Question about Maytag M7DH65B2A Dehumidifier
Dehumidifier model M7DH65b 2A
Dehumidifier turns on,begins to freeze around coils and shuts down in about 5 minutes
Its too old where you are running the appliance - lift it up in the air or raise the heat in the room. This is *not* a low-temp dehumidifier.
Posted on Jun 22, 2008
Dehumidifier freezes up
Good Afternoon Friend,
I understand your Frigidaire dehumidifier, model# FDF50S, is freezing up. I see that the compressor does not shut off, causing ice to build up on the coils, rather than water draining off. What can cause this is your dehumidifier has been turned on recently. This is normal due to refrigerant rushing through the coil. Frost will usually disappear within 60 minutes. Another cause is if the room temperature is too low or too high. Your appliance is designed to operate between 41 degrees F and 96 degrees F. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 29, 2014 | Frigidaire FDF50S Dehumidifier
Tip
Dehumidifier is Freezing up and not working
If you are having problems with your dehumidifier freezing up them here are a few things that you can check and also a few things that may help you.
First check the ambient temperature of the room at the level of the dehumidifier. If it is below 65 degrees and you do not have a special low temperature dehumidifier then you are asking for trouble. Most units are only designed to work in temperature 65 or higher and will freeze if they are working at lower temperatures. Some even will not work well below 68 degrees F.
Many dehumidifiers will shut off when the coil starts to freeze to let them thaw, then they will restart when the coil is warm enough again. This can take an hour or so. Some will not shut down the compressor and when the dehumidifier coil starts to freeze it reduces the air flow and only compounds the problem.
Check the air flow over the coil. If the coil becomes dirty or the fan motor stops or even slows down a bit, you will get freezing. The dehumidifier is very dependent upon the proper amount of air going over the coil to keep the coil warm enough to not freeze. Any restriction will cause problems.
The final and worst thing that can happen is for your dehumidification unit is to develop a slight leak in the refrigeration system. This will cause the coils to run even colder then they would normally and this will create the same problems. If everything else check out then you may have to have the refrigeration system checked by a professional. The problem with this is that many of these units only cost a few hundred dollars and a service call can soon add up to more then the unit is worth.
Some things that you can do to help out a dehumidifier that is freezing up are:
Raise the temperature of the room and provide a bit of heat for the room as the dehumidifier is actually a very small A/C unit.
Raise the dehumidifier up off of the floor… the air is usually warmer when you go higher up in the room, hot air rises.
Clean the coils off so that the air can flow through them easier and keep them warmer.
Make sure that the fan motor bearings are oiled and that the fan is running freely. Even a tiny bit of resistance will slow the fan enough to make a difference.
By checking all these things out and making some small changes you maybe able to make your dehumidifier work much more effectively.
http://www.fixya.com/support/r3877515-dehumidifier_problems_dehumidifier
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
http://www.fixya.com/support/r4688381-dehumidifier_problem_shows_bucket_full
on Apr 30, 2010 | Dehumidifiers
Dehumidifier freezing up
Good Morning Friend,
I understand that your Frigidaire dehumidifier, model# FDL25P1, is freezing up. First, if your dehumidifier has been turned on recently. This is normal due to refrigerant rushing through the coil. Frost will usually disappear within 60 minutes. Secondly, make sure the room temperature is above 41 degrees Fahrenheit. If it is too cold in the room, the coils can freeze. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully.
-Best Regards-
WP
Jun 21, 2014 | Frigidaire FDL25P1 Dehumidifier
Why freezes up?
I understand that your Frigidaire dehumidifier, model# FAD504DUD, is freezing up. First, if your dehumidifier has been turned on recently, this is normal due to refrigerant rushing through the coil. Frost will usually disappear within 60 minutes. Secondly, make sure the room temperature is above 41 degrees Fahrenheit. If it is too cold in the room, the coils can freeze. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully.
-Best Regards-
WP
Jun 20, 2014 | Frigidaire Dehumidifier Fad504dud
I understand your Frigidaire dehumidifier, model# LAD704TDL, is freezing up. If you have turned on your dehumidifier recently, this is normal due to refrigerant rushing through the coil. Frost will usually disappear within 60 minutes. Try starting your dehumidifier on a slower fan setting. Another possibility is that the room temperature is too low or too high. Your appliance is designed to operate between 41 degrees F (5 degrees C), and 96 degrees F (35 degrees C). I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your air conditioner status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 13, 2014 | Frigidaire Dehumidifier LAD704TDL
I have a whirlpool dehumidifier (AD75UST0) and it appears to be 'dead'. is there a fuse or a reset?
No. I have had a AD75UST0 WHIRLPOOL Dehumidifier for several years. My unit slowly got less and less efficient, then it "stopped" coming on as if it was not working. Upon disassemble and inspection I found fan was no longer spinning. It tries to start then (actually the condenser coils begin to freeze, but no Fan) then it shuts down within 30 sec or so.
I am going to try a replacement Fan and fan start Capacitor (always replace in pairs).
Aug 19, 2011 | Whirlpool 75-Pint Dehumidifier
Goldstar Dehumidiflier coil freezes
Hi, If you are having problems with your dehumidifier freezing up them here are a few things that you can check and also a few things that may help you.
First check the ambient temperature of the room at the level of the dehumidifier. If it is below 65 degreesand you do not have a special low temperature dehumidifier then you are asking for trouble. Most units are only designed to work in temperature 65 or higher and will freeze if they are working at lower temperatures. Some even will not work well below 68 degrees F.
The final and worst thing that can happen is for your dehumidification unit is to develop a slight leak in therefrigeration system. This will cause the coils to run even colder then they would normally and this will create the same problems. If everything else check out then you may have to have the refrigeration system checked by a professional. The problem with this is that many of these units only cost a few hundred dollars and a service call can soon add up to more then the unit is worth.
By checking all these things out and making some small changes you maybe able to make yourdehumidifier work much more effectively.
Aug 11, 2010 | Goldstar DH504EL Dehumidifier
Danby Dehumidifier Model # DDR557HE Serial # 0107030704369 --Does not collect water and cxontinues to frost up
Take care
Mar 23, 2009 | Danby DDR586R Dehumidifier - 58 Pints...
Ice forming on the coils of my Crosley Conservator dehumidifier
Dehumidifiers2_bing.gif freezing up can be causes by a few different problems.
Here is a tip that I wrote to help people with the freezing dehumidifier2_bing.gif problem....
http://www.fixya.com/support/r4662033-dehumidifier_freezing_up_not_working
heatman101
Jan 09, 2009 | Frigidaire FDL25P1 Dehumidifier
Maytag M7DH65B2A Dehumidifier Logo
139 people viewed this question
Top Maytag Dehumidifiers Experts
Michael Van Der...
Michael Van Der...
Bill Long
Steve
Are you a Maytag Dehumidifier Expert? Answer questions, earn points and help others
