Question about DeLonghi DE500 Dehumidifier
Delonghi D500P Unfortunately, it has been, for the last 24 hours, in a bathroom where the stool overflowed and saoked the carpet/.
Can it be used in toilet ? The walls are damp due to basement
It can be used in a bathroom in a safe place. It might taut of the bowel and drain traps but should not take any water out of the tank an air conditioner is a big humidifier so if you have an A/C you already have some moister being taken out. And a heating unit takes even more out then the A/C so I would say no problem.
Aug 28, 2014 | DeLonghi Dehumidifiers
Delonghi dehumidifier overflows
these humidifiers are total junk. The sensors are cheap and get stuck or broken so easily. for your problem tho, you can either find the sensor by taking off the cover and use your hands to break free any stuff causing it to get stuck or you can drill a hole in the water tank and insert some fish tank tubing and let the water drain out as it collects.
Mar 02, 2013 | DeLonghi DE500 Dehumidifier
We lost our manual for ours and my husband cant remember the settings is there a place where i can read the settings or a manual i can download?
Unfortunately, Delonghi, for whatever reason, does not post the Owner's Manuals for their Dehumidifiers online. However, if you call Delonghi Customer Support 800-322-3848 they can furnish one to you. Probably by email attachment.
Hope this helped you. Please let me know. Thanks.
Jun 13, 2011 | DeLonghi Dehumidifiers
Need an Operation Manual for Delonghi DN125 Dehumidifier
Unfortunately, Delongi doesn't list an Owner's/Operational Manual for your model dehumidifier. However, you can contact their Customer Support Dept at 800-322-3848. They can email you an Owners Manual. Be sure you have the correct model number for your unit, before calling.
Jun 01, 2011 | DeLonghi DN 125 Dehumidifier
Dehumidifier is running but very little moisture is accumulating in the tank our carpet is soaked so it should be removing more moisture than it is.
In the is a wall to wall carpet, it's going to take a while. If you have a wet/dry shop vac, you can speed up the process by using the shop vac in wet mode. This will remove a great deal of water and then the dehumidifier will take care of the rest. Remember, it it's wall to wall carpet, the pad underneath is soaked too. So the dehumidifier alone, will really be struggling with it for at least 24 hours.
If it's and area rug, vacuum it to. Then drape it up off the floor over a couple of saw horses or wooden chairs, so the the dehumidifier will fit under one end like a tent. That will dry it out with in 4 or 5 hours.
Last solution, borrow another dehumidifier from a friend and run both at the same time.
Hope this helps you solve your soggy problem.
Mar 12, 2011 | Goldstar DH504EL Dehumidifier
DEM 10 Delonghi Dehumidifier has Stopped collecting water but still seams to be working
First, make sure the humidistat isn't set too high by adjusting it to the lowest humidity setting and running it again. Next, test the dehumidifier by placing it in a closed bathroom with a hot shower running. If you don't see water collecting in the unit after several minutes, turn the unit off and clean all dehumidifier filters and coils. If, after adjusting the settings and cleaning the unit, you still don't see water collecting, you may have a refrigeration issue. This situation will have to be addressed by a qualified technician.
Take care.
Aug 14, 2010 | DeLonghi Dehumidifiers
I have Delonghi DE500P dehumidifier was running but doesn't pump water. how can i fix it.
Good luck
Aug 11, 2010 | DeLonghi DE500P Dehumidifier
When tank is full, it doesn't shut off, and tank overflows
yes jenn when the tank fills it will shut off so that it dosent run all over the floor on many models you can hook a hose on to the tank and find a place to drain itto like a floor drain etc
Apr 09, 2010 | DeLonghi DE500P Dehumidifier
Need a part
This appliance has 3-ft drainage hose and a 16-ft pump hose. I searched for a store that carry these hose, unfortunately, none of them sell a part or accessory for the DE500P.
Kindly click this link and verify if they could sell a hose:
http://www.nextag.com/delonghi-de500p/compare-html
Good luck.
May 03, 2009 | DeLonghi DE500P Dehumidifier
DeLonghi DE500 Dehumidifier Logo
145 people viewed this question
Top DeLonghi Dehumidifiers Experts
Mike Kolbay
Level 1 Expert
Are you a DeLonghi Dehumidifier Expert? Answer questions, earn points and help others
