Question about Miele 24 in. G870 Built-in Dishwasher
Miele G868 dishwasher - leaks from front panel air vent
I have a Miele G868 dishwasher, S/N 17786510,  which leaks water on the floor from the air vent on the top left of the door, located right above where the "Turbothermic" label is after all the cycles are complete and we open the door to unload the machine.  We lower the door to a horizontal position and several ounces of water leaks out the vent onto the floor.
It only started doing this recently, after many years of otherwise near flawless service.  Any ideas what to investigate or someone had prior experience with this malfunction?
  • 4 more comments
  • maxmed Jun 26, 2008
    We have the identical problem with our Miele G870 (installed 1997). Have tried drastically cutting back on the amount of detergent used, but that hasn't helped. Also removed and cleaned the white round vent on the left inside of the door.
    Di J.
  • slrobi Aug 10, 2008
    We've had the same problem with the G870 dishwasher.  It leaks water from the vent on the top left side of the door, when we lower the door to unload the dishwasher.   We've also tried using less soap, and have tried to clean out the vent, although, we still have the problem.
  • Anonymous Nov 07, 2008
    I tried taking the door apart and cleaning out the hose.
    The top left end of the hose came out easily and it was apparent that
    there was blockage. However, when I tried to remove the bottom right
    part of the hose, it did not slip off easily and cracked the connection.
    So close to a solution - and so far!
    Di J.
  • higgo888 Jan 24, 2014
    Leaking from vent when door opened usually means drain tube from bottom of air vent assembly is blocked.
    Water leak from vent fan upon fullt opening door usually means blocked drain tube from bottom of vent fan assembly. Try a vaccuum cleaner first successfully
  • higgo888 Jan 25, 2014
    oops rest of storty.... 1) cut 2 squares of plastic film and tape 1 over internal opening to vent . 2) cut hole in 2nd piece plastic to fit vacuum suction tube. hold vacuum suction and plastic against external opening of vent fan. Let vacuum run for a minute or so (tape plastic to tube / external vent if necessary). Worked fine for me.
  • 4 Answers
Hi all,
I have had the same problem. Here is what I've done. Take the door apart (a whole bunch of screws on the side of the door). The front panel will come off and you will see a rubber tube. Take it off and blow it out. Then take the blower out (you need to unscrew the inside of the blower). Take apart the blower and clean it out.
Good luck.
Posted on Oct 15, 2008
    Novelist:
  • 269 Answers
You have the Miele problem.
This happens every year or two. Take off the outside front panel to access the hose that runs from the bottom of the fan down to the dispenser, and lets the water drain out through it to the interior. Clean out that hose as well as you can. Replace. This is a stupid problem that Miele should have a permanent fix for. Grrrr.
In fact I just did this with mine today. The hose cleans out quickly, the problem is getting the front back on. 4 hands make it easier. It slips on when you start close to vertical, then slip in in and down. For putting the screws back in, you might have to use a micro screwdriver to re-align the little clips on the door panel. (You will see what I mean when you do it!) This costs a service call ($100, give or take) to call for service. It can be done at home with no added parts. I think it applies to all Miele dishwashers, and I have now done it several times. As I said before, this is a design fault and should not be necessary!
If you have a helper to help contain the mess, you can spray water into the fan area (best is backward through the hose, but try all directions) and catch the runoff. We have done this and it catches a lot of gunk.muck and slop.
Doggone design sucks on an otherwise nice machine!!
Posted on Oct 16, 2013
  • 4 more comments
  • Benny
    Benny Jul 27, 2014
    We removed the front door panel and found nothing but another panel! We have a g868 but it is almost 18 years old, so perhaps ithe one you have is newer?
  •  vpsoccer
    vpsoccer Jul 27, 2014
    Mine is circa 1998 so I am not sure. Take a look and maybe you can find another way to access this drain (running from the fan down to the soap dispenser, but from the front of the machine)?
  •  vpsoccer
    This is such a stupid design problem you would expect Miele to have found some kind of replacement kit or other permanent fix.
  • Benny
    Benny Jul 28, 2014
    Thank you for replying. Our only other option is to take the door apart from inside the machine. This seems like a bigger undertaking, but might be worth doing before spending the money on a service call. I will let you know if we have any success.
  •  vpsoccer
    vpsoccer Jul 28, 2014
    Note that while it is not in my original response, you do take the front (outer) panel -- the plexiglas or whatever -- off by removing the screws that are on the inside.
  •  vpsoccer
    You lower the door and work from that side. Otherwise, note that many professionals, and landlords with dishwashers in units, suggest that 15 years is about the service life of a family dishwasher. Of course we all expect more from Miele!
We had this problem and had to replace the door fan assembly which was frozen. The part is very expensive and I wonder whether Miele parts are available other than from Miele.
Posted on Nov 20, 2009
Miele g665 leaking water from turbothermic vent
I had this happen too. There is a rubber venting tube which runs from the vent on the door to the rinse/powder release pods. This clogs up and the water then comes out when the door opens. If you take off the front panel of the machine (screws are on the sides) it is easy to take off and clean out by running hot water through it, also clean out the line through the release pods .. problem should be solved.
Oct 21, 2011 | Miele 24 in. G665 Built-in Dishwasher
I have a Miele G 892 Dishwasher and recently the vent for the Turbotronic drying fan has been sticking in open position at the ned of the cycle. Teh result is the next cycle the vent fills with dirty water...
You'll have to take the door panel apart. There's a small drain hose between the turbothermic unit and the detergent dispenser. It's most likely clogged.
Feb 22, 2010 | Miele G880 Dishwasher
The drying vent on the front of our miele dishwasher is leaking water and the fan is making a lot of noise at the end of cycle
if you remove the door panel you will see a small hose from the fan to the combi dispener. Remove this and blow through it. Also connect it to the combi dispener and blow and then to the fan end and blow. Food and muck block the pipe and the excess water cannot escape back into the unit so instead it pours out the vent. you will find the fan is then quieter.
Feb 05, 2010 | Miele 23 in. Novotronic G841 Built-In...
It leaks from the left side when washing dishes
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
dddg
Nov 22, 2009 | Miele Touchtronic G892 Built-in Dishwasher
Oops! Bubbles in rinse cycle bc of wrong product - Palmolive soap instead of Miele rince-aid. Help! Miele G868 Dishwasher
You will have to cycle dishwasher several times before the suds will disappate from dishwasher. Good luck
Dave
Oct 26, 2009 | Dishwashers
LG dishwasher is dripping water from vent onto floor
Good that it is working. Recommend you keep a lose eye on the vent on the bottom of the door panel. This model will probably begin leaking again if it has not been retrofit with a kit that LG developed.
Please open a new problem when it starts to leak and please provide the Model and serial number when you do. Good Luck!
Mar 24, 2009 | LG LDF6810ST Stainless Steel Built-in...
Not enough water is going into the dishwasher unit
is the spray tower or lines to it clogged check them that might be where it is at
Feb 26, 2009 | Miele 24 in. G656SCi Plus SS Built-in...
Miele G868 built-in dishwasher water inlet problem
Pull of the program knob. Then you should find a water-intake-time-selector to the right of the axis. Take a screwdriver and turn it slightly counter clockwise one click to increase the time and vice versa.
Here's the manual:
http://www.miele.com/manuals_pdf/Residential/Dishwashers/English_manuals/Operating_Instructions/G870_us.pdf
Feb 12, 2009 | Miele 24 in. G870 Built-in Dishwasher
Drying cycle vent fan is noisy. How can I fix it
I had the same issue but mine is an inbuilt unit. I removed the 4 screws for the front main facia panel which was then removed. Following this I removed the 6 screws that hold the plastic control cover in place and then the three screws (1 top centre and 1 on left and right) that holds the control plate which I then gentrly lowered.
I then used a flat blade screw driver to turn the inside fan cover anti clockwise about 45 degrees which allows the fan module to be removed. Then disconnected the drain pipe at the fan module only and power and control cables.
I then blew the gunk out of the fan module and gave this a good wash through with hot water to ensure it was clean and then dryed with paper towel. I then also blew out the drain pipe. The remaining gunk was blown into the interior of the dish washer out a vent just below the rinse aid unit.
If I need to do this again then I would have removed both ends of the pipe and washed this through with hot soapy water to make sure it was clean.
To reassemble do the reverse process. Assistance will probably be required to reassemble the front main facia panel as one person would need two hands to hold in place and another to locate and start the screws. A couple of clamps could over come this.
Dec 31, 2008 | Miele 24 in. G865 Built-in Dishwasher
Miele g841sc dishwasher leaks
Typically the machine only uses 5-6 quarts of water, If you're floor is getting 1 or 2 quarts check for a loosly connected intake or drain hose. I've never seen any overflow drain on a Miele. It only fills the bottom of the tub. The machine uses a logic program that continuously checks the level of fill and drain by water pressure weight so it always runs with proper amount, even if your intake pressure is weak. Now, If you add too much soap then the bubbles can carry a few ounces over a worn door seal. If the seal is damaged then more spray arm water can run down the front of the machine into the float pan. But after it gets less than a pint of water the drain float will start thr drain pump and shut-off the machine controls and alert you. It won't let you run the machine until the water ( and the problem) is gone. Call Miele for help.
Sep 15, 2007 | Miele 23 in. Novotronic G841 Built-In...
Miele 24 in. G870 Built-in Dishwasher Logo
5,480 people viewed this question
Top Miele Dishwashers Experts
mpservices
Craig Butler
Craig Butler
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
