Question about Goodman GMS90703BXA Heater
Keeps blowing the fuse.
A/C is not working. Found a 3 Amp.fuse blown on a circuit board inside the blower section. I already went thru bunch of fuses.
Manufacturer: Goodman
Model # GMS90703BXA
It seems like a short circuit, but I don't know where to look. Any suggestions? Thank you.
  • Anonymous Jun 28, 2008
    FUSE BLOWS AFTER ABOUT AN HOUR OF RUN TIME . I'VE ALREADY CHECKED FOR SHORTS IN THE 24V WIRING . A/C BLOWER AND CONDENSER RUN FINE TILL FUSE BLOWS . REPLACED T-FORMER
  • Anonymous Mar 14, 2014
    Door Blower Switch was loose tried to push back in secure and it shorted. The fuse on the board did not blow will the switch prevent communication with the board?
    Novelist:
    Champion:
  • 230 Answers
In more rare scenarios the 24v activated fan relay that is soldered to the circuit board can cause this same problem. I agree with Therinnaiguy, If the fuse is blown 90+% of the time there is a short in the 24 volt control system.
Posted on Jun 17, 2008
  • 1,420 Answers
Most likely it's near where the wires got weed wacked outside. Follow the wires from the indoor unit to the outdoor unit. Look for any damage along the way. Also follow any thermostat wires you can find and inspect them. Sometimes where they enter into both the inside and outside units they frey on the metal casing. I hope you find something. Otherwise, you may have a bad transformer sending the wrong voltage to components.
Posted on Jun 10, 2008
Fisher and paykel keeps blowing fuses, code 37, I have replaced the pump already
Yes the original bad pump has damaged the drain pump circuit on the control board.
Dec 20, 2016 | Fisher and Paykel Washing Machines
Amp fuse 30a keep blowing
You have possibly melted a couple of wires together along the radio circuit. Also the radio unit itself has 1 or more protection fuses actually inside the unit that have blown, usually at back of unit in little bay near the wire clusters.
Check your relays too, a blow out through jump starting can do all sorts of little burn-outs.
Oct 15, 2016 | 2006 Lexus Rx 330
Wy fuse keeps blowing
Fuses blown when an overload occurs. More often than not caused by a short circuited transistor in the main amp section. Possibly also on the power supply too.
May 22, 2014 | AMC Multimedia CVT-2030 2-Channel...
AC isn't working
when a fuse keeps blowing it can only be one of two causes. either the consumer is loading the circuit too much due to a bearing problem or rusty component, or there could be a short circuit to ground. disconnect the blower motor plug connector and turn your a/c on like normal. if it blows the fuse again, replace the blower fan motor. if not, start checking the wiring for any exposed copper that might touch the ground-negative.also inspect all the plug connectors for water damage and corrosion.
Jul 08, 2013 | 1997 Toyota Avalon
1993 Buick Roadmaster keeps on blowing fuel pump/ecm in-line 20 amp fuse. Car stalled out in a parking lot, would not start, no fuel. Changed fuel pump, fuel filter, fuel pump relay. Found fuel pump/ecm...
Sorry to say it could also be a faulty ECM. The ecm uses circuit boards to provide grounds to a bunch of components and can short out internally.
Most of those components can fail and cause the same problem by causing a short "thru" the ECM. Things like injectors, O2 sensors, and so on.
I doubt you will find the problem without a book and some test equipment.
Jun 29, 2012 | Cars & Trucks
I have a duo therm model 57915531. i have checked the breakers all the fuses and the thermostat. i have found a 3 amp fuse in the control panel of the roof unit. this fuse was blown. i replaced it and it...
That unit has a thermostat I believe and 12 or 24 volts to power it. The 3 amps tells me it may be either line or low voltage, see manual. the fuse blows due to a short in the control circuit, a transformer if low voltage.
Sep 10, 2011 | Dometic Rooftop RV Air Conditioner
I have a Trane model TWE030P13FBO that keeps blowing the 5 amp fuse tied into the transformer. Just to see if I could solve the problem I put in a 10 amp fuse and the transformer smoked and I'm sure now...
You have a short in the low voltage...it could be the t-stat or the wiring to the t-stat...also could be the coil if a contactor, or a wire rubbed through somewhere...
To find it you need to start to isolate sections of the low voltage circuit and then ohm out each section...problem is that some will still not show up with out power applied... believe me this is not fun and can make ya pull your hair out...be patient and persistent...
but as you found out do not try a higher amp fuse...transformers work on smoke...and when the smoke comes out they no longer work... :-)
heatman101
Sep 15, 2010 | Heating & Cooling
The circuit board has a 25 Amp slow blow fuse is blown
if your circuit board has a 25 amp fuse that a lot of power, like running the compressor.. you need to have a model and serial number for the unit , there is no generic control board , each manufacture has it's own design
Nov 15, 2009 | Refrigerators
My blower blew a 3 amp fuse..i replaced it....the blower is running...but the ac wont kick back on
why did fuse blow thats what i would figure out? check for power at compressor it maybe locked up(you haft to reverse polarity to unlock)!! :)
Jul 05, 2009 | Heating & Cooling
Goodman GMS90703BXA Heater Logo
316 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
