Question about Haier Heating & Cooling
Window air conditioner HWR08XC7
It does not shut off when it is in energy saver and thermostat is set. When it reaches the desired temperture it keeps running going below what it is set on.
  • 95 Answers
Could be a lot of things, make sure the temp sensor is clean and is in a position to sense the air temp flowing over it. Other than that it could be out of calibration.
Posted on Jun 10, 2008
How can I fix this?
most a/c's are not designed to take room temperture into the 60's. thermostat takes it off first.
Jul 10, 2014 | Kenmore 70121 Window Air Conditioner...
Model # hwr08xc7 8000 btu. The air conditioner turns on but all it does is blow warm air no matter what setting i have it on.
you can take off the front cover and under the control panel, on newer units have a relay that the low voltage thermostat controls and by pass it. WARNING IT WILL NOT CYCLE NOW AND WILL NEED TO BE UN PLUGGED WHEN DESIRED TEMPITURE IS REACHED. IF NOT IT WILL BURN UP THE UNIT.. this not a 4 sure fix but can get you up and cooling 4 free, or if this doesn't fix it the unit might be junk.. hope this was of help..klick yes
Jul 25, 2011 | Haier HWR08XC7 Air Conditioner
How can I turn on the energy saver on my LWHD2400HR air conditioner? There is no switch on the A/C, only an indicator light that says "Energy Saver"?
The Energy Saver mode is activated by using the hand held remote control, that comes with the unit. Pressing the Energy Saver button activates it. Once activated the fan will shut OFF when the the compressor does. After which, about every 3 minutes the fan will turn ON to check the room air to determine if cooling is needed.
It sounds like, you're missing the hand held remote control?
Jul 19, 2011 | LG LWHD2400HR Wall/Window Air Conditioner
I have the Haier HWR08XC7 (8000 BTU) and my problem is that I have the thermostat set at 70 degrees, but it stays at 77 or 78 degrees... What could be the problem as the unit is 2 yrs old??
Hi!!
Check your owners manual, probably have unit set at automatic comfort level or some energy saver mode. It should say something on the remote about it.
Good Day!! Don't forget to rate this post!!
Aug 13, 2010 | Haier Heating & Cooling
New unit air seems not to be cold
MAKE SURE ENERGY SAVER IS ON SO FAN SHUTS OFF WITH COMPRESSOR. AND MAKE SURE THERMOSTAT IS SET TO COLDEST SETTING FIRST. IF THAT DOSENT DO IT YOU MAY HAVE ANOTHER PROBLEM.
Apr 23, 2010 | LG Electronic Window Air Conditioner
Model number HBLG 12303r how does the energy saver setting work bought this model used.
The energy saver setting will turn the blower fan off when the thermostat reaches the desired room temperature (with the compressor). Other non energy savers only cycle the compressor to regulate the room temp. so their fans will operate continusously using more electricity.
Aug 04, 2009 | Heating & Cooling
Frigidare window air conditioner with remote control about 3 yrs old. All controls seem to be working except when the energy saver mode is suppose to shut down the unit / the display goes dark but the...
Hello, I can assist you.
If the unit is supposed to turn off and it doesn't, it will be necessary to check several things.
  • First, is the unit cooling properly? See the section entitled "The air is cool but doesn't seem cold enough."
  • Next, is the temperature of the room adequately cool? If the room temperature is cold enough try setting the thermostat to a higher temperature. If the unit then seems to work properly leave the thermostat set to the higher temperature.
  • If the unit is cooling properly when it is turned on and the room is not cool enough the problem is probably that the unit is trying to cool an area that is too large for its capacity. Use the following chart to find the appropriate size air conditioner to use:
AREA TO BE COOLED / CAPACITY (BTU/HR)
100 to 150 square feet = 5,000
150 to 250 square feet = 6,000
250 to 300 square feet = 7,000
300 to 350 square feet = 8,000
350 to 400 square feet = 9,000
400 to 450 square feet = 10,000
450 to 550 square feet = 12,000
550 to 700 square feet = 14,000
700 to 1000 square feet = 18,000
If the room is heavily shaded, reduce needed capacity by 10%
If the room receives a lot of direct sun, increase needed capacity by 10%
Add 600 Btu/Hr for each person in the room if there are more than two people
If the unit is for a kitchen, increase the capacity by 4,000-6,000 Btu/Hr.
If the room size is too big for the air conditioner you have two possible choices. Either decrease the room size by shutting some doors or partitioning off an area of the room. Or, increase the BTU of the air conditioner for that room by installing a different air conditioner with a higher BTU rating.
Aug 02, 2009 | Heating & Cooling
This goldstar air conditioner model is WG2405RY7 It has an energy saver, but the unit just keeps running and won't shut off, everything else works.
Doe's the temp reach the set point? If not then it will run until it doe's. If you set the stat warmer and the fan keeps running after compressor shuts off check to make sure it is in power saver mode. Most AC units keep more even temp when fan is left on.
Jun 29, 2009 | Goldstar M1003R Air Conditioner
Need to know if indoor unit fan shuts off at desired temperature
Check your operating instructions and see if indoor fan unit has an "auto" feature that allows the fan to run only when the outdoor unit is running. Allowing the indoor fan to run constantly will provide for better air circulation and less stagnation but will use more energy.
May 10, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Lg 10000 btu ac wall unit
if you remove the front cover you should see a little sensor with a wire. you need to make sure it has not fallen off its bracket or came off form the evaporator. if it looks to be ok and mounted correctly, you may have a bad sensor and it is not able to tell the temp and not shut the unit down. also to on very hot and humid days even though you have it set to energy saver it senses it still needs to run. If you turn the thermostat up when its on the energy saver will it shut off? and if you do the same on the regular setting will the comressor shut off and the fan stay running? Let me know and I can go from there. Thanks
Aug 05, 2007 | LG Electronic Window Air Conditioner
Heating & Cooling Logo
98 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
