Question about GE Washing Machines
Dos not drain - GE Washing Machines
  • 868 Answers
Water pump is clogged up.If your machine is 1-7 years old.Remove the front panel ,on left side towards the bottom you will see the pump. Remove the 2 hoses and clean out the stuff inside.
Please rate This !
Posted on Jun 09, 2008
Wot dos oe as a fault code on my lg washing machine mean
Output error. Bad pump or kinked drain line
Apr 20, 2017 | LG Washing Machines
It dos not stop filling up water
The pressure switch, also called the water level switch, is what control the amount of water goes in the machine, If your machine is constantly filling to the overflow point, then that is your problem. Now, if water is going in and the level is staying the same then your machine drain line is lower than the pump and your siphoning out the water as it goes in. Pull the drain up a little a that should fix the problem.
May 27, 2012 | Zanussi ZWF1430W Front Load Washer
My Kenmore washer will not move into the next cycle unless I manually turn it to the next cycle. This just began today. What is wrong with it?
It's either the timer is faulty or the lid switch is broken. If it fills and agitates but dos not spin and drain it's the lid switch. If it spins and drains when manually advanced to that setting your timer is bad.
May 18, 2011 | Kenmore Washing Machines
What dos 5d means before the spin. When the time
Hi
Thanks for using FixYa. Error 5d means too much detergent was used. Try the following procedure---
Run the unit through a RINSE/SPIN cycle.
Run a NORMAL cycle without adding any detergent.
This should clear the unit of the excess detergent. If still the problem persists, then please check the following things--
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump, pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic Test or any cycle and replace the part that has gone bad.
Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Aug 11, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
My hotpoint aquarius dwf30 will not drain so will not wash...
Do you hear the motor run or is there deadly silence when you select drain.
Does the wash cycle start - do you hear water getting in and washer arms move?
Are there any lights flashing?
Jul 06, 2010 | Hotpoint 24 in. DWF32P Free-standing...
Washing machine wont drain or spin. It will agitate, but as soon as it clicks over to spin and drain, it shuts off.
Sounds like the motor is bad, dos it start to spin then stop, then this is the case, but if it never starts spinning then check the door lid switch,
Nov 26, 2009 | GE Washing Machines
Air conditionor dos not drain
you will find it on the passenger side on the fire wall to the bottom you'll see a short hose sticking out with a soft wire push it through and be careful not to pock a whole the evaporator. if this information has been useful please let us know good luck
Jul 28, 2009 | 1998 Chevrolet S-10 Pickup
I got an 01 concorde LXi 3.5 L need oil pan
they make oil drain plug repair kits for this problem, contact NAPA or Carquest for detailes, no need to replace the oil pan.
Jul 16, 2009 | 2001 Chrysler Concorde
The water in the dishwasher does not drain
Here is a good resum of what you can do when a dishwasher does not drain.
Click on the following link : The water doesn't drain from the machine.
Oct 23, 2008 | Frigidaire 24 in. FDB126RB Built-in...
Washing Machines Logo
37 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
