Question about Whirlpool LSR5132PQ Top Load Washer
Washing machine wont stop filling with cold water
Whirlpool washing machine wont stop filling with cold water.
alot of sand in our water and the screen was not in the cold water inlet..
this problem was solved before by replacing blue inlet piece..is this a good diagnosis
Since you removed the screens, the sand probably has entered the valve and damaged the spool. It's apparently sticking open. You need to replace the complete valve and keep the screens in place.
Posted on Jun 09, 2008
New Whirlpool Cabrio delivered. Water inlet hookups have Red(hot)and Blue(cold) markers in the opening where I connect the water hoses. Should those be removed? No mention of them in the manual. Ed
No they are screens that stop sand or other stuff that maybe in your water system stops it from clogging up valve if you have well water and water fill is slow they may need cleaning they will pop out
Dec 07, 2016 | Whirlpool Washing Machines
Whirlpool #dp1040xtxb1 wont fill is my inlet plugged
If you select warm water wash, do you get warm, hot only or cold only? If temp OK, but fills slow one of the fill hose screens is clogged. If only hot or only cold the opposite fill valve solonoid is bad.
Aug 18, 2014 | Washing Machines
Water isnt going into the machine
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Dec 05, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Cold water does not come into machine
Hi, When the water is to be filling, do you hear the inlet valve humming? Remove the inlet valve hoses and see if there is any sand plugging the screen inside the inlet valve. If the inlet valve does not hum when the water is to be filling, you will need to replace the valve.
I hope this helps you.
Vic
Jun 26, 2009 | Washing Machines
Very slow cold water fill, why?
First make sure that you have adequate water flow from the hose bib coming from the wall. You can do this by turning off your cold water connection at the wall, then disconnect the cold water hose. Then turn the faucet on and make sure the water flows freely. The most common reason for your problem is a clogged screen where the cold water hose connects to the back of the washer. To check this, disconnect the cold hose from the back of the washer and clean the small screen inside the cold water inlet on the washer.
Jun 19, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Matsui dishwasher wont fill up with water
check your inlet filter at the tap source and behind the machine where the filler pipe enters. They changed some pipes in our street and fine sand filled our micro filters to the dishwasher.
Jan 04, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Whirlpool washer cold water takes forever to fill
your cold side on water valve may need the screen cleaned.if that doesnt help then you will need to replace your water valve.take hose off cold water side of water valve and you will see the screen.it may have alot of blockage.
Jan 04, 2009 | Whirlpool LAB2700ML Pedestal Drawer for...
Ge profile whsb8000bocc
Washer is most likely trying to fill with cold rinse water and the inlet screen is blocked or the cold water solenoid is bad. If you set washer to wash cold only it will not fill or fill very slowly. When you set it to warm or hot you are getting almost all hot. Clean inlet screen or replace inlet water valve.
May 12, 2008 | GE Profile WPSR3120WWW
Whirlpool top loader
You either have a defective pressure switch or water inlet valve. Start to fill the machine with warm water so that both solenoids on the water inlet valve (hot and cold) are activated. After about 30-60 seconds, push the timer knob in to stop water flow. If the water continues to flow, replace the water inlet valve. If this is the case, it may take a few times of starting and stopping water flow to allow solenoid to heat up and become symptomatic. If water flow stops abruptly each time knob is pushed in, you most likely have a defective pressure switch (water level switch).
May 09, 2008 | Whirlpool LXR9445JT Top Load Washer
Whirlpool washingmachine
Karen, start by removing the cold water hose to the inlet valve in back. It will have a screen in the inlet valve. Make sure the screen is clear of sand and debris. Start there and post back. Catriver.
Apr 22, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool LSR5132PQ Top Load Washer Logo
256 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
