Question about GE Heating & Cooling
Hvac not getting strong air flow from vents
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
When was the last time you checked your filter? Suppose to be changed every 30--90 day , depends on the type of filter .If you remove the filter and the same low air flow, then the dirt and dust went to far and need a full serviced on your system. (koolbreezes74401@yahoo.com.)
Posted on Jun 09, 2008
How to repair auto a/c problem. A/C not blowing from dash vents, only. Issue occurred immediately after replacing a bad battery.
When you change air flow direction from defrost ,to floor ,to vent . does air flow change ? Where is the air coming out of ? Does it stay there ?
Oct 02, 2016 | 2004 Chevrolet Chevrolet TrailBlazer LS
Why is hvac air coming from all three locations (vent/floor/defrost) regardless of switch setting?
Check air box if it won't change air flow some thing is wrong there inside the car
Jul 14, 2014 | 2000 Buick Regal LS
Have a 2003 gmc yukon that blows air out of the vents but will only blow cold air
Coolant in system ??
Coolant flowing through 'Heater Core' ??
Code(s) present w/Scanned ??
Possible HVAC issue(s);Blend air door n HVAC box (Under Dash)-Temp Actuator-HVAC control head @ dash.....
Feb 15, 2014 | 2005 GMC Sierra
Odyssey air conditioning
HVAC Vent Doors under the dash- need to be diagnosed
One is not operating- to switch the air flow
HVAC Vent Door Motor or Vacuum Motor
which ever type you have
Jul 18, 2013 | 2005 Honda Odyssey
I have a Maytag Quiet Plus ll Model # MDE9806AYW. We found water in the dryer vent. Do you have any idea what could be causing this?
A plugged outlet vent. Start the dryer and go outside and check the vent. It should have a strong air flow. It the air flow is not strong check all the vent tubing and the outside vent.
May 31, 2011 | Maytag Dryers
HVAC vent selector does not function. Air flow is
THe blend door seems to be stuck. When you change settings from defrost to floor air or, vent, the blend door opens and closes directing the air to the place you want it to go to. I have had some success spraying a lubricating oil such as WD40 under the dash on the blend door. You need to get under the dash with a flashlight to locate it. It looks like a flap. Spray it with a couple of shots of the WD40. Go easy on the spraying as you may be inhaling the fumes. Keep the doors and windows open to minimize the fumes. Wait about 1/2 hour and try the A/C functions. (defrost, floor, vent air)
Mar 09, 2009 | 2002 Buick Rendezvous
Maytag gas dryer doesn't dry properly
SOUNDS LIKE A RESTRICTION IN THE VENT. CHECK AIR FLOW WHERE VENT EXITS HOUSE. IF IT IS NOT STRONG, INSPECT VENT LINE BEHIND DRYER. IS IT CRUSHED OR CLOGGED WITH LINT? THIS WILL CAUSE DRYER TO SHORT CYCLE. IF VENT IS NOT CLOGGED, CHECK AIR FLOW AT BACK OF DRYER WITH VENT DISCONNECTED. IS AIR FLOW STRONG? OF NOT, PROBLEM IS WITH BLOWER.
Jan 27, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Air flow weak when set to heat
check for dirty cab air inlet or "HVAC" filter, or heater core is plugged from debris and air is being restricted and wont blow through. it works like a radiator, air ducts can also be getting stuck.
Jan 06, 2009 | 1983 Toyota Camry
2004 Ford Crown Victoria no air flow through main air vents
Chances are the electronic/digital HVAC control unit is bad. This same problem happened to me and I had to replace the entire unit. The dealer wanted to charge $800 for just the part! After I freaked out on them, they found a used one for less than half. Sorry, but there's no easy fix here.
Jun 26, 2008 | 2004 Ford Crown Victoria
Heating & Cooling Logo
55 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Lawrence Oravetz
richie46
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
