Question about Linksys Wireless-G WRT54G Router
Linxsys wireless modem
I am having a problem connecting a laptop to my linxsys wireless modem. The computer recognized the linxsys and says it is connected with good strength but the internet will not come up.
I am having a similar problem. the computer is working when wired to the router, but i can't get computers to connect via wireless.
Posted on Jun 09, 2008
Hi!
first, disable the laptop firewall!
second, try configure the router using your web browser.
third. Your modem is also a router, the you need to configure two internal devices : the wan ( sided connected to internet) and lan ( connected to the wirelle devices and your laptop to.
v15307086@gmail.com
  • 2,794 Answers
Is it working if a computer is wired to the router?
Can I disable wireless and connect with ethernet cord and modem, for work do not want remove wireless cord, in the day want to be able to use my wireless.
Are you talking about direct-connecting via Ethernet to a cable or DSL modem? You shouldn't have to disable wireless to do that. If the cable modem has an open Ethernet port, you should be able to run a straight-thru Ethernet Cat-5 cable between that port and the Ethernet port on your laptop. The laptop should recognize that it is connected to the modem through the direct connection. Check the manual for the cable modem or information supplied by your ISP for connection details. You may have to do some setup on the modem to get an Internet connection, like having your ISP 'activate' the modem. Just be sure your Ethernet cable is a straight-thru, standard Ethernet cable, and not a 'cross-over' cable such as is used to transfer data between two computers.
Jul 24, 2014 | Dell Inspiron Computers & Internet
Other computers do not recognize my network
If you have a wireless router and it is connected to the DSLor cable modem then -To connect to your wireless router, the router needsits wireless settings to be configured with the SSID, encryption key etc., alsothe wireless cards and wireless adapters in all the laptops/computers needs tobe configured with these router's wireless settings. Then the laptops/desktopcomputers can communicate with your wireless router and access the Internet via the DSLor cable modem.
Jan 27, 2012 | D-Link Computers & Internet
Cannot to connect wireless broadband
do you still have the disk that came with the modem,if so run it on your computer and follow the instructions,let me know what happens
Apr 03, 2010 | Fujitsu LifeBookS6120 Notebook
Desktop wont connect to internet but laptop will
Is your cable modem also a wireless router?
From my search on it, it is not a wireless router.
This means you need to attach a hub or a wireless router to your cable modem so that more than one computer can connect to the internet simultaneously.
Go out and buy a wireless router. Connect the wireless router to your cable modem.
Connect your desktop to the wireless router with an ethernet cable.
Then you should have internet on your desktop.
Let me know if this helps. Give me a good rating and vote for me please.
Mar 24, 2010 | HP Compaq Presario SR2011WM PC Desktop
My broadband's modem cannot be used at my laptop but can be use at another laptop.
The modem - and the wireless cards if it's wireless - should come with a software to ensure the system will recognize your internet connection. If your modem is supposed to be wireless, just try and see if your laptop would work with an Ethernet wired connection to test if the modem itself would work with that laptop. If not, then your laptop may have a missing or corrupt component caused by malware. It also depends on the models of your two different laptops. Maybe the one that doesn't pick up the modem is incompatible with the given software. In which case if your machine is clean of malware, then you should contact your ISP and sort out the possible incompatibility issue. Good luck. Please do rate me if any of my ideas work. Thanks
Feb 05, 2010 | HP Pavilion dv5-1125nr Notebook
What do you need to connect xbox 360 to laptop got a router do i need a modem and a adsl line as the laptop is wireless broardband.
you must have a modem and a dsl line..
connect the dsl line to the modem..
then modem to router...
router to xbox..
throught LAN connection..
Oct 25, 2009 | Computers & Internet
Internet Connection Problem on One Computer
By any chance, are you trying to use something other than Windows to manage the wireless adapter? If you are, remove it.
Now, Click on Start, right click on Network highlight properties, and click on manage network connections on the Tasks menu.
Your two options will be the icons for your LAN and Wireless Network. Is it enabled and without red or yellow marks? It could be disable, it could be not connected and you can't view wireless networks because the switch is off, or it may just nut see your unsecure network (unlikely).
If the above is clear, right click on the wireless and highlight Properties and left click so it brings up the Networking tab. Highlight IPv4 and click on Properties. Make sure the Obtain dots are ticked. That should work, since you are running unsecured.
If it already is, check the red X or if it isn't click OK and close down the box.
Now, back to where your Wireless card is showing, right click it and you have Disable, Connect/Disconnect, Status, Diagnose etc.
If you're still Disconnected but not Disabled, click on Connect/Disconnect. Does it show your wireless network?
By this time, it should. If it doesn't post back. The other possibility is that you take your computer to a wireless internet cafe, McDonalds, Panera Bread, or motel with WiFi and test it there.
Carl
Jun 21, 2009 | Linksys Wireless-G Broadband Router
Wireless connection not working
Have your ISP setup your modem/router on there end its not setup yet.
Apr 11, 2009 | HP Pavilion dv6105us Notebook
Why does this keep happening??? Please advise...
Your modem is set to only allow one main IP address, which it assigned to your laptop.
Connect the cables through the router, then unplug first the modem, then the router.
Wait 45 seconds, then plug in router, wait 5 seconds, then plug in modem.
Give it a few seconds to talk to everything, and you should be good to go.
Dec 04, 2008 | Linksys Wireless-G WRT54G Router
Server not found} NetGear WGR614 Wireless Router doesn't connect me to the internet.
Dear Loud Nouises,
Your router must be connected properly to the cable modem. This must be to the wan port on the router.
Next, the router must be set-up accordingly to recognize the modem's internet connections. Please ask for the IP address.. and other relevant informations from your internet provider.
Set -up your computer using the internet connections wizard on each of your respective computer.
This should work fine if all connections were correctly configured.
Sidlahora
Nov 27, 2007 | NetGear WGR614 Wireless Router
Linksys Wireless-G WRT54G Router Logo
167 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
