Question about APC Heating & Cooling
Home central air conditioning unit
Not blowing forcefully, not really cold air, not kicking off
  • 95 Answers
Check the filter, make sure it's not plugged. Make sure all the vents are open. Are the lines freezing up (have ice on them?) Could be a lot of things but if it is not blowing much air then you may have a motor problem or dirty filter. If the unit is freezing up then probably have a leak and will need to be found, fixed and recharged.
Posted on Jun 10, 2008
2012 Alpine 3700re. Why is the rear air main air outlet not blowing forced air?
Assuming you are talking about some kind of central forced air and not a roof air conditioner, I would say the hose fell off the outlet or the A/C unit itself. Do all the other vents blow cold air? If yes, remove the wall vent and look. If the hose is attached, go to the A/C unit and check there. Also, remote possibility some kind of critter got inside the hose and built a home, effectively blocking the airflow.
Not enough info on filters. Central air filter? Roof A/C filter? Engine air filter?
Manufacturers put so many different models of sleeper sofas in RVs, it's hard to tell which one you have. Your owner's manual should tell you. If you don't have one, look around. There might be a latch(s) somewhere. Or try pulling up and out or straight up.
Jun 30, 2015 | RVs
Central heat not blow hot air
you posted in november if it was very cold auxillary heat issue.
Nov 11, 2013 | Goodman Heating & Cooling
Car blows warm air when idling
It sounds like your AC unit could be overheating or even damaged.
AC units have a sensor that will turn them off automatically to prevent damage from overheating. If there is an insufficient amount of air flow, the unit will heat up, and then eventually turn off.
When the car is moving, more air is forced over the unit, likely keeping it cool enough to run, however, when the car come to a stop, it loses that air flow, and quickly heats up. Thus, the AC would work while the vehicle is in motion, and overheat and stop when the car is stopped and idling.
However, the AC unit could be completely blown. The cold air while moving could be just a case of air being forced into the car. Think of a house fan, the fast the wind blows on you, the cooler it gets.... Thus, it could be an illusion that the AC is working when car is in motion, when it really isn't.
Hope this helps.
Jun 09, 2012 | 2004 Lincoln LS
My central air conditioner is making a whistling noise in the inside unit when the compressor is running. It's not the blower because the noise stops after the outdoor unit shuts off. It's also not blowing...
If there is no cooling (meaning no cold pipes and not blowing cold air) then check the outdoor A/C for any visible/obvious issues; breakers not tripped, no debris blocking the outside unit from passing air through it, etc. If all looks ok, you can start checking some things inside of the unit if you feel comfortable doing so. Also, most indoor heaters have a higher speed/rpm for the fan when the cooling kicks on, and the heat runs on a lower speed/rpm.
Hope this helps James
Apr 05, 2011 | Heating & Cooling
Central air conditioning system is blowing warm air.
many, many. Is the outside unit running? If it is, is the compressor running? Feel the refrigerant lines leaving the unit. Little one should be warm. Big one should be cold, probably sweating.
Jul 08, 2010 | Ruud UAPA042 Air Conditioner
AC blowing warm
Is it that hot in Sedona. I live in Tucson and thats hot. Have your freon recharged. You can buy the refrigerant at Checker or AutoZone. How do you like our Governor. She really made the national news.
Apr 25, 2010 | 2005 Kia Sedona
98 Explorer, cold air seeps not blows out in dash area.
ok, girl frm LA. It sounds like the door that allows fres air is open. Chk to see tthat there is nothing set on vent. or mix. I don'y know what kind of controls you have.
Sep 18, 2009 | 1998 Ford Explorer
Central air system blows cool air not cold and
your indoor unit is only circulating the air in the house. for your condensing unit. check your breaker in the electric panel. your contactor or your capacitor.
Aug 09, 2009 | Carrier Heating & Cooling
Heating & Cooling Logo
146 people viewed this question
Top APC Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you an APC Heating and Cooling Expert? Answer questions, earn points and help others
