Question about LG Heating & Cooling
I installed a dual split ac system an code ch 33 comes up on both units does this mean its low on charge? i put in the recommended freon
  • onebadtatt Jun 10, 2008
    i resolved the problem code ch33 means in short term needs more charge.and yes i have a universal certification for over 10 years now, the code comes up on both units the lg installation manuals never mention any codes but if you go to their web site you can find a list of codes and what they mean these dual zone art cool are a little more sensative than other single split systems
  • 95 Answers
Post a little more information and by the way are you certified to handle freon? $10,000 fine if you are not.
Posted on Jun 10, 2008
Light 2 and 3 flash in the condenser outside in my mini split system dual zone AC/Heat Pump. My second floor AC unit does not work. Green light comes on, vent opens, green light flashes.
Flashing lights normally are an error code.. this could be anything really. You have to find out what that code is telling you (manufacturer specific). You most likely won't be able to fix this yourself if you can even find what that code means.. your best bet. Get the installer back. Unless you did it yourself. Then your gonna pay a lot for service unless you find someone willing to look at it (not many people will look at systems they didn't put in.)
Otherwise you have a ugly box on your wall that wi?l only flash some lights at you..
Jul 19, 2017 | Heating & Cooling
I just got a 1983 33 ft Southwind Motorhome and everything in it works just fine except the ac quit working so I decided to try the 1 in back and it wouldnt come on either I only ran 1 at a time
The Ac system can not work for a variety of reasons. The most common is a low freon charge. You need to have the system pressures checked with gagues to determine if freon is the issue or there is an electrical problem with the compressor
Jul 12, 2015 | AC Cars & Trucks
My new LG mini split 24,000 BTU unit is Freezing up on the small tube side. Not cooling properly. I thought freezing up (low on freon) but wouldnt it be on the larger tube. Is it running the fluid...
The larger tube is the return tube for the hot freon gas from the evaporator. The small tube is the cold freon after is has gone through the condenser where gas is condensed to a liquid when the heat is removed. So I would say your system is low on freon.
Jun 09, 2011 | LG LM-2430H2L 24000 BTU Heat and Cool Dual...
We have LG air con system (hot and cold) coming up with error code CH33. What does this mean?
CH 33 -Excessive rise of standard compressor discharge temperature. If over 105°C check refrigerant charge. Over charged, release little gas still to normal PSI. If condenser full of debris, clean it.
Dec 18, 2010 | LG LS-L1210CL Mini Split Air Conditioner
Ac problems
This could mean the freon is low,or internal problems with the ac,try charging the system,you may have to reset the ac system if the ac compressor will not come on to charge the system,by removing the negative battery cable for 20 seconds,and the putting it back.If this was at all helpful,please rate,thank you.
Jun 22, 2010 | 2001 Mitsubishi Eclipse
Compressor shutting down
FC IS FREON CHARGE, WHAT YOU ARE GETTING IS A HIGH PRESURE CUT OFF  FAILURE. THE LABEL PRESURE IS TEST PRESURE. THE RUN PRESURE ON LOW SIDE IN AC MODE IS ABOUT 65 AT 75 T0 80 DEGREES INSIDE AND ABOUT 200-300 HIGH SIDE AT 75 -85 OUTSIDE TEMP. IN HEAT THE LARGE COPPER LINE BECOMES HIGH SIDE HOT WHEN YOU FEEL IT. IF YOUR FREON IS LOW WILL WILL ALSO GET SHUTDOWN. YOU WILL NEED SET OF FREON GAGES AND CONTACT ME BACK
Apr 23, 2010 | Heating & Cooling
Does not heat or cool
Hi, If the outdoor unit is running, make sure the fan is on also. If the system is new and has just been installed, it sounds like you may have a freon leak and have lost all its freon. Turn it on cool and let it run for a few minutes. Go outside and grab hold of the larger copper line coming out of the unit. It should be nice and cold and sweating. If not, and the fan and compressor are up and running, you have a leak and lost its charge. Check this and get back to me and let me know what you have found. We can go from there.
Shastalaker7
PS, When these installers put these units in, they sometimes get in a hurry and there welds are not very good and will leak over time, just to let you know.
Jan 26, 2010 | AmcorAire UCHW-H12AF2 Split System Air...
Not running; msg18 mini split , defrost board blinking 5 times.
check freon to low or to high. must be charged liquid 410 tank upside down.
Dec 14, 2009 | Heating & Cooling
I have a Toyo Aircon TA 12C(H)S air conditioner that shows E3 on the readout and nothing will come on. Any ideas what the error codes mean?
TOYO mini split air conditioner made in Japan is very very good quality and it can runs for 20 years without any problem. E3 means low pressure of refrigerant. You didn't hire a best ac technician to install your TOYO unit. The tubing connection between indoor unit and outdoor unit is not the right torque and refrigerant leak. Your TOYO unit runs out of refrigerant. You need fix the leak and fully charge the system. You will solve the problem. Good luck to you!
Jul 03, 2009 | Toyotomi TIN/TIG-329D Air Conditioner
Split ac not cooling
cak split in door unit 1st watar lavel and in sait watar tra blok paip.
Apr 07, 2009 | LG Heating & Cooling
Heating & Cooling Logo
296 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
