the drip pan on my everstar 10000btu standup unit seem to be missing the metal piece that i guess let the unit know pan is in place or not full. The unit still works but will not cool unless red light stops and senser knows pan is in place. I have tried to get a preplacemant part but there are none available is the anyway i can fix this problem myself if i knew exactly what the peice looked like or where nad how it activates senser i could fix the problem.
-   flashing p1 and red flashing light-   Guest
Aug 28, 2008
-   I have the MPK-10cr-1. I too had the P2 error coming up. Here is what I did. The slide that tells the P2 switch to open gets stuck. Mine had one of the control rods on the wrong side of the slide. I removed the switch and put it on correctly. That cured the problem. Don't attempt if you haven't any experience working on problems such as this.
Service and manual link: http://www.supportuscenter.com/product.asp?specific=jnnonph0
-   I have the same problem. P1 light is on and I cannot set cool option, the only thing that is working is the fan. The drip pan is in place.
Thank you for any help!-   teretall
Aug 16, 2008
-   my mpm-08cr-bb4, everstar air conditioner, will not turn on, the P1 light is on, and the red button is flashing. should i put water in the tub? what should i do? thnk u jc
-   mushroomouse
Aug 16, 2008
-   my Everstar Model MPK-10CR-1 is doing this also it was working fine then 3 hours later the P1 light came on. The bucket was completely emtpy. Now the P2 light is on & I have know idea what that means any suggestions?-   ambercsz3
if you take the cover off of the air conditioner. right above where the water catch is there is a switch in there. cut the wires on the switch. its only 2 wires and wire them to gether put electrical tape on the wires baldspot and put back together. put bucket back and turn it on. it will not stop running after the bucket is full now but it will work again.
just empty the pan below. i coudnt find it so i shook the unit until ihad water all over the place. unit started working. i am not sure how to get the pan out, but that is the problem of P1 and P2
jodie.coleman@charter.net
Instead of cutting the wires I just whack the bucket in until it hits the switch which you can work with our fingers. pull the bucket out the push in the switch (upper left corner where the bucket is) and it will turn off P2.. I suppose bubble gum would work too but then you will get overflow when the bucket fills. I suggest bubble gum and a long hose out the window.
Re: P1 Message
My problem was solved by just putting the plastic tube in a bucket and letting the water run out. First time I ever had to do this. This was the first time the humidity was so high since I have been using the unit. Easy Fix if that's your problem.
Was this helpful?
Yes
No
Solution #8
posted on Sep 27, 2008
Guest
Rank: Apprentice
Rating: 0%, 0 votes
THANK YOU!!!
I had the P1 problem as well. Took the case off and there was a little toggle switch that had fallen from its place at the top left of the water storage compartment. I just put some tape over it to hold it down and that was that.
I need a hendheld pen scan
suitable for XP and editable on word,
to save especially half of the...
(More)
to save especially half of the lines not the all page,also it should write-
I need wireless one,with large memory,which can run on batteries I can recharge on the USB port.
do ou reccommend anything please?
I m going to use it in Europe
on Bugarian and Turkish
thanks a lot
canon dr 2580c gives a small white stripe of 2 mm on a colour scan. Please give me an answer...
(More)
canon dr 2580c gives a small white stripe of 2 mm on a colour scan. Please give me an answer ,without letting me pay for the answer.
My Everstar Portable Air Conditioner, Model# MPM-08CR-BB4 has completely stopped; it is dead. "P1" lights up where the digital temperature indicator usually is. Also, there's a red light at the top that's come on. Could this have something to do with a filter or the exhaust? How can I fix this?
everstar portable air conditioner mode button not working. cannot change to cool also no lights on the mode or cool and dry light up. please help
Gilbert
