Question about Mitsubishi WT-46809 46" Rear Projection Television
Television problems TV automatically turns off right when I turn it on. I only have about 2 seconds before it turns off.
  • dsouders Jul 04, 2008
    I have a similar problem. When I turn on the TV, the green timer light comes on for about a second and then the power turns back off. The TV really never turns on.
  • 927 Answers
Good Day, T;
Check this out: This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR LEAKY C9A60 470 PF 1000 V PART # 154P400030, PARALLEL TO D9A57 ON THE POWER PCB (NOT SHOWN IN THE SCHEMATIC). 2. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR OPEN FUSES F9A04 AND F9A05 PART # 283P043090 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT. 3. SELF-DIAGNOSIS INDICATES SHORT PROTECT. CHECK FOR A SHORTED IC4B01 PART # 270P261020 (VERTICAL OUTPUT) LOADING 24-VOLT SUPPLY LINE. LOCATED ON THE MAIN PCB. Good luck, big IRISH, e me mmrkcar@yahoo.com for personal help, GOD bless.
Posted on Jul 15, 2008
Tv plays for a couple seconds, then automatically switches off
you have bad capacitors, if you dont know what those are, then I am sorry -its gonna cost you to fix
Jul 21, 2012 | Akai LCT3201TD 32 in. LCD Television
When i turn on the tv.. it turn on but in 2 seconds turn off automaticly...
You know that Pioneer had this problem not only in Flat screen but projections tvs too. It was always a loose connection problems in the projo's, and I am willing to bet it's the same in these. This is just my guess!
Jan 15, 2011 | Pioneer PDP-4360HD 43 in. Plasma...
The TV shut off automatically but the powerlight is blinking
Your power source seems to be the problem, replace the part (located inside the television) and the problem will be solved.
Jul 18, 2010 | Panasonic PT-47WX49 47" Rear Projection...
WS-65869 Turns off automatically after about 2 seconds
I have the same exact problem, did you guys got any help?
Jun 23, 2009 | Mitsubishi WS-55313 55" Rear Projection...
New TV 9 mos old, Won't stay on after power up? Remote or manual turn on, set keeps turning off after 1-2 second green on and brief screen flash.
I would try leaving the TV unplugged for 30mins so the TV can reset itself.
If that doesn't work, your TV should still be under warranty. I know 95% of come with a 1 year warranty.
The most common problem with Sylvania TVs made by FUNAI, the Backlight Inverter board fails to early in life. ( That's the part that powers the screen)
The Tv can't power up the screen and it turns off automatically. Basically called "Protection Mode" so it protects the other parts inside the TV.
Jun 01, 2009 | Sylvania LC320SS8 32 in. LCD Television
Automatically turns off
I have the same problem and had a samsung technician come to the house. It was the Power Board and the main board. He gave me an estimate to fix and it was $529. I'm trashing the TV. Samsung sucks.
May 17, 2009 | Samsung LN-S4041D 40 in. LCD HDTV
Turn on and stay on
It seems that Your TV set may have a problem with its power supply circuit, the problem is intermitent bring it to the repair shop.
Nov 06, 2008 | Televison & Video
Brief power on then shuts off
It could be a component short or crack on the power supply board. Open the back of the TV and look for signs of defect. The power supply board is the brown one on the right with huge capacitors.
Jul 12, 2008 | Panasonic PT-61HX41 61" Rear Projection...
Power turns off automatically
happened with my 2002 42" model. they say the convergence circuit.
Mar 10, 2007 | Mitsubishi VS-60707 60" Rear Projection...
Auto off
make checks in the standby power supply and related tey could be deffected if not make checks on eeprom and the microchip.good luck.
Jan 22, 2007 | Sanyo DS20930 20" TV
Mitsubishi WT-46809 46" Rear Projection Television Logo
102 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
