Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Locked The tv is lock and I do not know the code, what do I do
    Problem Solver:
  • 16 Answers
When all else fails try this.
With the tv on, with your remote punch in this series of commands--menu , 2, 4, 7, 0 the tv will show the option menu.
Make sure "initialize" is highlighted. if it is press "enter" on the remote. Wait a few seconds. The tv will default to customer factory settings, in other words the way the tv was when it came out of the box. DO NOT HIGHLIGHT ANYTHING ELSE IN THE OPTION MENU !!!!!!!!!
Good luck
Posted on Jun 12, 2008
  • coffeedrunk Jun 12, 2008
    MY bad
    too excite option menu just hit the menu button on the remote once again
My akai tv is locked,don't know the code
Most TVs have a parental control lock that can be set to prevent children from watching specific television shows. In order to activate or deactivate the controls, you need to know the four digit security code or parental lock control password. If you forget the number you chose or if the lock gets set accidentally, it is still possible to unlock the TV.
Instructions
Turn on the TV and grab the remote. In most cases, you will need the original remote to unlock the TV if you aren't sure of the unlock code. If you don't have the original remote, you will need to purchase one.
Look at the screen. If you see a blank screen with a red key on the bottom of the screen, press 'Function' and 'Mute' at the same time. This should unlock the channel. This is an option for people who want the TV to stay locked but, want to be able to bypass the lock to watch a certain show or channel. All other channels will remain locked and the TV will fully lock when it is turned off.
Unlock all of the channels on the TV by entering the factory reset code. There are three main reset codes that TV manufacturers set. These are 0711, 6688 and 3308. Try each one until you find the one that works. This will reset the TV to original factory settings. When you do this, you will loose any information that you have stored in the TV, such as favorite channels, automatic timers and the clock. You will have to go through the full initial set up.
Call the technical support service number in your owner's manual if none of those codes work. A technician can help you troubleshoot the television because the problem may not be the locking control. When you call, make sure that you have the model number and serial number of the TV.
Take your television to a TV repair shop. In some cases, a professional who access to wiring diagrams for your television set may have to rewire certain components in order for the television to unlock. This is usually the case when the TV locks by itself while it is on.
Sep 13, 2012 | Jensen Q2749J 27" TV
V-chip block passcode
Hello
You must have its original remote control handset to unlock your Mitsubishi tv.
After you set the lock, you must use your pass code
to view a locked program, view the locked TV, view
a locked channel, cancel the lock, or enter the Lock
menus.
If you forget your pass code, you can view the locked
TV without entering your pass code. When you are
prompted for your pass code, press the number 9 and
QV keys on the TV remote control at the same time. This
process temporarily unlocks the TV.
When entering the Lock menu, this process deletes
your old pass code and prompts you to enter a new
pass code.
• You can either enter a new pass code to open the
Lock menu and make changes or press EXIT to close
the menu.
• If any of the locks are turned on and you exit the
menus when prompted for a new code, the old
code and all lock settings are retained.
• If all locks are turned off and you exit the menus
when prompted for a new code, then the previous
code is erased.
OK.
Mar 17, 2011 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi parental unlock code???
Hello
Mitsubishi sets use a four-digit code for a V-Chip locked program, view a locked TV, cancel the lock, or to enter the V-Chip lock menus. You can view the locked shows on the TV set by pressing the number 9 and QV buttons on the remote at the same time, whenever your code is requested. This process temporarily unlocks the TV and asks you to enter a new code.
OK.
Dec 28, 2010 | Daewoo DTQ-13P2FC 13" TV
How to change the v chip code to a mitsubishi medallion projection tv 62
Bypassing the V-Chip Lock on most Mitsubishi sets:
Mitsubishi sets use a four-digit passcode that is required to view a V-Chip locked program, view the locked TV, cancel the lock, or enter the V-Chip lock menus.
If you don't have the passcode, it is easy to bypass. This is neccessary if you forgot the code, purchased the set used, or if you simply don't feel like searching through your files to find it.
To bypass the V-chip: You can view the locked shows by pressing the number 9 and QV buttons on the remote at the same time, whenever your passcode is requested. This process temporarily unlocks the TV.
To reset the code: When you use the button combination 9 and QV while entering the V-Chip Lock menu, this process deletes your old passcode and prompts you to enter a new passcode.
Good luck, and let us know how you made out with this TV set.
Mar 20, 2010 | Televison & Video
Tv key code locked
hi what make and model is ur tv
Apr 19, 2009 | Televison & Video
Channell lock
i find out that some channel are locked on my telivision with a padlock sign. How can i unlock this channels
Aug 24, 2008 | Curtis CM25101S 25" TV
Sanyo tv kit 360 ch fit in my old tv & lock channel kindly solve problem to unlock tv channel
i am imran
and i have also buy sanyo tv kit 360 ch fit in my old bpl 20"tv and i know for unlock tv channel.
try this this code definetly is solve your problem.
1st go to the locked channel.
and then press menu>system>child lock
and then press and hold down tv/av key and press swap key.
and see locked channel is unlock.
i have coming soon post for service code menu in short coming days.
please reply me to imr4@in.com
Aug 12, 2008 | Sanyo DS24205 24" TV
Forgotten password
Your tv is switched on and locked , blue screen and shows keys. A tv with activated child lock can only be unlocked after an 4-digit code is punched in.
Reset of child lock is as followed :
Determain chassisnumber type on type plate on the back of TV.
example: CUC xxxx ( xxxx = 4 digit number).
TV's CUC 6300, 6301 and 6310: bullet.gif Press cursors (blue arrows ) in sequence : Right, Left, Down , Up, followed by OK
TV's with chassis CUC 2003, 2005, 1805, 1825 t/m 1827, 1842, 1894, 1952, 1962, 1983, 1984, 1806, 1828, 1829, 1830, 1836, 1929, 2020, 2021, 2030, 2031, 2033, 2050, 2058, 2059:
bullet.gif Punch in universal code 7038 in. This code ends the child lock
TV's with Chassis CUC 1832, 1930, 1931:
bullet.gif Punch in universal code 7038580. This code ends the child lock Greetz and good luck, and PLS let me know if it works
Arni
Jun 13, 2008 | Televison & Video
Panasonic TV TC-19LX50 that is Locked
Ask your part time workers what the code was, then enter it into the television.
Mar 24, 2008 | Panasonic CT-24SX12 24" TV
Locked out, channel or child lock how to re-set
I know one code please try if it helps 1 press mute button once on remote control handset. 2 once again press &HOLD remote hand set mute button. 3 while keeping mute button pressed press menu button on tv set. good luck
Sep 17, 2007 | Toshiba CF36G40 36" TV
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
