Question about Frigidaire FWS833A Top Load Washer
Not spinning My washer is pumping out the water but when it gets to final spin, it won't spin. Also I smell a burning smell when it tries to spin.
  • hopey0128 Jul 15, 2008
    I am having the same problem with mine....I smelled something burning and found sopping wet clothes inside. when i turned it back on it was not spinning. when i took it apart i found a broken plastic piece, round 2" in dia. and looks like a bearing housing or something.it looks like little square teeth and it has grease on it. I dont know if this has anything to do with it but i really need my washer back. Please help!!!
  • Anonymous Jan 27, 2009
    the washer wont drain and im smelling somthing burning. the water comes in fine and it also wont spin.
  • 868 Answers
You may have a frozen pump .Tilt the machine back so you can look under it and turn each pulley by hand if one isnt turning youll know whts wrong then.Please leave a rating!!
Posted on Jun 09, 2008
I have a Whirlpool Gold washer (MOD# GSQ9669LW0). The washer makes a grinding noise below when in operation. Spins when agitating, but not in rinse mode. Water still pumps out in final spin.
This machine can get items stuck in the drum, the bearings can go bad etc. https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Washing-Machine/38-5-620929-/Whirlpool-Washer-won-t-spin-GSQ9669LW0.
Oct 16, 2017 | Whirlpool Washing Machines
Washer agitates but will not spin. Burning smell coming from motor
The water pump could be stuck, or broken so the pulley on the pump is not spinning, while the belt is, which gives you the burning smell. Could also mean the motor is overheating giving you the burning smell. You will have to open the back and observe whats happening while its running. Just keep your hands clear while its working.
Feb 16, 2015 | Kenmore 98702 Stacked Washer/Dryer
Kenmore washer wont drain
There is a coupling between the motor and the pump and this has finally worn out... on some models the pump is belt driven and the belt could be bad... on some models the pump is seperate from the drive motor and has its own motor just for the pump...this could be running but the pump part could be bad...nearly all machines will allow the water to drain out if you just lower the drain hose lower than the tub...try letting the water drain into a small bucket and then see if it wil spin...it should spin once the water is drained out but you will have to keep the drain hose in the bucket lower than the tub through the spin cycle....this should work and allow you to get all the water out of your machine....dont use it any more....get it repaired by a washing machine maintenance person
Aug 22, 2012 | Kenmore Washing Machines
The washer will go into final spin, it seems to be
Well there could be few things causing the smell and the tub not turning. Its possible something is restricting the tub from turning and the motor is over heating. It is also possible that the transmission has a broken gear and you are smelling something from it getting hot inside. Or you could have a bad belt or coupling. Also the water pump could be stopped up. Its hard to tell because there are so many different types of washers and Im not sure which one you have I assume it is a whirlpool late model.
Sep 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer spins but won't drain, electrical smell
HI, the smell is coming from the pump housing. the pump impeller may have slipped of the drive stud, in return, jamming itself in side the housing. this will cause the pump to burn out. Check the following before you replace the pump.
1. Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
Jul 09, 2009 | Kenmore 24032\24036 Top Load Washer
Wahser stopped after wash cycle, burning smell
Hi, it is possible that something got into the pump and stopped it from turning. Let the drain hose down so that it drains into a bucket or a floor drain if possible.
If water does not drain then it is deffinetly plugged. Once you get the water out of the washer, tip it against the wall and try to remove the pump off the motor. There are two clips that hold the pump on. You will also need to remove the hoses.
With the pump off, you can set the washer back down and try to run the spin cycle. If the motor runs, it must be the pump.
Please let me know if I can assist you further.
Thanks
Vic
May 23, 2009 | Roper RAS6233KQ Top Load Washer
Burned belt?
Yes, smell like your belt.. if there is water in tub, try to get it out... (wet vac)... slide your washer out and tilt it back so you can see under... there should be 2 belts.. 1 for gear and 1 for water drain pump... and you can check Sears.com for parts.. good luck...
Jan 23, 2009 | Maytag SAV5710 Top Load Washer
Kenmore Washer Won't Drain
yes, check the drain, could be clogged, or check the water pump assembly as well, the clothe could be stuck in the impeller.
the burning smell could be coming from a separate electric water pump and it can not turn that is why it is burning already.
tnx 4 using fixya,
drcool
Oct 07, 2008 | Washing Machines
FRIGIDAIRE FWX435RHS - FINAL SPIN PROBLEM...............
Most likely cause is partial blockage in the pump or filter. refer to your manual for access to your pump filter..most manual's show you how to do this and is not a difficult procedure. Good idea to do this on a semi regular basis as front loaders do build up with lint in this area
Dec 05, 2007 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire FWS833A Top Load Washer Logo
159 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
