Keyboard will not work donot light up tried diffent one same thing
  • jpage51 Jun 12, 2008
    maxdata after pluging in earphone which have been use many times before, tried pc today keyboard still not working and now mouse as stop
  • Rick Netzke May 11, 2010
    What kind of computer are you using? When did the problem start? Any more information would be helpful
Try using a usb keyboard
Posted on Jun 10, 2008
My svd13215pxb show blank screen and power on
Plug an external monitor in and then try and boot again.
Oct 01, 2016 | Sony VAIO Duo 13 SVD13215PXB 13.3"...
Left arrow keypress is not recognized
Check battery in wireless keyboard... May be weak. If wireless keyboard and mouse are after market you may have to reset them...or if the keyboard is old it may have crud trapped in between the key. Turn off..spray a little alcohol between the key and let dry before trying to use it again. Keyboards are cheap if that does not work replace it.
Mar 10, 2015 | Computers & Internet
Why My netbook donot show the screen. after it swich on.
Hi
Could it be that the light on the screen is turned all the way down? Try to locate the keys on your keyboard and turn the light up.
Hope this is the case, it is the least expensive ;-)
Feb 19, 2015 | Samsung NP-N145-JP02US NETBOOK
I have a 89 chevy 1500 the brake lights do not work. The turn singals work the running lights work but the hazzard flashers do not work either. The brake lights donot work or the hazzards donot work ,...
First check all fuses. If they look good, more than likely brake light switch is bad. Switch is mounted just above brake pedal under the dash. Small plastic switch w/a couple of wires coming from it. Easy fix.
Mar 14, 2011 | Chevrolet 1500 Cars & Trucks
ViewMate Keyboard: when I press shift 2 I get inverted comma. donot w...
you need to change the keyboard lay out install US if the machine is from US and UK if bought in the UK goto regional settings etc
May 16, 2010 | ViewSonic ViewMate Keyboard
Keyboard wont work.
i had the same problem and called hp i was told to turn off my notebook and unplug the charger from the notebook take the battery off and hold down the power button for 30 seconds then reattach everything my keyboard started working again. i was told this happens because i donot let the battery die on my laptop or i keep it plugged in all the time which is true the notebook has to much static and the keyboard stops working. hope this helps
Feb 15, 2009 | HP Pavilion dv2715nr Notebook
My keyboard
Is it just the ENTER key above the SHIFT key or is it also affecting the ENTER key on the numeric keypad also?
Is it a USB k/b? If so try unplugging it and rebooting PC then reconnecting it.
If it is a PS2 connection (usually purple round connector) then try a reboot only.
Ifthese things donot resolve the problem, you should try testing it on another PC as it most likely is faulty
Jul 12, 2008 | Gateway (7000375) (  7000375)...
New Gateway KEyboard problems
If u installed anything incorrecly then the computer will prevent the mouse and keyboard from working, try plughin in a diffent one and see if it works, if not, ur keyborad and mouse might have fried
Jan 04, 2008 | Computers & Internet
Wii been working perfectly with all games ,then suddenly no colour on screen on all games just black n white
try turning off the screen burn in if that does help if that doesn't work try a diffent tv if it the same thing then the console has a defect with the screen burn in and needs to be returned
Jan 04, 2008 | Nintendo Wii Console
Computers & Internet Logo
David Payne
David Payne
