Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
Connection dropping My router keeps dropping the connection every few minutes both wireless and wired connections, the LED lights on my belkin g+ MIMO router are all flashing except the power button, it is really confusing me.. my modem is a cable modem and i have checked all ethernet cables and replaced them many times and the problem is still going.
  • SNYPA8064 Nov 05, 2008
    The same thing happens to me, the only difference is I have a Belkin wireless N MIMO router but I have the slipstream 4100 modem. I have not yet solved this problem.
    Problem Solver:
  • 9 Answers
If the lights are flashing - that's OK. Wireless light will flash because the connections and beacon transmission, port lights will flash because of local connections. We can troubleshoot this for a while but I think this might be a problem with the box. Probably the best option is to replace it. In case you would like to play, try to run Ethereal and capture the packets and analyse them.
Posted on Jun 10, 2008
How can i reset my Belkin Wireless G Plus MIMO Router it cannot connect for an internet connection
  • Locate the small master-reset pinhole on the back of the router. The pinhole is located directly to the right of the Ethernet port labeled "connection to modem."
  • 3
    Soft-reset the router by placing a sharp object, like a push pin, into the router hole. Push inward and immediately release the button. The lights on the router will flash and then the "Power/Ready" light will start to blink. When the light turns solid, the router is reset and ready to use. This reset does not restore the router to factory settings. It refreshes the software and is similar to rebooting a computer. If you want to restore the router to the factory settings, skip this step and move to step four.
  • 4
    Master-reset the router by placing a sharp object, like a pushpin into the router hole. Keep the pin pushed into the hole for 10 seconds. The lights on the router will flash and then the power/ready light will start to blink. When the light turns solid, the router is reset and ready to use.
    Read more: How to Reset a Belkin Wireless G Plus MIMO Router ' eHow.com http://www.ehow.com/how_6759000_reset-wireless-plus-mimo-router.html#ixzz16uTbPLCW
  • Dec 01, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
    Have wireless G plus MIMO router and lapto using a
    Please enter to the router page and decrese the chanel. make it to 6 or 11
    May 01, 2010 | Belkin (F5D6230-3) Wireless Router
    Belkin Wireless G Plus MIMO router - connectivity problem
    • this problem can be ISP releted they may have some issues on the ADSL line connection
    Aug 10, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
    Line-drop problems on Belkin G PLUS MIMO Router F5D2304
    firemware update can fix this issue if it is an issue with rtr .... try connecting a comp to modem and observe connection first if it is fine then update firmware it should work
    Jun 19, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
    No wireless connection
    You need to have an Internet Service Provider. You connect the router to a modem from the cable Service Provider or through the phone line for BT. Then you can connect wired or wirelessly to internet through the router.
    If you describe your set up in detail and tell me the Internet Service Provider I may be able to help more....
    Jan 06, 2009 | Belkin Wireless-G Plus MIMO Router with...
    Internet connection
    try to update the router's firmware to the latest one, if conection is still dropping try lowering the MTU size(by default its set to auto) to 1492, 1480, 1472, 1450 check which MTU size will make you connection stable.
    Aug 05, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
    Dropping Connection
    All the LED except power should be flashing, that indicates traffic flow, power should be steady.
    If all wired and wireless connections fail it is unlikely the router, more likely the cable/adsl modem that is dropping connection. Test by connecting a pc directly to the cable modem, watch for dropouts. If fails, contact your ISP service dept for line check and do a cable speed check from an online source.
    Check also terms of service for the package you bought, many low end services restrict speeds below dialup if you go over your transfer limit. Multiple pcs playing online games use a lot of bandwidth. the speed restriction may put you below the threshhold for game server
    Jun 08, 2008 | Belkin (F5D5231-4) Router
    Router connection problem
    yes I tried with laptop, psp its not working
    May 14, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
    Router
    Is your xbox connected wirelessly to your router?
    May 08, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
    Belkin Mimo Router
    If you're connected to the router with excellent stregth then the problem most likly lies in the routers connection to the internet. Check your DSL, Cable modem and make sure the connection to the "Internet" port on your router is good. Try switching out the Ethernet cable if nessciary.
    Feb 22, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
    Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
    282 people viewed this question
    Top Belkin Computers & Internet Experts
    Prashant M
    Prashant M
    Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
