Question about Alpine CDA-9811 CD Player
What lead do i need to get to play my ipod through it
Not sure if my unit would use a (m-bus din male) cable or a (ai-net) cable
    Problem Solver:
  • 3 Answers
You will need an ai-net cable. your local car audio dealer will definitely know.
Posted on Apr 19, 2009
Ai-NET cable is cut, wire splice male aux cord
On the ai net cable identify and separate strand with green, blue and unshielded common/ground. G and B will be your positive which you will then solder to red and white leads from rca or headphone cable with unshielded from that cable twisted together and soldered together with the unshielded wire from ai net cable. Tape off or heat shrink the rest of wires from ai net cable.
Sep 29, 2013 | Alpine CDA-7863 CD Player
Does the Kenwood KDC MP5032 have an aux input? If so, where is it?
Kenwood utilize the CD Changer plug in the back (which acts as a secondary Aux input), to operate external iPod devices.
This is done with the aid of an Adapter Lead - it has the 13-pin DIN plug on one end (plugs into the rear of your unit), and an iPod plug on the other end (plugs into your iPod).
Depending on the "Generation" of your external iPod device, you will need to buy the appropriate Kenwood adapter cable. These are: KCA-IP102, KCA-IP202 or KCA-IP302.
There may be some aftermarket (3rd party) cables that may do the same job.
Just ensure you read your Kenwood manual, as the Kenwood unit may be limited to the types of files (i.e. formats) it can read & play.
Hope this explains....
Dec 31, 2012 | Kenwood KDC-MP5032 CD Player
FCan get my Ipod to play through my Roland TD-20 Mudule
You need to get yourself a cable - with a 3.5mm male jack plug on one end (which will fit into your ipod), and a 1/4 inch male jack plug on the other end.
(you could use a lead with a 3.5mm male plug on each end, and used a 3.5mm female to 1/4 inch male adaptor to achieve this)
Connect the 3.5mm end into the ipod - play a track, with the volume at say, 75%.
Connect the 1/4 inch end of the cable to the 'Mix In' input in the back of your TD20.
Use the 'Mix In' control - at the top right hand side of your TD-20 module to control the volume.
If you wish only to have the iPod going to (for example) headphones - and not Front Of House (PA) speakers - which you will have connected via the Master and / or Direct Out(s); this can be achieved in the 'Mixer' settings (accessed via pressing the 'Mixer' button).
Oct 22, 2012 | Roland TD-20X V-Drum Sound Modul
Is the system cable wired as a serial connector
u can get one from 8 pin mini din male/male
Oct 19, 2009 | JVC TH-M303 System
There is a auxiliary button on the sony cdx-m8800. Is there a way to hook up an IPOD? The stereo also has MP3 written on the inside face. Thanks
Contrary to the below Expert's testimony, the UK CDX-M880 has a REAR AUX connector that will enable you to play your iPod through your car's stereo.
You will not be able to control the ipod's interface through the radio. You will have to use the control on the iPod .
You require a Male 3.5mm extension cable like the following...
a5e60c6.jpg A 4-6 foot length is recommended, as the cable will need to be routed from behind the radio to a place your iPod can be easily manipulated.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 18, 2009 | Sony CDX-M8800 CD Player
Want to know if I can use the line-level inputs from the CD Chgr
Your alpine unit is the old "M-BUS" the other adapter you are talking about is an "AI-BUS" adapter. (Hence the model numbers beginning with CD"M" or CD"A" ...)
Look for an Alpine M-Bus to RCA Input adapter.
heres one on eay for less than 10.00 including shipping.
Feb 09, 2009 | Alpine CDM-7857 CD Player
What is the AUX good for
I use the Aux to plugin my Ipod, amke sure you have it set on. Then it acts as the plugin. it was originally there for XM radio or a tv.
Sep 24, 2008 | Alpine CDA-9805 CD Player
Ipod connection instruction
you can get a set of phono leads with a jack on just one end?plug that in to the back of the head unit (depending on your pre out options and aux option) then plug it straight in to you ipod.
hope that helps?
Mar 08, 2008 | Alpine CDA-9851 CD Player
Hooking up ipod
Hi I am on the same boat and about to purchase the same cable. I did a little research which identiies that for TDM 7574 needs to have a Versatile Link eature, which also says that it must have a pink and black cable,I have asked the seller and waiting their response. I know its not a solution (yet), but I hope it gets us closer to a solution. Pls find the link regarding this..
Sep 27, 2007 | Alpine TDM-7574 Cassette Player
Alpine CDA-9811 CD Player Logo
157 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
