Question about Bernina Artista 180
Thread get's tangled and attached to plate while embroidering
I have been embroidering and sewing on my 180 for 8 years now but within the past 6 months something will happened and thread will get tangled and caught on the plate only when embroidery module is being used. I will hear a metal sort of noise and then it may break a needle or just get all tangled. I will then literally have to cut the hoop away and usually end up ruining another item. It also will usually pull the needle out. I had the machine serviced a few months ago for this problem but it is still doing it. I used to enjoy embroidering but now it's something a dread. Any suggestions? .
  • 323 Answers
Just a thought. Is it possible that your thread is wrapping around your spool post or snagging on your thread spool?
sewman7
Posted on Jun 12, 2008
I have a futura SEQS 6000. It sews perfectly fine but when I try to embroider the thread is either unthreaded or becomes tangled with the bobbin thread and doesn't finish the design.
indicates that the needle thread is not tight enough some embroidery threads are finer than normal threads so require an increase in thread tension
Jul 09, 2016 | Sewing Machines
Top thread gets tangle under plate
ajust the tension to top thread
Apr 04, 2014 | Baby Lock Ellure
How do you start embroidering a design where the thread breaks on a Bernina Artista 180 sewing/embroidery machine?
Most machines have a stitch counter, stitch forward and step back features. Check your manual and embroidery machine's screens for this.
IN case you have misplaced your manual I found this one for you. It's big so allow time to download.
http://www.itsastitchonline.com/mastery_on_the_web/Mastery_170_180_1-10-02.pdf
Sep 10, 2012 | Bernina Artista 180
Top thread - not bobbin thread - bunches up under fabric where feed dogs are when I'm embroidering.
this is a top thread tension problem . make shure thread is between tension plates and spring is contacting the plate if the tension number is high
Apr 12, 2010 | Baby Lock Ellure
I recently replaced the bobbin case because it developed a deep groove in the side after I put it in improperly. The initial reason why I took it out was because the thread bunched up under the plate while...
the problem of your machine is, under the plate of your machine, you saw the teeth look like the used of it is to move forward the cloth u embroiderd, you should tight the bolt or nuts so that, the bunching up of thread on the plate will stop. thank you!!!!!
Jan 26, 2010 | Baby Lock Ellure
Thread tangles under throat plate while embroidering
Could the little hook that is stuck over the bobbin area be the thread cutter? My thread cutter gets stuck there and I have to turn my machine off and then try to use the cutter to reset it to its "resting" position.
Nov 23, 2008 | Brother SE-270D Computerized Sewing...
Hi, I'm trying to embroider using my Singer Futura CE-100. After it starts to embroider, it will either bunch up bobbin side or the machine will beep, and the computer says to turn it off, remove hoop,...
could be a threading problem. on the top of the machine, where you go under the plate, pull the thread back and forth like you are flossing. you should feel the thread snap around the 2 wheels, then continue threading. hope it helps
Aug 15, 2008 | Singer CE-100 Futura Computerized Sewing...
Singer Futura CE100 Embroidery
check to be sure machine is being threaded correctly first, then when pressure foot is lowered pull thread and see if you are getting tension, if not assembly is bad
Jan 21, 2008 | Singer 7422
Needle Thread and Bobbin Thread
This is a timing problem and will have to be repaired by authorized dealer.
Jun 18, 2007 | Euro-Pro 373 Mechanical Sewing Machine
Sewing Machines Logo
175 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
