heard. To unlock, press and hold the CYCLE SIGNAL button for
3 seconds. The indicator light turns off.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 11, 2009 • Dryers
5helpful
2answers
The Dryer says "Control Locked"
Try pressing an holding the "End of Cycle Signal" button on the front panel in for 3 seconds. This button is used to lock/unlock the control panel to keep small children from manipulating the controls when the dryer is not in use. A designed safety feature. If this does not work for you, please post back and let me know. I hope this helps you.
3helpful
Controls locked
Hello
Welcome to Fixya
My name is Huum,
To disable the control lock, hold the OPTIONS and SELECT buttons at the same time until the control lock light turns off.
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
2helpful
I have the kenmore dryer and the light for the controls being locked is lit up and it wont let me press anything or even start the dryer...how do i get the controls unlocked??
According to the owners manual that I have, if you hold the Auto Dry Level button for three seconds, it will lock and/or unlock the dryer settings.
Top Kenmore Dryers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
