Question about Microwave Ovens
GE Microwave JES1139WL01
The paint (or other finish) is peeling on the floor of the microwave, which is less than 2 years old. So far, this has happened only in areas under the glass turntable. Several people have used and cleaned it, and it's not clear whether a cleaning substance contributed to this.
It otherwise works o.k. except that sometimes it starts turning slowly when you open the door, before you've pushed 'start'.
Is it safe to continue to use the microwave?
Is there a way to repair or renew the finish?
Have others reported this problem?
Thank you.
  • Microwave Ovens Master
  • 9,098 Answers
Chances are spills or steam is accumulating during cooking.
After steam or spills, it's best to wipe the moisture away and even leave the door open a while to let it air out.
The "turning slowly when you open the door" you mentioned is probably normal due to door switch timing, unless you feel the door latches or door latch holes may have some grease buildup, in which case they should be cleaned.
Always be sure to hit Stop to halt cooking, and never open the door while it's cooking. That shortens the life of the door switches and can lead to erratic behavior.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jul 05, 2008
I have a GE microwave model# jes737wm02 manufactured inFeb. 2009 it runs but won't cook
we purchased a ge microwave about 2 yrs ago & the paint is peeling on the inside. Is this dangerous & should we continue to use it?
Oct 28, 2010 | GE JES738 Microwave Oven
I have a GE microwave that is barely a year old. Recently, my husband was heating up some melting chocolate and white sparks started flying within the microwave. When we opened it, all we saw was that some...
Very difficult to explain briefly as microwaves are truly complex.
You will almost certainly have 2 problems. 1)You need to carefully sandpaper the area where the paint is peeling off and "only paint with appliance paint as this does not have lead in it and 2)The sparks are due to a variety of things, but the most obvious, replace your main capacitor and HV diode. This combination is the normal culprit for arching. If it continues after that, the Magnatron needs replacement as well (Unfortunately, for first time diagnosis, electrical testing equiptment is needed.)
Jul 30, 2010 | Microwave Ovens
The paint in the cavity of my 6 year old microwave oven is peeling from the top. I don't know why. Is it safe to sand off the loose paint and touch it up?
Sand off the loose paint and make sure that there are no holes in the cavity. If there's holes the unit is not safe to use.
If it's just surface flaking, it should be safe to sand back with fine grade wet/dry sandpaper. We usually respray with automotive paint in a colour close to the cavity colour.
May 26, 2010 | GE Microwave Ovens
White bottom panel inside the microwave is peeling in two spots. What can be done if anything?
affected area would need to be sanded and re-painted with microwave paint. sells the paint
Feb 04, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Paint peeling
The paint you need is called microwave cavity paint. If they don't have it at your local hardware store, you may get it at
Be sure to sand the area first with some emory cloth to remove any loose paint flakes.
May 07, 2009 | Rival MT660 Microwave Oven
GE zmc1095 microwave beeps and indicates "HOT" in the display
If it stops heating it needs a new magnetron. our oven is less than 2 years old and has gone thru 2 magnetrons so far. Hoping to get some help from GE.
Jan 28, 2009 | GE JVM2050 Microwave Oven
GE Microwave JES1136 The paint is peeling off the left side of the turn table floor where the floor and wall meets. Will this cause a problem? The microwave was purchased in October of 2006.
Yes. If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Otherwise, arcing and deterioration can occur.
William E. Miller, AS-EET
Apr 29, 2008 | Microwave Ovens
Peeling paint
You need to thoroughly clean it, then sand it smooth to removew all the loose paint.
Once it's squeaky clean and dry, you can apply high-temperature appliance paint, which is available in brush-on or spray-on form at big box stores like Wal-Mart, home improvement centers like Lowe's and appliance parts stores.
Nov 02, 2007 | Rival MT660 Microwave Oven
Non-Stick surface peeling off inside microwave.
Normally you can strip and sand the old paint, get it squeaky clean, and use appliance paint. Yes indeed it is a heat-resistant enamel. You can get it from appliance parts stores, Wal-Mart, or home centers, etc. BUT if it's under warranty I would call GE Customer Relations with your model and serial numbers. They're at 1-800-386-1215 (8-6 ET) and I would also suggest you ask them for a referral to a GE-authorized servide center in your area. Good luck. I appreciate your thoughtful rating of this answer.
Jan 29, 2007 | GE JES1231 Microwave Oven
Microwave Ovens Logo
383 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
