Question about Whirlpool RBS275PD Electric Single Oven
Just wanted to say THANK YOU, THANK YOU!
I had this problem and read through the threads and found your solution to this and it worked like a charm and just HAD to say THANK YOU, THANK YOU! I posted it as a solution within my own thread that I had attached to someone else that was having this same problem. Please let me know if I have to do something else to give you the credit that you so much deserve on this. And, again thank you for assisting those of us that need a little help along the way....
Here is what I posted:
Just found this posted by tech17 (THANK YOU SO MUCH!) and it worked!
i posted the solution under premium problems i don't know how that works but what you have to do is get a couple of nails pull the hinge on the door down far enough to insert the nails in the holes and let it rest against the door this will hold the door at the proper angle to engage the hooks inside the hinge slots on the body of the range grasp the door on each side and insert the hinges in each side to engage the hooks then open the door all the way and remove the nails
  • 1,314 Answers
A great reply like this is thanks enough we rarely get them but its no big deal most of us are here to help but you can post to this message and rate me after wards that helps my rating four boxes is great but thank you for your kind reply
Posted on Jun 10, 2008
How do you remove light bulb cover?
Just twist it off. I know that is easier said than done because they can be a pain. But if you turn it hard enough it will come off. I've seen suggestions about putting warm water on it to loosen it, an another said using an oil wrench on it worked like a charm.
Good luck
Jul 14, 2014 | Maytag CWE4800A Electric Single Oven
Top oven/grill. Element has dislodged from the screw connection. Attempted to screww back the element and there seems no thread for the screws to attach to the oven. What are my options?
Hello Michael Clift - I am happy to assist you. First, I will need your model number (and serial number if you have it) to better address the issue at hand. Thank you.
Jan 16, 2013 | Electrolux EOD6330 Ultrafan Electric...
F3 on display keeps on buzzing
hello there and thank you for choosing fixya
well this is the most common code of all the oven codes it is simply telling you that the temperature sensor is either not reading the temperature correctly or it is faulty all together so i would firstlook at the sensor to ensure that the sensor is good you can have it tested with a ohm meter and check it for continuity if found bad replace it which normaly is the case ok
Post me back with the make and model number and i can get yo the part number and price for this ok?
Best regards Mike
Feb 25, 2011 | Ovens
Oven does not work is reads F6E0 error code lost communition what's wrong?
I assume it's a KitchenAid that you have. Here you can find a previous thread about this code:
Oven repair in Santa Ana, CA
Appliance repair in Santa Ana, CA
Jan 24, 2011 | Ovens
Admiral designer series gas stove flashing f5 error
Hi There
i look up your codes for you and found it. you can read this and i hope this gets you in the right direction.
F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC)Thank you for writing to fix ya.
Best Regards Richard
Dec 23, 2009 | Ovens
Frigidaire Gas self cleaning - lock won't release/door locked
Hold the lock button for 3-5 seconds or Find the main circuit breaker for your oven. Turn it off for fifteen minutes, then flip it back on. This should allow the door to open. Another thing sometimes, the dial for self clean will hang up, but this should fix it.goodluck hope this helps
pls appreciate by rating as fixyaa. thanks
Dec 23, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Display light
Found out that I could replace the C3 capacitor with a 100uF 35V (high temperature - 105 C). Spent $1.69 for the capacitor and 1/2 hour taking the unit out, soldering the new capacitor in, and remounting the upper clock unit back on the oven. Works like a charm. No need to buy the whole Clock/Temp unit, waste of money.
Aug 13, 2008 | Jenn-Air W30400P Stainless Steel Electric...
Ge profile double overn
This is a common problem. I made this fix 2 years ago and it works like a charm.
Jul 19, 2008 | GE Profile JTP56 Electric Double Oven
326B1230P001 GE TrueTemp Black Oven Error Code F0
We had the same problem with our GE Tru Temp Oven and the fix worked like a charm! Thank you for posting this fix - you saved our dinner party!
Jun 21, 2008 | GE JKS05 Electric Single Oven
Whirlpool RBS275PD Electric Single Oven Logo
59 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
