Question about Jl Audio 500/1 Car Audio Amplifier
We have all the wires hooked up right.... I even tested the wires with another amp and that amp worked. I was just wondering if their are any fuses in the jl audio that might have blown or any other signs I should look for... why my JL audio would not be working?
  • chalcee Jun 09, 2008
    Their is no sound at all... The only light that comes on is the power light!
  • crouch-66 May 03, 2009
    no lights come on nothing happens is there no fuse at all in the amp?
  • 631 Answers
There are no fuses inside the amp.
Are any of the lights lighting up on the amp?
If so, which ones?
Posted on Jun 09, 2008
  • Perry Babin Jun 09, 2008
    How much DC voltage do you have across the positive and negative speaker terminals (black meter probe on the negative speaker terminal, red meter probe on the positive speaker terminal)?
    How much DC voltage do you have from the chassis ground terminal to the positive speaker terminal (black meter probe on the chassis ground terminal, red meter probe on the positive speaker terminal)?
    How much DC voltage do you have from the chassis ground terminal to the negative speaker terminal (black meter probe on the chassis ground terminal, red meter probe on the negative speaker terminal)?
04 navigator is blowing ac fuse 11, ac coil shorted, 3 different coils, can ac compress short the coils
How did you hook up the inline fuse to compressor and ground to compress ? Ground what ? Right at the clutch coil ? You have to be hooking it up wrong . The compressor can't cause the clutch coil to short or blow the fuse , even if the compressor were seized up . An before that would have the serpentine belt would burn up , squealing noise. applying B+ voltage in the relay socket ,pin 30 to pin 87 will engage the compressor clutch . If the fuse blows the wiring from the relay to the compressor clutch is shorted to ground . Look for rubbed through wiring harness .
Jul 14, 2017 | Ford Cars & Trucks
Wireing jl 500/1 to dvc sub
You will have to take a piece of speaker wire and put it from the positive of one voice coil to the negative of the other voice coil.....Then, with the other remaining positive and negative, hook it up to the amp.....And your good to go....If your still confused, get back to me....hope that helps.....
Mar 24, 2012 | Jl Audio 500/1 Car Audio Amplifier
99 neon dome light wire diagram
Hooked all wires up right??? Fuse is fine??? Somehow, I do not think this is the case. I wish I had a dollar for every time I have seen this happen....I would be a VERY rich man!
You do not need a dome lamp diagram. You need to replace Fuse #13 (10 Amp) in the Power Distribution Center in the engine compartment. This will make the power return to the PINK wire and get your dome lamps working.
The only way that the RED/WHITE wire is going to have power with the ignition switch off is if either the ignition switch is shorted to power or the RED/WHITE wire got hot enough to melt the insulation in the wire harness and short to another B+ wire. This wire is supposed to have power when the ignition switch is in the RUN and ACC positions. Make sure it is in the OFF position. If this wire still has power, then YES, you probably smoked the wiring harness. If this is the case, the dash should be removed so that full access to the wiring harness can be achieved, allowing a full inspection/repair of ALL of the damage (there are most likely several other wires in the harness that have also been damaged).
Dec 24, 2011 | Dodge Cars & Trucks
I have a jl 500/1 amp hooked up in my car and the power light comes on for about 5 seconds then turns off. no sound out of the subs. it is hooked up to a factory deck through a high to low level converter....
hook up the remote wire ( or make sure its hooked up good) check your ground! ground wire not big enough awg wire and put on bare metal not more than 1 foot away from amp. bad ground will cause this.
Sep 12, 2011 | Jl Audio 500/1 Car Audio Amplifier
Stereo is hooked up, but not receiving power. wondering if it might be a blown fuse, and how do i fix this?
just check all your fuses with a test light because even if the fuse doesn't look like its blown it might be. also check wires behind the stereo
Jun 30, 2011 | 2000 Ford Contour
Can you run a 8 gauge power wire to a jl audio 1000/1 amp and not have problems even though jl reccommends 4 gauge power wire?
Hi, if you're going to run a smaller wire, you also need to use a smaller fuse. A 50 amp fuse is needed for 8 gage wire. The fuse is there to keep the wire insulation from melting, which is what will happen if you run too much power thru the wire. If you don't plan to turn the amp up too high, this may work fine, but I would test it first with a 50 amp fuse before installing. You will need all of the speakers hooked up and the gain set to max to test the power draw. See the following link on wire sizing for more info: http://www.bcae1.com/wire.htm
Mar 14, 2011 | Jl Audio 1000/1 Car Audio Amplifier
Just bought a 1999 f150 pick up. the guy said he was having a charging problem and replaced the battery and altonator. He had a big sterio in it and removed that so right now it has no sterio. He had it...
Start with having the alternator tested ( out of the truck, not just a meter test like Autozone would do ) and have the battery load tested.
Could be the alternator field fuse is blown, this is the 20A fuse in the same block as the mega fuses on the firewall.
Also check the connector at the alternator to make sure it is in good shape, some times the connector will get gummed up.
Jan 01, 2011 | 1999 Ford F150 Regular Cab
Amp comes on then shuts down JL 500/1
what do you have hooked up to it? Subs, Speaker, so on. it sounds like it is going into protection because of improper wiring... or it was improperly wired. if it is malfunctioning you need to take it to an authorized JL audio dealer. It's going to cost some cash unless you have a warranty on it and it was installed by a liscensed technician.
May 31, 2010 | Jl Audio 500/1 Car Audio Amplifier
Installin car systems
you dont want to connect both of those amplifiers together. You could run them separately to separate subs or the jl to your sub and your alpine to your front speakers. But you dont ever want to mix and match amps to the same sub. Even if you had 2 jl500/1's you wouldnt want to just hook them up together. Because they both have to be putting out the exact same amount of power. Which no 2 amps are ever exactly the same. Some companies make bridges to properly connect 2 exact amps together. I Hooked up 2 JL 1000/1's to each voice coil on a 13.5 W7 and i smoked the sub. So i definitely dont reccommend doing it unless the amps are conneccted to separate things.
Apr 28, 2010 | Jl Audio 500/1 Car Audio Amplifier
Jl Audio 500/1 Car Audio Amplifier Logo
333 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
hoyzee1
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
