Question about Bose Wave Radio
Display stays in dim mode AWR1-1W (later version) brief power outage
We experienced a brief 1 second power outage a couple of nights ago caused by a nearby lightning strike. Ever since that event the display in my BWR has remained very dim so it is really difficult to read it in daylight or at night. Everything else works as it should. Without a schematic it’s hard to trace back the problem. It could be the light senor or the LED driver. Any suggestions?
  • Anonymous Jun 16, 2008
    Had the same problem. To fix, hold down the CD mode button and press the volume up button. Adjust to desired brightness level.
  • rmangambu Jun 28, 2008
    Yes, almost same situation. A brief power outage and the display remains very very dim. Does not adjust anymore as outlined in the manual. Did the earlier writer get the problem solved? If so can u pls let me know how. Thanks
Hold down CD mode button and press volume button.
Posted on Jun 16, 2008
    Genius:
  • 1,036 Answers
Yes I think you're right.
You are lucky this is all it is.
Bose do not seem to supply spare parts direct to the consumer, and I'm afraid lightening isn't covered in their warranty. If you want to return the unit to Bose, first you need to call them to obtain a Return Material Authorization (RMA) number. This number helps them track the status of your product. In the United States, call 1-800-367-4008. Monday through Friday, 8:30 AM to 7:00 PM ET and Saturdays from 9:00 AM to 3:00 PM ET. International customers, click here to find the facility closest to you.
Have the following information available when you call:
  • Product model and series number, if applicable
  • Serial number(s): Please note that Lifestyle® systems have separate serial numbers for the music center and Acoustimass® module
  • Date of purchase
  • Details of the problem you are experiencing
  • If your product is no longer covered under warranty and you plan to send it to Bose Corporation for repair, please have your credit card number available.
Alternatively - find another damaged system with a different fault, and swap assemblies.
Hope this helps.
Posted on Jun 13, 2008
Whirlpool WRF560SEYB Refrigerator did not turn back on after power outage, display said "cooling off"
Sounds like you had a power outage?-- did the lights go dim for a few minutes, before the power actually went out?-- Sometimes, low voltage will cause the compressor motor to over heat-- so it might have to 'cool down'-- What happened next?-- Did you try it again an hour or so later/-- Tell us more-- Mack B
Nov 03, 2013 | Whirlpool WRF560SEYB 30" french door...
After a brief power surge our Vingcard 2800 stopped encoding, what do I need to do to fix?
WE HAVE POWER OUTAGE FOR 1/2 HOUR AND THEN AFTER WE TRY TO RESET OUR VINGCARD 2800 AND FOUND BLACKOUT ON SCREEN. WE CAN SEE, IF U TRY FROM ONE SIDE UNDER THE KNEE.
Aug 14, 2012 | Office Equipment & Supplies
Rheem Power Vent 50 gas water heater will not come out of vacation mode! Have tried turning on and off, resetting and following directions on the side of the tank. Will not come out of Vacation Mode. Had a...
Water inside tank-type water heater can remain hot for some time.
That's one advantage of well-insulated tank-type water heaters.
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
Power outage can be related to failure of gas control.
Unplug stuff when power goes out. And then plug back in after power is restored.
Water heaters with electronics are not protected from surge.
Electronics can blow out during and after power outage. For example nearby lightning strike will cause current to run along household wires. With ordinary power outage, once power is restored, the surge can affect all kinds of electronic circuitry such as timers, water heaters, water softener, treadmill etc.
Sounds like you have intellivent gas control valve:
Open following link to identify gas control, and download typical manual, and download intellivent service manual with troubleshooting, error codes, etc.
http://waterheatertimer.org/How-to-adjust-temperature-on-water-heater.html#intelli
Take a moment and vote on answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Aug 26, 2011 | RHEEM 50 Gallon FVR NATGAS Water Heater...
We had a pwer outage last night and my comuter shutdown. This morning when I turned it back on the monitor will only stay on for about 15 seconds of inactivity before going into powersave mode. How do I...
The monitor goes to power save because no signal is coming from the computer - this means that the computer was fried by the power surge that caused the outage. To find out what was fried inside the computer you must open it and test its components one at a time, starting with the power source - time to take it to someone that has other parts to test it, or to an repair shop.
Apr 20, 2011 | Lenovo Computers & Internet
T.sonic 610 MP3... Problem:
sir, for switching on the device u need to hold the play button for a couple of seconds.if ir is switching off after some time, then it means the power is not sufficient. you need to charge it well.
May 28, 2009 | Transcend T.sonic 610 MP3 Player
Power Outage & Now Wii Won't Power Up...
When this same thing happened to me, I unplugged the Wii power supply from the wall (not just from the back of the Wii) and let it sit unplugged for about 10 minutes. When I plugged it back in, everything was fine.
Nov 11, 2008 | Nintendo Wii Console
Wave Radio-dial face,display very dim.
Our Bose did the same thing after a power outage. This one doesn't have a CD button, so we tried holding down the Clock button and used the volume control and that seems to have fixed it.
Mar 23, 2008 | Bose Wave Radio
Tv won't come on
Sounds like the typical power surge created by the outage has caused a power supply problem inside your TV. IF that is it, there not much you can do yourself.
Nov 07, 2007 | Televison & Video
Samsung RS2555SL humming noise
don't know this model specifically, but have had loads of problems with these samsung fridge-freezers. the no water in drinks dispensor is probably due to the water bottle at the bottom of the fridge being frozen. this is endemic with samsung the noise you hear is ice hitting fan. samsung use two systems for fan. the one i think you have is separate fans for fridge and freezer and a separate evaperator for fridge and freezer. take of the back plate of the fridge and you will find the fan mounted in it. disconnect the plug and socket connection. you will probably find ice build up round the fan blade. melt off with hot water. the bar you had showing on the "8" is a fault code - the most common fault being the defrost termination sensor. unless you are experienced, this is not really a diy appliance
Apr 02, 2007 | Samsung 26 Cu. Ft. Side-by-Side...
Oven display won't work
rmedrano, Try pressing and holding the stop-time and cancel pads together for 5 seconds, see if it comes back to life. If not, try the cancel and clock keypads together for 3 seconds. First is the control lock-out funtion and the second is the display blank mode. If these fail to work, you are going to have to test for power at the board. The clock (ERC) has a 3 year warranty incase you have to call for service. Catriver.post back.
Dec 16, 2006 | Maytag MES5770 Electric Kitchen Range
Bose Wave Radio Logo
530 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
