Question about Cooktops
Converting gas hob to electric hob
Hiya, the wife wants to convert from a gas hob to electric hob, is it easy to install? the oven is electric, and we have a power supply on the wall. many thanks. john.
If you are in the USA most codes require a seperate circuit for the oven and the cooktop. Most cooktops require 30 amps and at least #10 wire.
Posted on Jun 29, 2008
Intalled the 30" gas oven, converted to LP (both
Hello, thank you for posting. It sounds like you have done a little work to get the unit converted to LP. Make sure you didn't install the regulator upside down. Sometime you can get a defective regulator out of the box. Some of the regulators have the "N" for natural gas if so you need to convert this as well. I suggest you send a factory repair person just to double check on the unit. It well not cost anything to have them test out the unit if you feel the part is "broken".
Happy Holidays!
Please rate me "4 thumbs" if that was helpful.
Dec 20, 2010 | Maytag 30" Built-In Gas Cooktop - White
Electric ignition to hob seems to be jammed
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
May 31, 2010 | Cooktops
Gas hob ignition firing, won't stop
not a solution I'm afraid - I'm having the same problem. How did you manage to fix it?
May 11, 2010 | Baumatic 27 in. B67 Gas Cooktop
Severely reduced gas supply to hobs while grill
Valve at back of cooker that isolates gas to the hobs when the lid is lowered is sticking. Move lid up and down half a dozen times or oil it to ease it.
Dec 27, 2009 | Cooktops
Creda gas hob now keeps ignighting
the ignitors have got wet usually due to cleaning. they are usually located under the rotating switches just let them dry out ( very well .....may take days) and it will work normally again
Dec 23, 2008 | Bosch 30 in. NGP 732 / 736 Gas Cooktop
No gas to hobs
use mactches for ur gas burner if the ignition not really work.put all gas in off position b4 cleaning by using a vacium in the place of the control knob,turn off the power b4 try to clean,tnx
Nov 24, 2008 | Dacor Preference SGM466 Gas Cooktop
Injectors for hobs convert from LPG to natural gas
try to call wat brand u have to buy a injector for convertion,big different the injector for LPG and the natural gas,the LPG injector is small hole & the natural is have big hole.
Nov 21, 2008 | Cooktops
Gas Hob Flame
Hello
Tha sounds to me like the air mixture nedds to be adjusted on the stove, It's not difficult to do, just rotate it until the flames loose the yellow or your pans will be stained with soot.
The should be by the fittings (convertion fittings), you know?
LP Gas to Natural Gas or Natural Gas to LP Gas.
Hope this help
Eddie Rentas
Tupper Lake NY
Jul 30, 2008 | Cooktops
AEG 5 burner gas hob
there is a bypass screw on each gas valve. adjust so flame is reasonable when each burner is turned to low
Jun 15, 2007 | AEG 34942G-M Gas Cooktop
Cooktops Logo
323 people viewed this question
Top Cooktops Experts
Dan Webster
Dan Webster
meztang
meztang
Gere knutson
Are you a Cooktop Expert? Answer questions, earn points and help others
