Question about Sony KP-57WS500 57" Rear Projection Television
Started with green arch lines on the screen
Now the problem has gotten worse. The green tint on the tv screen starts to fade light then dark in color. Then the whole screen turns green in color. After that the tv power's off and the light flashes eight times. I was wondering where I should go from here. My tv is 5 1/2 yrs old. Any help would be appreciated.
  • Brett Hawk Jun 09, 2008
    Goldflack, My tv's model number is a Sony KP57WS500.
    Thanks
    President:
  • 2,712 Answers
If your TV is a CRT type, then most likley the CRT guns need replacing. If an LCd, then the convergence modules will have to be replaced. it is also possible that you may have a couple faulty resistor/s and/or capacitor/s.
My advice would be to seek the assistance of a TV repairman, as this is not very simple to do if you have no prior experience. Also, it is very difficult to say what exactly is wrong without doing a manual inspection.
Posted on Jun 09, 2008
  • 1 more comment
  • Swilin Sampson
    Swilin Sampson Jun 09, 2008
    OK, you have a CRT TV..
    Your problem here has to do with the amount of aging that happens to the three colour tubes - red, green and blue. There is a way to adjust this by removing the speaker grill assembly in front of the set.
    On the left hand side behind the speaker cover you will see a black square block with six adjustment points. Look for the one marked SCR GREEN. Switch the set to a unused input. Now adjust the GREEN point counter both clockwise and anti-clockwise. A small adjustment should do it, Switch back to a picture and make sure the whites are still white.
    If that doesnt work, then you will have to replace the three CRT tubes. This should sort your problem. I would however suggest asking a Sony service center
    to do this for you, if you have no prior experience. This is a dangerous thing to do as you will be
    working close to the 35KV supply the the anodes of the three tubes. There are voltages inside that can KILL, even when the TV is unplugged.
  • Swilin Sampson
    I must warn yoou that repair does not come cheap..somewhere in the $400-500 range. If your TV is under warranty, then great! Simply contact your point of purchase.
    If not, you will have to decide whether a repair is worth it, or if you'd like to go in for a new TV.
    Hope that helps! If the solution I provided helps you in any way, kindly take a moment to "Accept" my solution..
    Thanks in advance :)
    IrishDruid
  • Swilin Sampson
    Swilin Sampson Jun 10, 2008
    THIS article may help you in reaching the SCR GREEN and dismantling the frille, if you wish to attempt it..
    http://www.somelifeblog.com/2007/06/sony...
    Sergeant:
    Champion:
  • 310 Answers
Can u tell me the model no of ur tv
  • khader ibrahim Jun 10, 2008
    problem in CRT gun...Remove cover of ur TV and then do this...
    When focused in on the controls, you want to
    concentrate on the bottom row for the voltage / ray gun projection
    adjustment. The colors are labeled below and from left to right are
    blue, green, and red. Choose the one that needs to be adjusted and turn
    ever so slightly with your Philips screwdriver to remove the lines. In
    my case, the red just needed to be turned 1/8 of a rotation to be back
    in adjustment. Do not turn to quickly or abruptly or you could possibly
    damage your TV by varying the voltage too quickly.
    try it if its not solve means u want to change the gun.....
Picture is very blue, especially in dark scenes.
Sony TVs has an Optical Block issue. If there is an issue with the optical block, then there will be green, blue patches or tint on the TV display. Try resetting the TV to the factory settings and try Power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue still persists, then TV may require service. You can contact the Customer relations team and check for the available options. Sony had repaired free of cost for such issues. Hence, contact the customer relations.
Jul 21, 2010 | Sony KP-57WV700 57" Rear Projection HDTV
Distortion, blinking, dark screen - now nothing
at the horizontal deflection yoke! maybe you have defective flyback! or horizontal yoke!
Sep 20, 2007 | Mitsubishi WS-55807 TV
Dark picture
Hmm my dad's old t.v. just cut out on him it took awile to turn on this my be the end of ur tv so this might be a power problem but older t.v. loose there colour on the screen my uncle had a like 10-15 year old t.v the screen was like green when it was light but when u turned of the light or closed the blind's it's picture was ok so try that.
Feb 02, 2010 | Hitachi 53FDX01B 53" Rear Projection...
Arched lines in dark screens whether it's Cable or DVD playing Model number: KP-57WV600 Sony 57inch rear projection TV
Ur convergence it dead.Do u know how to solders? Tries these websites. Tv repair World.com or Tvrepairkits.com have it.Buy a convergence kit used what in that kit ur tv well get back to normal.The shop will cost u $300 for parts and labors.
Jan 01, 2010 | Sony KP-57WV600 57" Rear Projection...
Colors arched and overlapping
if the option for convergence is still listed under the setting section of the on screen menu, then you need a convergence power supply board. If the convergence option is missing from the menu you need the ITC222 convergence missing repair kit. You can get either one at the following link they include instructions for the repair.
http://www.tvrepairworld.com/
Jul 13, 2009 | RCA R52WM24 52" HDTV Projection Television
Sony KV-36FV27 too dark, pink or green tint, 5 blink error,
Fuzzy,blury picture in CRT tv tube.Tv in long use not repairable.Tv tube is dying,it junk.
Mar 27, 2009 | Sony FD Trinitron WEGA KV-36FV27 36" TV
Green lines? Greenish tint to black colors on tv
ohh noooo call a good repair man...
tap on the green crt and check for liquid on the board
Feb 01, 2008 | RCA HD52W59 HDTV Projection Television
Sony KP-51WS500
does it have blue video image?
Sep 29, 2007 | Sony KP-51WS500 51" Rear Projection...
Dark and red picture
First you can up the screen voltage, by finding the HV transformer. It has Screen and Focus control on it this it the Transformer that is in back of set and has an anode lead going to Picture tube. Come up on the screen control slowly and if the picture brightens with vertical lines then it's too high, The red problem is a small transistor that maybe located on the CRT board. It's probably shorted. There are about 3, each going to the different colors Red, Blue, Green.
Sep 13, 2007 | RCA F35317 35" TV
Sony KP-57WV600 rear projection
sounds like bad CRT, some of these sonys have had defective CRT issues, usually all will come and go sooner or later (all 3 bad), you can pull the speaker grill off(either 2 1/4" screws on bottom or 6 1/4" on back sides) and pull off the Crt box cover (2'X3' piece) and lightly tap the CRT's with tv on, if they flare or get colored streaks in pix they are bad, CALL SONY 800 # and complain, also could adjust G2 (Screen control for color) for short patch. Will need new crts.
Jul 31, 2007 | Sony KP-57WV600 57" Rear Projection...
Sony KP-57WS500 57" Rear Projection Television Logo
66 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
