Question about Epson Stylus C64 InkJet Printer
Ink doesn't show up
I have an epson C64 and have just put in new ink cartidges. When I tell it to print, it pulls the paper through and moves back and forth like it is printing, but I get a clean sheet of paper when it's through.
  • 1 more comment
  • Anonymous Oct 05, 2008
    I have the same trouble it just feeds the paper straight back through when ever i tell it to print something
  • dtg123uk Feb 18, 2009
    Just wasted £50 on replacement cartridges for the colour ones (not black) and now the wretched thing either just prints blanks or only part of the lines and only every 5 lines .... have switched it on and off and cleaned varous nozzles etc with no joy
    Debbie Mandelli
  • general1952 May 05, 2009
    Replaced with new cartridges. Will not print Powerpoint slide. Attempts to print Word doc. Skips every two lines. Prints no color.
Same problem as above.
Posted on Nov 03, 2008
Hi havent used this printer in a while and set it up to my laptop, i tried to print and it wasnt working so i thought that it was the ink as it hadnt been used for a while so i went and bought all new...
Remove and then replace the black ink. Make sure you remove any sealing tape that may be covering holes in the ink cartidge. While the ink cartidge is removed, you might also want to give it good shake. Finally, the cartrice may juat have been too old - they age even when in the packaging, and most have an expiry date.
Nov 08, 2017 | Epson C64 InkJet Printer
Ink and paper lights flashing alternately epson c64 photo edition. paper fine, ink levels fine, power fine, comms with computer fine, still wont work, Help.
-turn off printer
-disconnect from computer
-load a couple sheet of plain paper
-press & hold paper feed button while turning the printer on
-it should print a test page if it is working fine, otherwise it is bound for service
Apr 02, 2010 | Epson C64 InkJet Printer
Epson stylus c64. Replaced low ink printer
1) Unplug the power cord, wait 30 seconds, then plug back in.
2)Did you follow the directions exactly when replacing the cartridge? Did you peel off the protective film?
Jul 03, 2009 | Epson Stylus Photo R300 InkJet Printer
I have epson i was given i have just put new ink in and it prints but with no ink
Have you carried out 2 or 3 head cleaning cycles? If not, do it. Is there ink on paper after this cleaning? If so, but it is streaky, leave the printer for 24 hours and repeat. If not, you must soak the heads for at least 24 hours - use print head cleaning fluid or distilled water NOT TAP WATER. Turn the printer on, and as soon as the print head moves, pull the power cord out of the back, or switch it off at the mains. You should now be able to move the print head over to the left by hand out of the way. Now look in the "parking bay" at the right end where the print head parks itself. You will see a small oval rubber cup that covers the print head when it is parked. Use a syringe or dropper to fill the cup with cleaning fluid, then gently push the print head as far into the parking position as it will go. Then leave for at least 24 hours. Then try the cleaning cycles again. If no joy after this, report.
Dec 13, 2008 | Epson C64 InkJet Printer
Epson C64 Printer
It sounds like the print head is jamming on the parking mechanism (usually because the actuation lever is stuck in the up position). Turn the printer on, and as soon as the print head moves, pull the power cord out of the back, or switch it off at the mains. You should now be able to move the print head over to the left by hand out of the way. Now look in the "parking bay" at the right end where the print head parks itself and see if there is a plastic arm sticking up. If there is, gently pull it towards you and it should spring down. Now turn the printer back on and it should operate normally. If it happens again, repeat the process a few times to see if it clears the problem. Otherwise it means the parking mechanism is gummed up with dried ink and needs a good clean (see below).
Alternatively, if you see that the whole parking mechanism itself has moved up to block the way, this means a spring has come off. To get this back on again requires the printer to be dismantled - as does the cleaning job above!
Should you decide to have a go at cleaning or re-fixing the spring, let me know via a new posted comment so I can provide further assistance.
Nov 09, 2008 | Epson Stylus® C64 InkJet Printer
Epson cx6600 printing only magenta even with new cartidges
Try remove and shake the inks and reinstall it back in and test to print. If you have tried more than 4x with the head cleaning it might be your ink pads inside the printer is clogged. Is this still under warranty? You have to call Epson they might help you out with it.
Oct 11, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Epson stylus C64 ink jet printer
if you have installed the software for the printer correctly it will show you the approximate level of ink every time you prints.
Jun 18, 2008 | Epson Stylus C64 InkJet Printer
Printer will not print
More info needed here. Are any lights on or flashing? Have you tried going through the cartidge instsallation process again (but just taking out and putting back the same cartridges when told to put in new ones)? Are the unrecognised cartridges genuine Epson or compatibles? Have you tried putting genuine Epson cartridges in (even empty ones will do) to see if they are recognised? A response to these question will permit me to give you much more specific help.
Nov 26, 2007 | Epson C64 InkJet Printer
C64 printer
Is this a New printer or a used one? what are the cartridges new or uses original or third party Did you follow exactly the Epson installation procedure? lots of question for you to come back with
May 24, 2007 | Epson C64 InkJet Printer
Epson Stylus C64 InkJet Printer Logo
222 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
