Hitachi 42PD7200 HDCP problem. SKY HD reports the TV is not HDCP. Been fine for the previous 18 months
  • alfaowner Nov 19, 2008
    Yep, I have same problem :( what was the problem?
  • Anonymous May 17, 2009
    my 7200 was working fine for 6 weeks when i first got sky HD box.
    now will not display HD box with HDMI lead so no real HD souce.
5 Suggested Answers
creativemind
  • 133 Answers
SOURCE: Sky new zealand say my
http://tv.about.com/od/hdtv/a/hdmidvihdcp.htm
see the link
Posted on Aug 06, 2008
  • 375 Answers
SOURCE: how do i connect hitachi
check your owners manual for audio outputs on your unit to feed to the amp.
Posted on Aug 23, 2008
SOURCE: Unable to use Sky HD Due to an HDCP
Try calling samsung they might have a firmware update they can send you
Posted on Dec 31, 2008
  • 47 Answers
SOURCE: onn 32 hd ready tv
you havent got another channle sitting on top of your hd channel have you . also is the hd cable pushed in all the way.
Posted on Jul 07, 2009
sethdileswar
  • 253 Answers
SOURCE: Hitachi 42PD7200 Plasma TV gone dead
this problem is from smps power supply of your tv circuit, may be power capacitor may be short , power transister may be short pls check some spair of power supply
Posted on Apr 06, 2010
Hitachi LCD TV Dead
There is a internal fuse on the power supply board. When you plug in the set, does the standby light come on?
May 10, 2013 | Hitachi 42PD7200 42 in. HD-Ready Plasma...
What is the tv code for Hitachi model 42PD7200
what you will want to do is go into the users guide and find the reset factory defaults option usually it involves holding a button or two while starting the device however are sometimes very different
hope this helps
Robb
Oct 03, 2010 | Hitachi 42PD7200 42 in. HD-Ready Plasma...
Apr 06, 2010 | Hitachi 42HDT79 42 in. Plasma Television
Is there HDCP chip in Sony KF-E42A10?
HD programing 1080i,if tv it can get that mode.No part change in tv to get HD it can or not, that it.
Jan 13, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Black like down the center of tv
this is a critical failure on plasmas, you will need to get it serviced.
Apr 03, 2009 | Hitachi 42PD7200 42 in. HD-Ready Plasma...
LE40R74BDX HDMI input stopped working
I work for sky as an engineer (not a subby)
HDCP is the encryption that is sent down when a program is transmitted. I have had this several times over the years and have found out that you need go to the manufactors web site or call them to update your telly this will sort out this problem.
I would do this sooner then later... reason I am telly you this is sky have take the Component inputs off all the sky boxes now.... The box you have is a THOMSON (have a look.... make you smile)lol this was due to people connecting there sky HD box to there pc via Component and using programs like Copy+ and extract + to copy the content.
If your box breaks down. then you are snookered if you telly is not going to accept the skyHD through a HDMI connection.
Hope this helps
Cheers
Little Dish Fitter
Mar 04, 2009 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
Dec 06, 2008 | Samsung LE32R73BD 32 in. HD-Ready LCD...
Televison & Video Logo
350 people viewed this question
Top Televison & Video Experts
Electro Med Services...
