Question about Whirlpool Kitchen Ranges
Whirlpool Electric Range #GR395LXGQ2
Lightning strike near the house...all fuses in hoiuse tripped...when power finally back on the display reads...large lower case "a" with a small "?" question m,ark and the word "ON'...burners work but oven doesn't and didplay won't change...I pulled the plug to reset and no difference...can I fixz this thing?
  • smjudd Jun 09, 2008
    OK...helpful
  • 770 Answers
You got to be kidding me you did not rate me as helpful??
Posted on Jun 09, 2008
  • Gary Davd
    Gary Davd Jun 09, 2008
    In the chat session
Control board sparks, smokes and smells when trying to start
Did you have a lightning strike near by? Or power outage with a power surge. Could have shorted the board.
Mar 13, 2015 | Maytag Epic MGD9700S 27 7.3 cuft. Gas...
Clock,timer and oven does not work on Kenmore gas Range
Let me know the model# and ill see if there are any thermal fuses. If not than most likely you will have to replace the EOC (Electronic oven control). Available at www3.sears.com
Oct 04, 2007 | Kitchen Ranges
Where are my electric stove's fuses located (if that is indeed the problem)?
The electronics were probably destroyed by the lightning strike.
Heating elements can withstand voltage surges but not the more sensitive electronics.
The oven is controlled by the timer but none of the top burners are. Using the Brand name and Model number you should be able to buy parts. The controls may all on a single board.
Aug 22, 2014 | Kitchen Ranges
Will a nearby lightning strike cause a power board failure?
It could happen yes it would depend where the strike entered the TV. Not all lighting strikes hit on the electrical lines, on a TV they can come through the cable, as well as a antenna if you have one hooked up.
May 10, 2014 | Samsung UN32EH4003F
Oven will not light
yes this is most likely do to the lightning i have been to a couple houses hit by lightning that all of the appliances were shorted due to lightning try first unplugging the power cord then replug to see if you can get it to trip back to the normal fuction mode most of the time this does not work most likely your main control board has shorted out due to the lightning most of the time this is covered under you homeowners insurance if you rent then you can speak with the landlord. your other option would be to open the unit and find every shorted spot which might get a bit costly hope this helps
Jul 18, 2010 | Whirlpool Kitchen Ranges
Lightning strike power surge partially disabled dryer.(Whirlpool)
If it took a lightning strike something in the heating coil is shorting to ground tripping the breaker. DO NOT Keep trying it, you could cause more damage or even burn your house down.
Sep 29, 2009 | GE Profile Harmony DPGT750EC Electric...
We had a near lightning strike and now my tv (sanyo model ht27744)doesn't want to come on.
Lightening may have caused a surge on your power lines to the house and to the outlet the TV was on.
Do other things work on that outlet? If not you tripped a power breaker.If they do work check this.
Unplug the TV for 2 min or more and plug back in.
Try bypassing your surge protector you had it plugged into. It could have died when the lightening struck.
(no surge protector?) Bet you'll buy one for your next TV.
Look for 3000 joules and up rating for a surge protector and insure it has protection for a cable/antenna input too.
If this doesn't work the TV may be fried or internal fuse blown.
Time to take it to a repair shop or depending on it's age (5 years+) it may be time to buy a new TV and surge protector.
Near Lightening strikes can effect appliances from several inputs that could be affected from outside like Power, Cable, Antennas, Phone Lines that come into your house.
Jul 06, 2009 | Sanyo Televison & Video
Heating eliments do not heat up
Did the electrical service power go out, or did the display on the oven go out?
If it was the display, then make certain the breakers didn't trip or fuses blow feeding power to the unit. If they are both good, and the display is still not lighting up, the unit may have blown a thermal fuse, usually located near the control head. This failure could be caused by a number of things (it happened that my KitchenAid had a service bulletin and modification kit to replace the blowers and reroute the wiring).
Please reply you findings and I wil help you more.
Jan 24, 2009 | Whirlpool RS696 Electric Kitchen Range
Kitchen Ranges Logo
121 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
