Excessive vibration during spin cycle
I have an Asko 20605 washer that frequently vibrates during the final spin and makes the water supply pipes rattle in the basement. It does not do this every time, but most of the time. Sometimes if I stop it, open the door and start it again, it will spin correctly. Any idea what might be causing this?
  • ratmandue Oct 31, 2008
    Pipes in basement make a lot of noise like there is air in pipes. Only happens some of the time. Very loud
I have a kenmore front loader. It also vibrates during the final spin. I wonder if needs to be ballance. Specially, since I did not secure it very well during our last move.
Posted on Jun 15, 2009
  • 868 Answers
If this is the only problem be thankful ,its capable of a future of problems. I my self would not recommend putting 1 more dollar into this machine.Your next concern is a high dollar repair that may be soon coming ,that is a circuit board problem.
Please rate this !!
Posted on Jun 09, 2008
Plz check for the ground level is equal.weather its normal means u have to check the shock obsorber
Jun 06, 2010 | Maytag PAV2300 Top Load Washer
LG WM0642H washer "excessive" vibration
sounds like damper rods are getting worn. they support bowl underneath.i think if u change them it should fix problem. is it noisy during spin?if u need more help please reply. please turn power off b4 working on it do not want any accidents.
Apr 08, 2010 | LG WM0642H Front Load
Asko 20605 washer stopped mid-cycle, now no power?!
The ECU should be tested. Look for the service manual inside the chassis for troubleshooting procedures.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 04, 2010 | Asko Washing Machines
Clothes washer vibration during spin cycles
the vibration and noise is most likely from the drum bearings wearing out to test the bearings try this out,,,
open the door, hold the top of the drum and lift it up, if it has any free lift in it the bearings are going, now spin the drum by hand and you should here the rumble off the bearings
Dec 29, 2009 | GE WPXH214A Front Load Washer
Vibrates during spin cycle
front loaders are made to sit on concrete they probably didnt tell you when you purchased it if its on wood floor not much you can do
Jul 05, 2009 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Chck to see that all (6) suspension springs are still attached. Check the plastic snubber ring below the mechanism and above the base plate for cracks or contamination.
Mar 07, 2009 | Maytag Performa PAV2200
Washer drum shakes excessively during fast spin
y shaped piece that contains the spindle that attatches to the basket and allows it to spin is corroded and cracking. you can't buy just the spindle bracket, you must buy the basket too. you'll be buying the front part of the drum too, if you wait to long.
Feb 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Roper RAX7244EQ1 Vibrates during spin cycle
Dear customer
Please perform the following checks
This may be a spin problem or a drain problem
Drain:
  • Make sure the drain line is clear
  • Check the drain hose for a partial blockage
  • Inspect the water pump
Spin:
  • Test the lid switch
  • Test the timer control
  • Test the centrifugal switch
  • Test the water level switch
  • Inspect the motor coupler
  • Inspect the drive belt (belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
Please rate this,Thank u
Nov 21, 2008 | Roper RAS8445KQ Top Load Washer
20605 Washer - portal door hinge is loose - so door vibrates and bangs loudly in the spin cycle... literally tearing itself apart. Where can I get the replacement hinge parts, including the clips, and how...
its a big job the door comes as a kit,you have to losen the front panel that the door sits on thers two bolts on the back of the front panel you get access from inside take off the back panel use 60 cm extension then remove door seal and ring the screws for the door are behind the hinge you will have to move the front panel forward and stick screw driver handel between so you can get access,but the kit does have instuctions.it will take about 1 hour or so.hopethis helps. model 20605 is an asko
Mar 26, 2008 | Washing Machines
sure..start by re leveling the unit, with a standard carpenters level.
Mar 02, 2008 | Maytag Atlantis MAV5000
Washing Machines Logo
349 people viewed this question
Top Washing Machines Experts
