Question about RIM BlackBerry Pearl 8100
Can't make calls from phone
I can make calls from my car using my the bluetooth in my car but when I try ot make a call from my phone I get a message saying I can only make emergency calls.
  • Anonymous Aug 28, 2008
    i have a samsung phone I tried to use my phone this morning and the "Emergency calls only" message appeared? I have not adjusted any settings on the phone and the other user on the att acount is not having any problems. Please advise.
  • Anonymous Dec 30, 2008
    my blackberry cannot get off sos whan i need it to be on edge
  • 30 Answers
Have you checked to see if you have fixed dialing on, as this can prevent you from making phone calls.
Posted on Jun 16, 2008
I have an LG Splendor and it wont let me delete voicemail messages! Option 7 will normally delete messages but its stopped working! When i press 7 it is just hanging up the call! Ugh
Try using your phone's dialpad while not in a call to see if all the buttons and numbers respond. If they do not, then there may be an issue with the touch digitizer on your phone, and it will need replaced or repaired.
A unique workaround may be to purchase a bluetooth keyboard and pair it with your phone and press the numbers on the bluetooth keyboard instead of on your phone screen.
Jul 19, 2014 | Cell Phones
Can't receive file from my laptop
Dont use the bluetooth at all, you should have got a usb cable with the Samsung phone so use that instead it's much easier.
You may have to go into the settings menu on the phone then phone settings, then usb settings and set it to mass storage device then it will show up as a drive in my computer, from there you can drag and drop files easily and way faster............
or
Install the Bluetooth Driver -> http://consumersupport.lenovo.com/ot/en/...
If your not using Windows 7 Put the OS And Driver in here -> http://consumersupport.lenovo.com/ot/en/.....
thanks.
Apr 27, 2011 | Samsung Smooth SCH-u350 Cell Phone
Can't pair Samsung C3053 with Motorola bluetooth. I have followed the directions to use the Bluetooth messenger (whatever that is) and have gone to (in order) Menu, Settings, Messages, Bluetooth...
any one of the cell might have newer ver of bluetooth whicdh other 1 cannot recongonise.... try some other bluetooth headsets of own brand
Apr 10, 2010 | Cell Phones
My RAZR V3 won't pair with 2009 Chevrolet Silverado bluetooth
http://www.gm.com/vc/bluetooth/index.jsp?brand=chevrolet&landing=true
PAIRING A PHONE WITH YOUR 2009 Silverado
Before you begin:
To take advantage of the Bluetooth for Chevrolet functionality, you must first pair a Bluetooth-enabled phone to a Bluetooth-enabled vehicle.
Note: If you do not pair a Bluetooth-enabled phone, all calls will be made using OnStar® Hands-Free Calling.3
Some additional tips:
1. You can pair up to five phones with your 2009 Silverado.
2. Your system automatically recognizes the first phone you pair. To use a different paired phone, you must
select it using the "Change Phone" command.
3. Only one paired cell phone can be connected to your system at a time.
4. When the vehicle is in motion, you cannot pair a phone.
5. Pairing should only need to be completed once (unless changes to the pairing information have been made, or the
phone is deleted).
PAIR YOUR PHONE
Set up phone - Turn Bluetooth 'ON':
1. From the main screen, select "Menu"
2. Select "Settings & Tools"
3. Select "Connections"
4. Select "Bluetooth"
5. Select "Setup"
6. Select "Power"
7. Select "On"
Set up vehicle - Enter 'Pairing' mode:
1. Press and hold the Push to Talk button for two seconds
2. Your system will respond with a "Ready" message followed by
a tone
3. Clearly say "Bluetooth"
4. Your system will respond with a "Bluetooth ready" message
followed by a tone
5. Clearly say "Pair"
6. Your system will respond with instructions and a four-digit
Personal Identification Number (PIN); you will need to enter
this PIN on your phone
Begin the pairing process on your phone:
5. Select "Hands free"
6. Select "Look For Devices"
7. Select "General Motors"
8. Select "Yes" to bond with General Motors
9. Enter the PIN code provided by the vehicle
10. Select "OK"
Finish the pairing process in your vehicle:
1. The system will prompt you to give a name to your phone
2. Say a name that best describes your phone (example: Corey's
phone); this name will be used to indicate which phone is
connected
3. Your system will ask you to confirm your name
4. If you confirm that name, the system will respond with the
message: "'<Phone name>' has been successfully paired"
Sep 04, 2009 | Motorola Mobility RAZR V3c Cellular Phone
Recieving an invaild pointer address message when
try looking for bluetooth and make sure your phone is compatible with it
Jul 19, 2009 | Adapters.com Bluetooth USB Adapater, USB...
Sending bluetooth message
ur phone or mem card contain virus.. the easiest way to recover this is first put ur mem card in card reader and format it seperatly. then format ur phone seperately. there are two ways of 6600 formating !. use the coad (*#7370#) if u know ur security code. 2. if u forgot ur cade then switch off ur phone press #, 3, and dial call button at the same time and holding these buttons press switch on button n hold it. note::: hold these four buttons uptil formating doesnt start.
then insert ur formated memory card in the phone (100% working) i tried it.
WARNING format will cause deletion of ur cont nos , messages , images, softwares, videos, and all other data.
May 27, 2009 | Nokia 6600
I can't receive and send a message by using pc suite
hello there!! thanks for using Fixya.com!
I guess these requirements will help you...
Requirements
To send and receive SMS messages via a mobile phone using a Windows PC, you need:
  • a mobile phone that can be connected to your PC (some mobile phones do not have an interface for connecting to a PC)
  • a Windows program that can control the mobile phone to send and receive SMS messages
Today, most mobile phones support at least one of the following options to connect to a PC:
  • Via infrared (IrDA)
  • Via Bluetooth
  • Via a USB cable
  • Via a serial cable
The infrared and Bluetooth option should be very useful to many notebook computer users since nowadays many notebook computers have built-in infrared or Bluetooth support.
The Windows program for sending and receiving SMS messages is provided by some mobile phone manufacturers. For example, Nokia offers a software package called Nokia PC Suite to their mobile phone users. It can be downloaded free of charge from Nokia's web site. Microsoft has also released a free program called SMS Sender that enables Windows users to send SMS messages via a GSM mobile phone from a PC.
In the following sections, we will explain how to use Microsoft SMS Sender to send SMS messages on your Windows PC.
Hope this will help you..have a nice day! Or try to reinstall the CD (pc suite) on your laptop or pc, this will make it very helpful as well.
Feb 15, 2009 | Nokia N72 Cellular Phone
BLUE TOOTH
The name of your bluetooth headset is the OmniTech (OT-020C).
This will be slightly difficult to explain without knowing the model of phone... First off, you need to ensure that you are using a bluetooth enabled phone. You will need to enter the settings and tools menu. From within that menu, you need to find either "connections" or "bluetooth" and select. Make sure bluetooth is enabled. There will be an option to add a new device.
On your bluetooth headset, hold down the power button down until the power light stays lit. This may take 5 seconds or more. Now your bluetooth is in pairing mode.
Back to the phone, you want to hit "add new device". On certain models of phone you additionally have to select "search for devices". Your phone will recognize any headsets in pairing mode. When it is finished scanning, allow the phone to add your headset. It will ask you for the device pin code. This pin code will be 0000.
I hope this answered all of your concerns. If you are having trouble with finding the correct settings from within your phone, reply with your phone model and I can give you more detailed information!
Jan 20, 2008 | Motorola Mobility RAZR V3
RIM BlackBerry  Pearl  8100 Logo
324 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
David
Martin Murray
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
