Question about Soundstream PCA2000D Car Amp
Soundsream pca2000d car amp the is getting power but no sound. i had 3 10" jl audio w6 hooked up to it. it quit working about a month ago. i tooked it to a local repair shop they said i need to send it back to the manufacturer because it requires a special tool to fix it. what kind of tool are they talking about?
    Habit-Forming:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 125 Answers
It's sounds like your audio outputs are dead which require an oscilloscope to test , Check your audio connections to the unit , Did they check the speakers ?
Posted on Dec 11, 2017
2 Suggested Answers
  • 631 Answers
SOURCE: soundstream ribcom500
You can get the schematic from SoundStream. If you get the schematic and need help, email it to me at:
babin_perry@yahoo.com
If the amplifier does nothing, post the DC voltage on each of the pins of the SG3525 (or whatever IC they're using in the supply). Use this as a template:
Pin 1:
Pin 2:
Pin 3:
Pin 4:
Pin 5:
Pin 6:
Pin 7:
Pin 8:
Pin 9:
Pin 10:
Pin 11:
Pin 12:
Pin 13:
Pin 14:
Pin 15:
Pin 16:
Posted on Nov 09, 2007
Jl 500x1audio comes on but turns off after a few sec powering 1 w6 jlaudio
There is a internal problem with it.Or it is not hooked up poperly.
Nov 27, 2012 | Jl Audio 250/1 Car Audio Amplifier
JL W6 ohm wiring issue
Parallel , all positives together , all negatives together . With 4 ,4ohm voice coils in parallel you get around 1 ohm .
Apr 23, 2012 | Jl Audio Car Audio & Video
I cant get my jl audio w6 10s to give off much bass with the jl audio 500/1 amp
here is a manual for your subwoofers: http://mobile.jlaudio.com/pdfs/8-12W6_BDS.pdf
use the wiring diagram for 1.5? (1.5ohm) with 2 speakers. the diagram for 3 speakers will not work, because it would bring the load down to 1 ohm, and the amp cannot go below 1.5 ohm.
to set up the amp:
under "preamp output section", on the "output mode" switch, select "amp filter"
to set up the levels: start with the amp gain pretty far down- with the input voltage on low for line level outputs from the deck, and on high for speaker outputs from the deck. now turn your cd deck as far up as it will go until it distorts, then turn the cd deck down to just where it stops distorting. now, you can start to turn up the gain on the amp.
on the filters, youll prolly want the cutoff filter around 100hz @ 24db slope. start with the infrasonic filters off, but, if you do get into them, try centering between 30 and 60hz on either, and, possibly dropping the cutoff filter to 80hz.
Jan 31, 2011 | Jl Audio 500/1 Car Audio Amplifier
Can you push a w6 with a 1500 phantom boss amp?
I can assume that phantom 1500 is a 1500 watt amp? but still the amp will have more than enough power to push a w6, w7,and even in pairs. Single w6 can handle 600 watts rms, thus you will need to turn the gain all the way down so that the speaker won't over powered and that can lead to breaking the sub.
Dec 12, 2010 | Jl Audio 12W3 Car Subwoofer
Got jl300/2 amp confused which subwoofer sounds good
Hello drsubhakar26,
JL W6's will perform well with from 150-600 watts RMS. W7's with from 150-500 watts. Less expensive Alpine Type R's work OK with from 200-500 watts RMS. Either of the brands will sound good. None of them will perform to their full potential with 300 watts RMS. Powering any sub with a 2-channel amp is a compromise. A monoblock is more efficient.
Hope this helps.
Jul 12, 2009 | Jl Audio Slash 300/2 Car Audio Amplifier
Jl audio w6 surround repair
If you're willing to do the repair yourself, there is an Internet site - Simply Speakers -that sells repair kits for speakers ,including speaker surrounds.
I did two 10" drivers and it worked 100%. ..
Jun 05, 2009 | Jl Audio 12W3 Car Subwoofer
Need a new surround for '96 JL AUDIO W6 12"
Call Jeff at California Sound in Wichita, KS 316-686-2254. He is a JL expert!
Jul 20, 2008 | Jl Audio 12W3 Car Subwoofer
How to connect it
bridge the amp and wire the JLs in parallel..then put some earplugs on ..lol
Dec 23, 2007 | Jl Audio 1000/1 Car Audio Amplifier
Ma120xe sound horrible
Make sure that you have the subs wired in a 4-ohm series and not a 8-ohm load
Dec 14, 2007 | MA Audio MA 1200XL Car Subwoofer
Soundstream PCA2000D Car Amp Logo
65 people viewed this question
Top Soundstream Car Audio & Video Experts
Joseph Gallucci
Jerry Umali
Are you a Soundstream Car Audio and Video Expert? Answer questions, earn points and help others
