Question about Whirlpool Refrigerators
Replaced inlet valve 2 months ago,stopped pumping water to ice maker. line is clear. ice maker cycles ok otherwise.
  • 770 Answers
Open the cover to the icemaker pull it off the white plastic cap you will need an insulated peice of small wire to make a jumper stick one end into the "T" terminal hole and the other in th e"H" terminal hole the icemaker will cycle pull the jumper out after 10 secs of the start...watch the ejection fingers when they reach the 12 o'clock position you should get a fill for about 7 sec.
Posted on Jun 09, 2008
    Genius:
  • 1,073 Answers
Check for bad water valve again
The ice maker in my Whirlpool Gold (Model GI6FDRXXY07) stopped making ice. I can get water from the door and can hear the ice maker cycling. It is calling for water but the flow valve is not opening.
The same valve that the water comes from except there are two halves to the valve. The valve you need is a=> Whirlpool Refrigerator Water Inlet Valve WPW10312696 The problem is with these models the ice maker tends to function a little causing you to believe it is OK when they are worn out. I can point you to a manual to see if the water valve works by going to page 18 HERE and use a jumper wire between test point L and the letter V. Make sure the wire is insulated so you don't get shocked. Otherwise the ice maker may need to be changed and it is less expensive than the water control valve Ice Maker=> HERE
APPLIANCE911
E-Mail Contact Me Here
Aug 29, 2016 | Whirlpool Refrigerators
I have a Scotsman CME 506 ice maker. After running a cleaning cycle it won't run. After resetting the freeze light blinks and nothing happens. The water inlet valve never opens (the sump is current
CM3 Operational Sequence.
From Off, push and release the freeze button.
1. If sump is full,water pump starts.If sump is not full,water valve opens to fill it.
2. Compressor starts when sump is full.Air cooled fan motor starts too.
3. water pump stops early in freeze cycle for 30 seconds.
4. Sump refills after pump starts.
5. In low ambient condition,fan motor may begin to cycle on and off.
6. Freeze continues until water level in sump drops to preset point. Exceptions: SCE275 must fill sump two more times.
7. Fan may shut off before the end of freeze.
8. Harvest begins. Hot gas valve opens,pump stops.
9. Pump restarts, inlet water valve opens to fill and overflow the reservoir.
10. Harvest continues for preset first cycle harvest time.
11. If bin is not full, cycle repeats ( compressor stays on). If bin is full, unit shuts off at the end of harvest.
OK with that out of the way unless you unplugged any wires cleaning the machine should not have caused any problems. First cut off water and pull water supply line from water inlet valve look in the end of valve there is a screen in there it could be stopped up. If the valve screen is not stopped up then put supply water line back on and turn water back on. power the CM3 controller off. push freeze button. now with a voltage meter check at the water inlet valve to make sure you are getting power to the valve.If you are then either valve is stopped up or valve is bad. If you are not getting power to valve then replace the CM3 controller now make sure the bin full light is not on because if it is this will not let controller go back to a freeze cycle.
Oct 28, 2014 | Kitchen Appliances - Others
No water no ice
Change the=> 67006531 Water Inlet Valve I believe the side of your 67006531 Water Inlet Valve that controls water flow to the ice maker has weakened and cannot open properly. Replace the water valves and I believe the ice maker will work fine, Sea Breeze
Jun 07, 2012 | Whirlpool GX5FHTXVA Bottom Freezer French...
Hi, I have a Kenmore Elite Refrigerator model #596.76253702 that leaks water from the bottom every time the ice maker refills. The problem keeps getting worse since I purchased this product 2 years ago.
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
Ice maker water not stopping
The water inlet valve may be staying open. You can swap the wires on the dual water inlet valve and disconnect the water line at the valve which goes to the ice maker. When you try the water dispenser the water will come out there. When you stop the water dispenser, if the water at the valve doesn't stop, the valve isn't closing so you'll need to replace it. If it does stop after trying it several times then the problem is with the ice maker.
Aug 24, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
I have a Kenmore ice maker that makes a sucking sound while cycling. The water pan will not fill up all the way between cycles and my ice harvested is thin and cloudy. Do I have a pump problem? Can it...
It sounds like your water supply line might be partially clogged probably at the water inlet valve in the bottom left front of the machine. I think there is a screen in there that you can clean out. The circulation pump will make a sloshy surging sound when not enough water is cycling through it as it pumps it up to the ice making sheet. You may need to replace the inlet valve itself. Pour extra water into the water reservoir in the interior of the machine and see if the pump runs smoothly thereafter.
Dec 31, 2010 | Kenmore 51lb. Clear Ice Maker
Icemaker not working
The ice maker valve is a dual one. with 2 solenoids. One solenoid operates the water and the other the ice maker. So if the water works that don't mean the ice maker supply is ok. The ice maker itself controls the flow of water. So if the water valve is ok then the ice maker is faulty. I have repair photos HERE
Feb 14, 2010 | Refrigerators
Ice maker quit working on GE refrigerator
Sometimes on a ice maker what will happen is the water line that fills the ice maker will freeze. You can use a large syringe filled with hot water and from the rear of the frig remove the water line where the hose goes into the rear of the frig and force some hot water into the tube to see if it is clear.
If the line is clear fill the ice maker manually and see if it goes through a cycle.
If it goes through a cycle you have to check to see if the ice maker is calling for water by putting a multi meter across the contacts of the water inlet valve located behind the panel on the back of the frig. Advance the ice maker to run through a cycle and see if it is calling for water. If you have current going to the valve and no water momming in, replace the valve.
If you do not have current going to the valve after the ice maker has gone through a cycle. Replace the ice maker.
Dec 29, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
No water is coming into the ice maker
HI. First you will need to make sure the inlet tube, inside the unit is not frozen over. Once you have confirmed that the inlet tube is not frozen, this will lead to a spent water filter, or a failed water inlet valve assembly. If equipped, check the filters date. if it is more than 10 months old, it may need ot be replaced. An old, or fully used filter, will stop the continues flow of water, when it reaches its filtration limit.
Now, once you have confirmed that the lines and filter(if equipped), are not the issue, then move on to the water valve inspections.
WATER VALVE
The water inlet valve is located behind your refrigerator. Find the water supply line coming into the valve and turn it off at the source (typically under the sink). Disconnect the supply line. Remove the screws that secure the inlet valve in place.
The water inlet valve is connected by two wires. Label the wire placement on the water inlet valve before disconnecting the wires. The wires are connected to the terminals with slip on connectors
Firmly pull the connectors off of the terminals (do not pull on the wire). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If the connectors are corroded they should be replaced.
Inspect the filter screen where the supply line connects. Remove any debris or deposits that may have built up using a toothbrush
or warm running water. If you cannot clear the clog, it will be necessary to replace the valve (the filter is not removable on most inlet valves).
Test the water inlet valve for continuity using a multimeter. Set the multimeter to the ohms setting X100 (if available, otherwise use the nearest ohm setting). Place a probe on each terminal. The multimeter should display a reading of 200 to 500 ohms. Close inspection of the inlet valve and especially the coil may reveal the exact ohm resistance rating to test for. If the water inlet valve does not pass this test, it should be replaced.
Oct 24, 2009 | Kenmore Refrigerators
The ice maker stopped making ice. Any solutions?
A lot of filters ( not all ) do not even access the ice maker . Only the water dispensor . If your water dispensor is working fine , then you need to replace the dual water inlet valve behind the refrig . This is the piece the wall water line connects to . It is called a dual valve because there are 2 coils on the valve . 1 for the ice maker and 1 for the water dispensor .
Oct 23, 2009 | Kenmore Refrigerators
Ice maker stopped
The water inlet valve is the control device that controls the flow of water to the ice maker, it is energized during the last few seconds of the harvest cycle. During these few seconds there should be 110v power to the water inlet valve, if there is power to the valve but the valve does not open to allow water to flow then the valve is defective and must be replaced if the valve does open it could be that the water supply line inlet tube has frozen solid this can be thawed with warm water or a hair dryer. The area of the tube vulnerable to freezing is where the water line enters the freezer section and connects to the water supply inlet of the ice maker.
Also there are obviously other reasons that it might have stopped such as a faulty harvest thermostat, your freezer is to warm and of course your shutoff arm in the off position, be sure to clear the simplest potential causes of the failure first.
Hope this helps.
Mar 15, 2008 | Refrigerators
Refrigerators Logo
63 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Steve
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
