Dehumidifiers
Problem for Dehumidifiers
Generic problem for all Dehumidifiers
Dehumidifier
By rmikey on Jun 09, 2008
Are you saying that it is working? If so, where is the water going?
Same Problem
Dec 20, 2008
-   The dehumdifier worked well when I first purchased it, but about 3 months after i purchased it, it stopped collecting water. This is a rip off.-   bderrick
Sep 14, 2008
-   plugged in, running not collecting water
-   rmlehman
Aug 21, 2008
-   Brand new. Was working when plugged in. Was connected by hose to empty into floor drain. Since initial setup, no water is being produced. It runs, lights are on, speed can be adjusted and humidity level can be set, but does not lower humidity and seems inaccurate.
What should humidty level be set at for normal basement living? -   Guest
Jul 05, 2008
-   The dehumidifier runs but doesn't collect water. I turned the humidity control to the lowest setting.-   slamb03054
Jun 12, 2008
-   Friedrich model d40c. Bucket is not collecting water.Motor is running and fan is working-   vatts
Popular Solutions for Dehumidifiers
Questions and Unsolved Problems for Dehumidifiers
Answer
I am looking to purchase an everstar airconditioner/dehumidifier. I was looking to see the value if... (More)
Answer
small basement efficiency that is not occupied during cold months, and accumulates mold and paint... (More)
Answer
After storing the HD880 for several years, it fails to start functioning. both red and green lights... (More)
Answer
I have a LG LHD45 EL dehumifier, which I purchased in Feb of 2008. I run it 24/7, and it is hooked... (More)
Answer
My BDH-651 is now (after 3 years) forming Ice at the top/front and the actual humidity percentage... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dehumidifiers Experts
Top Air Conditioner Repair
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
