Question about D-Link AirPlus Xtreme G DWL-2100AP 802.11g/b Wireless Access Point
Airplus xtreme g doesn't work
I followed all the instructions on setting this up, but it doesn't work.
When I connect it to power, the Power, WAN, and all four Local Network lights are on. No flashing lights of any sort. I've disconnected the modem like it ask, connected the cable from the modem to the WAN port in the back, and connected the ethernet cable to the computer and the LAN port 1. When I put the address it asks me (which is like http://194.34.0.1) <[that isn't it by the way] it doesn't work.
Any help would be much appreciated.
  • 2,794 Answers
I have have this happen before with D-Link routers. Check your ac adaptor for power. If there is power to the adaptor, then the power supply in the router is gone and needs to be replaced.
Mine blew up unexpectedly and I replaced it with a linksys.
Posted on Jun 09, 2008
Wep to wap. i want to do a hard reset
Connections All Ethernet Ports (WAN and LAN) are auto MDI/MDIX, meaning you can use either a straight-through or a crossover Ethernet cable. Pressing the Reset Button restores the router to its original factory default settings. Auto MDI/MDIX LAN ports automatically sense the cable type when connecting to Ethernet-enabled computers. The Auto MDI/ MDIX WAN port is the connection for the Ethernet cable to the Cable or DSL modem Receptor for the Power Adapter 5
Sep 20, 2011 | D-Link AirPlus Xtreme G DI-624 Wireless...
I was given an AirPlus Xtreme G Wireless Router and am now trying to do the set up, but I can't get onto 192.168.0.1 (when I type admin with no password the password screen just pops up again). I have...
Press RESET button for 10 seconds it is in back side of router .
Then all settings goes to defaults.
Then Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank or "1234"
Click on WAN settings and set those settings as your internet service provider settings.
Enable DHCP if you want to get ip from router.
Clickon wireless settings enable wireless then enable WEP Security then add WEP code .It isyour password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Then you can see configuration page of router.
Let me know if you need further assistance.
Thanks for uisng FixYa.
Apr 03, 2010 | D-Link AirPlus Xtreme G DI-624 Wireless...
Internet intermittently going down
Before going out and buying a new router, you should try reseting this one.
There should be a small pin hole on the back of the router, stick a pin in there to set it back to factory settings.
You can also check the WAN connection to make sure it isn't loose.
Thanks,
Pat
Apr 02, 2010 | D-Link AirPlus Xtreme G DI-624 Wireless...
I can't connect to the internet or router, only wan and 1-4 local network lights up
Check the power cable,try to connect it to a different power socket.
Change the powercable and check whether the power light is up
if still the same problem then it should be the hardware issue.
Contact the manufacturer or service provider if it is under warrenty
{If it is connected through USB and getting power from the computer itself then uninstall and reinstall the USB software}
May 26, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
Ok i do all the set up right when i turn off my dsl modem the turn it back on it says i dont have internet and wen i plug it in normaly it works i have the d-link di-624 air extreme ....i dont kno why does...
You need to power cycle your devices. Make sure the modem is connected to the WAN port of your router and your PC to port 1. Unplug the power to the router and modem. Wait for 30 seconds. Turn on the modem first, wait for the lights to be solid, then turn on the router. That should do it.
Apr 02, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
Lights are solid green: WAN, local network 1,2,3,4
If that is status of the lights on your router there's a big possibility that its already bad and needs a replacement, but you can first try to reset it and check if that will correct the problem
, To reset the router just press and hold the reset button for 30 seconds while the power is ON then after that check if the lights are back to normal if still the same light router is already bad...
Dec 01, 2008 | D-Link AirPlus Xtreme Super-G DI-624...
Laptop can see the desktop where access point is connected and yet not connect on internet
The way this should be connected is..
Modem connects to DWL-2000ap (wan port)
Peterscomp connects to DWL-2000ap via ethernet
Laptop connects to DWL-2000ap via wireless.
May 15, 2008 | D-Link AirPlus Xtreme G DWL-2000AP...
D-link airplus Xtreme DWL-G650 - hang up
hello!
-- who is your internet service provider
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
Apr 23, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
WAN settings
The WAN settings should be configured by Verizon personnel only. If you reset the VDI-604 or VDI-624 to factory defaults, you will need to contact Verizon to reconfigure your WAN settings.
Feb 16, 2006 | D-Link AirPlus Xtreme Super-G DI-624...
D-Link AirPlus Xtreme G DWL-2100AP 802.11g/b Wireless Access Point Logo
260 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
