Question about GE Dryers
Automatic drying is not working on GE Mod DPSR473EW0ww. I assume sensor may be defective. where is it located.
  • 868 Answers
Timer is not turning and you still have some heat coming into the dryer??Remove the vent hose from the dryer for 1 load .Is the timer moving now??Your vent is clogged up. Please Rate This !!
Posted on Jun 09, 2008
How do I find the moisture sensor in my GE dryer model number DBSR463EDWW?
open door and use flashlight look right at back wall , see those two chrome strips there , thats it!! use glass cleaner on them only , it wont stick inside and stink up your clothes from heating it
Mar 07, 2015 | GE DBSR453EBWW Electric Dryer
Service manual for GE DPSR473EW0WW dryer
the timer may be stuck at a certain place as they have points that at times tend to burn out and stick when the timer gets to that point. do the other settings work? some times the moister sensor will not sense dry clothes and keep running? as for ur drum noise that may be due to bad rollers or bad tensioner and belt depending on ur model and hopefully not bad bearings also a possibility
Jan 22, 2015 | GE Dryers
Ge dryer model dwxr473gt5ww s.n. ts750624a.my problem is no heat for drying.
it may be the thermal fuse on the blower housing thats open,the radiant sensor or the high limit thermostat located on the burner tube, or the boost and secondary coils on the gas valve body that are open or defective
Jul 28, 2010 | GE DBXR463GB Gas Dryer
Dryer keeps drying long after clothes are actually dry.
Bad timer most likely, remove power and check continuity on the timer motor. Verify movement of dial.
May 21, 2010 | GE DWXR483EBCC Electric Dryer
No heat during either drying cycle automatic
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Feb 15, 2010 | GE DVLR223 Dryers
Loud noise coming from bottom of washer during spin cycle
If it is a ge kenmore it sounds like your tub bearing is dry and needs to be replaced.The reason i say ge kenmore is because they fall under differant companys depending on witch year you bought it
May 07, 2009 | Whirlpool Inglis IP4400 Washer
Automatic dry feature of electric dryerr does not work
chances are you have lint on the sensor look inside the dryer in the front just in side the door you will see three or four silver wires about flush with the front housing wipe the off and try it if this fails contact a local appliance parts store with your model number and they can get the part num for it
good luck
bill
Jan 08, 2009 | GE Dryers
Frigidaire AEQ8000 dryer doesn't completely dry clothes
1. Gas valve coilsIgniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
Sep 15, 2008 | Frigidaire AEQ7000ES Dryer
Squeaky Dryer
the support rollers are drying out plz post your email i will send you the how to get to them and fix this you have to be handy though
Mar 15, 2008 | GE Profile Harmony DPGT750EC Electric...
Dryers Logo
142 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
