Question about Tascam CD-RW4U CD Recorder
Cd rewritable player recorder tascam cdrw4u
The cds will not record or play back on the tascam cdrw4u recorder.
I have tried all kinds of is hooked up to a sound board maybe i have it hooked up wrong or something is not set right with the recorder.
Thank you for your help.
  • 1 more comment
  • Anonymous Mar 17, 2014
    tascam cd rw 750 records and finalizes but when you play back on other drives says the cd is blank
  • Anonymous Mar 29, 2014
    Rejects all cds
  • Anonymous Mar 31, 2014
    need to know how to keep track of minutes used while recording a cd from a cassette
I never had that problems. I have been using it over five years. Does it play commercially made CDs (the ones you bought at the store)? Panel shows track numbers and sound volume? Can you hear it by using a head set (phone volume control turned up? If so, now recording part, do you have input select correct (analog or digital)? Input cable(s) into right connector(s)? When you press "record" button, does it put into "pause" mode? Can you watch the incoming sound levels when it is on "pause" mode? Can you start the recording with remote's fader button or play/pause button on the machine? Good luck.
Posted on Jun 18, 2008
My tascam is starting to eject most cds I try to play. These are cds I have always been able to play plus new ones. I haven't had problem recording on it.
There are a number of things that can cause a CD not to read and then be rejected. It can be dirt accumulated on the lens, lack of correct spin up of the spindle motor- they often times need good oiling and then maybe the deck does not know the tray is in due to a faulty switch. The questions are does it focus, does it spin up to proper rate and will it read the TOC?
Oct 25, 2016 | Tascam Audio Players & Recorders
Tascam cd-rw750 - while recording from another CD player (using digital coax connection), machine records for some time and then just "jumps out of record mode" and goes back to the beginning like nothing...
1. First problem: "like nothing is recorded". IS something recorded or has it been left in Pause Mode so long (instead of Recording) that it just got impatient and time out?
2. Get yourself a couple of CD-RW Digital Audio discs to play with until you're past this learning curve/problem scenario. That way you can always erase them and start over without having to discard the disc.
3. Dropouts on playback. Are they repeatable - always at the same place, even on different CD players? If so, the data is bad on the disc. If not, the data is probably marginal.
4. If you have a DVD player, try to play the failed recordings in it. Some DVD players can play back unfinalized CDR's. You may be able to recover the data by copying it back to the CD Recorder from the DVD player. Just be advised that an unfinalized CD-RW may not have 'silence' following the last recorded track due to old data remaining from a previous session, so be ready to pause or stop the recorder when the last track finishes.
5. "Scratches near the outside of the CD". Were these NOT present prior to entering the CD Recorder? Do they seem to coincide with about where the recording may have failed?
6. 20 vs 19 tracks: Is this a constant problem or only when there is a failure during CD creation? If the latter, it would make sense as the last track in isn't technically completed.
Apr 09, 2010 | Tascam CD-RW750 CD Recorder
My cd recorder wont read blank cds help me please
Do as it asks, insert blank CD-Audio or CD-Music media.
Discs for recording
For recording, make sure to use special audio discs only.
These discs are marked with “Digital Audio” and the logos shown below.
There are two different types of audio discs for the use on this CD recorder:
– CD-Audio Recordable (CDR) discs
These discs can be recorded on once and
play in all standard CD players and CD
recorders, when they are finalized.
– CD-Audio ReWritable (CDRW) discs
These discs can be recorded on, erased and
re-recorded many times and play in CDRW
compatible CD players and CD recorders,
– All Philips CD players and CD recorders
with the sticker shown here are CDRW
To ensure proper working of the set we recommend the use of Philips audio CDR and audio CDRW discs only.
Note: Do not use a computer CDR or CDRW as recording will not work!
Go here and download the manual. You'll need it.
Mar 04, 2010 | Philips CDR602 CD Recorder
My teac dvd/cd player wont play some cds
Probably a codec problem on the notebook. rather than a drive problem. Try a 3rd party media player such as Real Player or Quicktime
Feb 15, 2009 | Teac CD-Rewritable W28E CD-RW Burner
How to record from a microphone to a CD
Are you plugging a mic (if so what type) directly into the Tascam, if so this will not work.
will offer solution when you provide details of mic. There are no dedicated mic inputs on the CC-222mkIII unit.
Oct 07, 2008 | Tascam CC-222mkIII CD Player / Recorder
DP-01FX/CD sound quality of CDs
Nothing really specific other than to make sure you are recording as close to 0 db as possible without going over. Your master fader also needs to be set at 0db or above as this effects the volume when mastering.
Commercial CDs use a lot of compression to attain volume levels which aren't attainable without it. You should however be able to reproduce onto CD the volume levels you are hearing on your Tascam without resorting to compression.
To troubleshoot, you might want to try exporting your master tracks as wav files onto your computer via usb and then listening to them there. If the volume is low there you aren't creating master tracks with good volume (see above: master fader level), if the tracks sound good as wavs on your PC, then burn them onto a cd from there. If that CD has proper volume then you may have some problem with your Tascam CD burner although I've never seen a situation where a burner actually caused low volume like this.
Best of luck.
Apr 21, 2008 | Tascam DP01 All-In-One Recording Package...
Uploading audio instumentals into the Tascam 2488 II
You can get to the quick start guide here.
There is quite a bit to learn to get to the proficient point with this unit. Most of it involves the operator learning the software
Feb 11, 2008 | Tascam 2488 Portastudio Multitrack...
Tascam CD-RW4U CD Recorder Logo
266 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
Michial Gueffroy
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
