Question about Jl Audio 500/1 Car Audio Amplifier
JL Audio 500/1 amp
There is no sound at all, the only light coming on is the power light!
  • 631 Answers
I need the answers to the questions I posted to know the condition of the amplifier.
Posted on Jun 09, 2008
I have a jl 500/1 amp hooked up in my car and the power light comes on for about 5 seconds then turns off. no sound out of the subs. it is hooked up to a factory deck through a high to low level converter....
hook up the remote wire ( or make sure its hooked up good) check your ground! ground wire not big enough awg wire and put on bare metal not more than 1 foot away from amp. bad ground will cause this.
Sep 12, 2011 | Jl Audio 500/1 Car Audio Amplifier
My amp jl audio 500/1 i connect it and the green light turn on then i turn in the sterio and it sounds but when i turn off the sterio and when i wanna turn it on again the amp dont turn on i dont know why
Check the remote lead and see if it is getting power at the amp when it won't come on that way you know if the issue is with the head unit or the amplifier.
Mar 08, 2011 | Jl Audio 500/1 Car Audio Amplifier
My jl 500.1 amp dosent play anything.
you have your sub wired incorrectly. your amp shouldn't get hot unless you're settings are too high or your'e sending too small of an ohm load to the amp. this would cause it to heat up and will fry your amp.
May 30, 2010 | Jl Audio 500/1 Car Audio Amplifier
JL Amp isn't powering subs and speakers
silly as it sounds, you may want to check your EQ settings on your headunit. Things like sub volume, SLA, loudness and balance. When they replaced your battery, those old settings were lost.
Mar 26, 2010 | Jl Audio 500/1 Car Audio Amplifier
My Jl Audio 500/1, power light comes on but no power to subs
maybe it dont have enough to push it ,,did you try it before you buy it?
Mar 01, 2010 | Jl Audio 500/1 Car Audio Amplifier
JL Audio 500/1 Amp, The green power light is on but no sound!
Check to be sure you are on the correct outputs on the head unit, and be sure the outputs do not have a separate volume control.
Mar 06, 2009 | Jl Audio 500/1 Car Audio Amplifier
I HAVE A JL AUDIO MONOBLOCK AMP 250
It indicating that the power output is too loud and possibility of speakers may get damaged if played at this volume for long periods. When the loudest sound is played the led light mightshow its loosing its brightness and dims in time with the sound level.......................sodeep
Jan 17, 2009 | Jl Audio 500/1 Car Audio Amplifier
Jl 500/1
Nine times out of ten if the amp smells burnt it usuallly is. Your best bet is to hook another amp to your system and see if you get sound.
Jan 30, 2008 | Jl Audio 500/1 Car Audio Amplifier
Jl 500/1 no sound, green light
This is an indication that the MOSFETs are ok but the driver stages may have a problem. Get a schematic find the pre-amp stages and test the voltages levels there as compared to the schematic. I do believe that you will find the problem in the pre-driver pre-amp atages.
Sep 03, 2007 | Jl Audio 500/1 Car Audio Amplifier
is there any sound?
Aug 21, 2007 | Jl Audio 500/5 Car Audio Amplifier
Jl Audio 500/1 Car Audio Amplifier Logo
114 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
hoyzee1
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
