Question about Garmin StreetPilot c340 GPS Receiver
C340 Just got a c340....says it's trying to locate a satellite. I'm living in Pittsburgh
  • janetwood Aug 08, 2008
    My Garmin C340 worked fine for about one year and then it started saying "Acquiring Satellite" showing the wrong location where I am located. When I first turn on the unit it shows a Map Updater Notice. I have heard that sometimes if you update the map then this fixes the problem of not acquiring a satellite. Is this true or is the unit broken and I would be wasting $70.00 purchasing an updated version of the map.
    Thank you.
  • benzi646 Aug 31, 2008
    The unit is trying to locate satellites but can't even when not in motion with clear view of skies. It shows the wrong location which was the location when the problem occurred. It can try to locate satellites even for one hour but never does. It happened after one year that the unit was working fine. I am not sure if updating the maps which cost $70.00 would help. It cost $120.00 to buy a new one on E Bay.
Make sure you are outside with a clear view of the sky. It will lock faster if you are not moving.
Posted on Jul 28, 2008
Garmin c340 loses the satellite very frequently. Battery?
1. make sure the unit is as low un the windshield as possible, remember it needs to see the sky, the more sky it can see the more sat it can lock in on.
2. Check the GPS Mode, under tools(Wrench), select system, the GPS mode, make sure it is in the normal setting. WAAS is more accurate, but most of the sats are at the equator, so in some areas the coverage is not as good.
Hope this helps.
Apr 17, 2009 | Garmin StreetPilot c340 GPS Receiver
Searching for satellite
First, be sure you are outside, in the open when making this diagnosis. Some cars have metallic defrosting layers, which blocks the GPS signal. Also, first fix when new may take several minutes (5-10 minutes).
If, when outside in clear view, you still have problems, try this...
Have you tried a hardware RESET? The button is hidden behind the front panel, which snaps off by a fingernail slot located directly under the GARMIN logo on the front panel.
* Use caution removing and reinstalling the front panel... it's somewhat fragile... wiggle it a little to get it off.
Press where it says "Press to Reset", hold for a second or two. Charge the unit with the car cord or USB cable, then try to turn it on again.
Once you can get the unit to (hopefully) turn ON, you should run all updates (there may be several!) using Garmin's Webupdater. (Connect to computer with USB cable first.)
Hope this helps!!
Jun 09, 2008 | Garmin StreetPilot c340 GPS Receiver
Garmin StreetPilot c340 GPS Receiver Logo
80 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
