1999 Chevrolet Lumina Logo
Posted on Oct 27, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I reset the change oil soon message in my 1998 Chevy Lumina after changing the oil?
Johnny Brown
Level 3:
  • Chevrolet Master 5,763 Answers
  • Posted on Oct 27, 2010
Johnny    Brown
Chevrolet Master
Level 3:
Answers
5763
Questions
0
Helped
3161261
Points
20432
This is done by turning the key on engine off and fully pressing the gas pedal to the floor sloowly three times within 5 seconds, the light will blink and go off then turn the key off for 3 sec and start engine, light should be off if not repeat steps. hope this helps.
Anonymous
Level 3:
  • Master 335 Answers
Anonymous
Master
Level 3:
Answers
335
Questions
0
Helped
274680
Points
1135
Hello and welcome. here is the instructions for resetting the oil light!
To reset the engine oil life monitor:
  1. Turn the ignition to ON without starting the engine.
  2. Fully press and release the accelerator pedal three times within five seconds. • If the CHG OIL SOON indicator flashes two times, the system is reset. • If the CHG OIL SOON indicator comes on and stays on for five seconds, try to reset the system again.
Recently changed the oil for my 04 silverado, but the change engine oil warning will not go off, how do i correct this
After changing the oil and filter, reset the monitor by proceeding as follows:
Turn ignition On, but do not start engine.
Fully depress and release accelerator pedal three times within five seconds.
If CHANGE ENGINE OIL lamp flashes for five seconds, this indicates system has reset.
Start engine. OIL LIFE should change to 100%.
If CHANGE OIL SOON lamp lights again, repeat reset procedure.
2001-08 Silverado, w/Driver Information Center
Press MODE button until DIC (Driver Information Center) reads OIL LIFE LEFT/HOLD SET TO RESET.
Press and hold SET button until 100 percent is displayed. You will hear 3 chimes and CHANGE ENGINE OIL SOON message will go off.
Turn ignition Of
how to reset oil life on 2004 chevy silverado
4helpful
2answers
How to clear the change oil message in the information center on a 2004 Tahoe
GM OIL LIFE SYSTEM - RESETTING
Reset the oil life monitor when the oil has been changed, use the following procedure.
1. Turn the ignition key to the RUN position.
2. Fully push and release the accelerator pedal 3 times within 5 seconds.
3. If the Change Oil Soon light flashes, the system is resetting.
4. Start the vehicle.
5. The oil life will change to 100%.
6. If the Change Oil Soon light comes back on, the system has not reset. Repeat the procedure.
I have a 97 Chevy Lumina. It has 276,*** miles on it. I bought it used 4 months ago. It was running excellent then the service engine soon light, low coolant light, and change oil soon light started coming...
The fact that the oil was low would not be from the oil pump, but from wear in the engine. If it is not smoking when you start it or as you drive, you can probably keep it running by just keeping the oil level checked at each fuel fill-up. As for the car shutting off, you didn't say if the engine seized or got real hot. A low oil pressure problem should have triggered a warning light before the problem got to the point where you lost the engine.
If the car ran after you added the oil, you got lucky and need to always check it.
3helpful
How do i reset flashing low tire pressure,change oil soon after the problem is taken care of?
To reset the tire pressure message, first make sure all pressures are appropriate, then turn the ignition on with the engine off. Press and hold the GAGES button located on the left side of the steering column until TIRE PRESSURE appears in the display. Press and hold the RESET button for 5 seconds until TIRE PRESSURE RESET appears then release the RESET button.
To reset change oil soon message, press GAGES button until OIL LIFE displays. Press and hold RESET for 5 seconds.
2helpful
99 Lumina - had an oil change. change oil soon light is still on. Now engine light is coming on.
If the engine light is on, then I would have an OBD-II Scanner get the codes out of the computer to see what may be causing this error.
The change oil soon light should be reset after changing the oil.
2helpful
2answers
1998 Cheverolet Lumina, ''service engine soon'' and hard gear shift
I doubt the two problems are connected. I would try a new gas cap and see what happens since it runs fine. The service engine soon light won't reset on it's own right away.
3helpful
What type of oil does a 1998 chevy lumina take?
5w-30
about 5 quarts for an oil and filter change
1helpful
2answers
1997 Chevy Lumina won't shift past 2nd
Have transmission service, oil and filtr. .Anywhere but aamco. sounds like valve body os sticking. do it soon.
1helpful
2answers
Change oil light.
Turn the ignition to the "ON" position. with the engine NOT running. With the ignition in the "ON" position press the gas pedal down to the floor 3 times within 5 seconds. The light should flash twice. If it doesn't you need to try resetting it again.
Top Chevrolet Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Chevrolet Expert? Answer questions, earn points and help others
