Question about Proscan PSVR65 VHS VCR
Problem with my vcr
I have the proscan psvr65 and when i turn on the vcr it says "lock" and i can't do anything with it and theres a vcr tape inside and it won't eject out either and i have even unplugged the power cable for at least an hour please help
With your remote just hold on the power button! and you will get a cheery hello!!
Posted on Jul 08, 2008
Why won't the vcr turn on
Most likely it's a capacitor fault.
Google "Capacitor bulge" and then search Youtube for your make and model to see if anyone has done an instructional video. You'll need to be comfortable dismantling the TV and be able to use a soldering iron. If this isn't you then take it to a repair shop.
Aug 26, 2014 | Proscan PSVR65 VHS VCR
VCR Display Panel
It sounds like the LED might be burned out of it. Is your VCR still under warranty? If it is, the manf. can replace it at no cost. Otherwise an LED doesnt cost that much to replace if that is the problem. Did it do anything else before the problem happened? Does it still work now? But you cant see the screen is all?
Oct 02, 2007 | Proscan PSVR65 VHS VCR
VCR tapes "eaten"
I'm sure all it requires is a "more" up-to-date recorder (although up-to-date doesn't exist for that these days because of all the DVD's and Blu-ray discs). I am not sure if you mean the problem that it keeps doing that (problem in the recorder. Or you get it repaired, or you get yourself a new one (cheap these days, I wouldn't recommend repairing). Or you're meaning the problem that the tape is now completely ruined. If it hasn't been damaged too hardly, you can get the tape fixed. Or you get someone to repair it, or you can even try it yourself. I'm sure there are things on the internet for that.
May 31, 2010 | Proscan PSVR65 VHS VCR
Tape in. will not play or rewind - can't eject. screen reads 'LOCK'
open the vcr look on the right side you will see a belt attached to a motor use your hand and manually turn the belt until the tape ejects
Jan 03, 2010 | Proscan PSVR83 VCR
How to record a radio station on the TV onto a vcr tape
your better off getin a digital recorder like
http://www.amazon.com/Olympus-WS-100-Digital-Recorder-Interface/dp/B0009N9PJA
pros u can index spots of the show
May 21, 2009 | Proscan PSVR65 VHS VCR
Tape is locked in Sharp VCR
take the case off and see if the tape is stuck around anything. if not, remove the tape deck very carefully (make sure it is unplugged first). you should be able to remove the tape fairly easy. the tape may be wrapped around something inside of the deck there, or the loading gears could be out of synch. and if it happens again you might consider getting a new vcr because to replace a new loading deck is cost prohibitive because vcr's are so cheap now.
Apr 28, 2008 | Televison & Video
Proscan vcr plus gold stuck in lock
I just had the same problem and found a solution on the internet that worked. Hopefully you still have the VCR's remote control. Press and hold either the on/off, VCR1 or VCR2 button on the remote. I pressed the VCR1 button and held it for about 5-7 seconds. It released the lock and worked fine afterwards. The lock is some kind of childlock devise.
Mar 10, 2008 | Proscan PSVR73 VHS VCR
VCR eating tapes
Is the vcr in a cold room? the heads might have dew on them
or need cleaned. If it keeps doing it you probly wouldn't want to fix it at a shop. you can buy new vcr's with remote at walmart now for $25-$30 I think. Hey you can try the old treatment
that i always do. Try unplugging the vcr from the electrical
outlet for a hour or maybe even longer sometimes that will resit
everything in it and it will work right.
Nov 09, 2007 | Proscan PSVR65 VHS VCR
My vcr lcd reads LOCK now and I can't access any menu functions
My Proscan PSVR74 turns on, says "Hello" and immediately goes to Stop and turns itself off. Is there any hope for this machine?
Joe
May 08, 2007 | Proscan PSVR73 VHS VCR
Cant play tape
the end-of-tape optical sensor is at fault. either it is very dirty, has failed or something else is detecting end of tape. many VCR's now will auto-eject the tape upon end of tape detect
Dec 28, 2006 | Proscan PSVR73 VHS VCR
Televison & Video Logo
116 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
