Question about Ricoh AC204 All-In-One Laser Printer
Ricoh ac204 i am having trouble with the scanning portion of this machine. printer works fine but it doesn't want to see the scanner. if i go to install a scanner, ricoh isn't in the list so i click have disk, insert the disk and go to show it the .inf file and no matter which one i choose it says that this disk doesn't contain any information about my device. i have downloaded a current driver, but they only offer the whole application to install, not just the twain driver on it's own. when i plug it into a different usb for the first time the installation wizard recognizes it but gives an error saying that it couldn't be installed. this is the second computer i have had this problem with when it comes to this same printer problem. the first time i thought it was the computer, but now i am starting to wonder. i got it to work eventually on the old computer but i had to hook it up via serial port, which didn't even come included on this new computer so usb is my only option. please help!
  • suntot17 Jun 13, 2008
    i do have the application installed which only has information pertaining to fax properties and i have downloaded the new twain driver and still nothing. any other ideas?
  • cres10 Apr 21, 2009
    Same issue, I use the AC204 for printing, faxing, and copying. I want to use the scanner feature (to my PC running Windows XP) but can't seem to get the computer to recognize it. Have also tried downloading drivers, etc., but no luck.
  • 3 Answers
So, i finally figured this out. if you are trying to do this via usb, uninstall the software and drivers if you have installed them previously. once you have restarted your computer, or you haven't installed the drivers yet at all, turn off the printer put the disk in and when it asks you to plug in the printer, DON'T! tell it to proceed with the install without it plugged in and do a typical install not custom. it will install an additional driver than it did the last time around called scanner driver type 102. restart the computer then plug in and turn on the printer. it might install a copy 1 in the printers section but you can delete it, just make sure that in the properties of the one you intend to use is set to be using the usb port not parallel port.
Posted on Aug 24, 2010
  • Ricoh Master
  • 2,794 Answers
You probably need the whole application to get it to work. Usually Ricohs use a memory resident program to control scanning functions. That way you can fax or scan to e-mail with them.
You can check on www.ricoh-usa.com to see if there is a Twain driver for that particular model.
Posted on Jun 09, 2008
  • Tim Babcock
    Tim Babcock Jun 13, 2008
    I'm pretty sure that network scanning isn't an option on that machine. You can only scan locally.
    That machine looks a lot like a Sharp al series. I wonder if it works the same way which means that network capabilities are very limited and only reserved for printing.
  • lexijaxty Aug 24, 2010
    network scanning was never the issue, the problem was that i couldn't scan locally by the twain driver that was supplied.
We have a network ricoh aficio mp 1600 pcl printer we recently upgraded to windows 7 printer and copier are working ok but scanner is not working is there a problem with the scanner driver for windows 7
please go to www.ricoh.com and instal the scanner drivers of windows-7 other wise you can instal the scan to folder which dos not required any drivers or you can install scan to mail this also does not required any drivers - thanks
Mar 10, 2011 | Ricoh Aficio MP 1600L Black and White...
I have a Ricoh sp c222sf multifunction machine. I'm running Windows 7. I loaded a driver for both the printer and the scanner from thier website. All seemed well until I went to scan from the ADF. It...
u got to unscrew the scanner a bit and arange the adf left or right depending your line position. the adf is not positioned perfect on the machine , and at the end it scan the adf back , thath is the line come from on your scanned document
Feb 02, 2011 | Ricoh Aficio SP C222SF All-In-One Laser...
Scanner is locked with red lightning rod lit on front of printer. How do I unlock?
I am having this same problem today, urgent issue. AC204 will not perform copy function, says "scanner locked" and red lightening bolt lit up. This my first time at this site, i do not see where this answer is ..
Please help me, thank you
May 20, 2010 | Ricoh AC204 All-In-One Laser Printer
Installing Printer/scanner kit to Ricoh Aficio 2015
the main part of the kit is a dimm card. the dimm has the fax/scan/print stored on it. the problem adding this to your machine is drivers, only twain scanning, no scan to folerd, no internet faxing, no winodws 7 drivers. if you get a whole kit you need to add the fax pcb and also get the nic for it to scan properly. good luck
Dec 23, 2009 | Ricoh Aficio 2015 Copier
Ricoh MP4000B
hi
a rijas working in dubai
my Gestetner MP 4000B nw its showing waste toner bottil is full please advice me how to solve dis problem
Feb 18, 2009 | Office Equipment & Supplies
Printer shows offline/Scanner has no destination list
You must program the email addresses in the machine address book, so that you will have a destination list to scan to email.
You can also try to scan by pressing the Scanner button to access the scanner function and input the email address manually by selecting manual, and then press the Start button to scan the document.
Joe
Dec 18, 2008 | Ricoh Aficio 1515MF All-In-One Laser...
I am having trouble scanning a document on the Ricoh Aficio 2018D, I also cannot locate the user manual, can you please advise how to scan on this machine?
If the scanner has not been configured, or network settings have changed, the setup for scanning on this unit is unfortunately quite difficult for a novice. the manuals are readily available at Ricoh.com, under Downloads, but this will not help very much with the scanner config.
Sorry:(
Dec 08, 2008 | Ricoh Aficio 2018D All-In-One Laser...
Problem in scanner when scan
Try adding the scanner's IP address in the scnhosts file in the TWAIN folder. Format is similar to the windows hosts file. You'll see a commented out sample entry, just modify that to suit your needs.
This may or may not work for you; we had it working under this configuration but then it stopped for no apparent reason. also note that scanrouter isn't supported under vista. Only advice I've been given so far is to revert to sending scans via SMTP - not ideal!
Jul 02, 2008 | Ricoh Aficio 2018D All-In-One Laser...
Scaning . . . Scanning. . .. not scanned
Not sure if this is the correct way around, but it worked.  Go to Start --> All programs --> Dell Printers --> Dell Photo AIO Printer 922 --> Dell All-in-one center
From here, you can determine and change your scan settings as needed;  then click "scan now" (thus by-passing the button on the actual AIO machine).  This scanned photos into my picture program so I could email to all the grandparents!
Nov 14, 2006 | Dell 922 All-In-One InkJet Printer
Ricoh AC204 All-In-One Laser Printer Logo
172 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Bernard D'Souza
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
