Question about Ovens
Pf code on frigidaire professional series free standing range
On this free standing gas range what does "PF" code mean ?
  • 1 more comment
  • harvinder60 Aug 03, 2008
    My Frigidaire professional series duel fuel stove was beeping and as per the user manual I was required to clear it but pressing "Stop". But that did not work. In order to stop the beep I shut the power off. Now (with power turned on) the beeping has stopped but PF error is displaying and I am unable to clear it and hence am unable to use any of the buttons on the panel (so oven is not working but gas is). Please help!
  • Anonymous Jan 26, 2009
    When ever my oven goes to cool down a PF code pops up on the display. This keeps happening over and over. I can press clock to reset the clock and it seems to take the PF code of the display until the next time I use my oven and it goes into the cool down mode.
  • Anonymous Mar 07, 2009
    i was cooking cake ,i look up and my oven showes pf what do i do
  • 413 Answers
"PF" indicates the electronic control detected a Power Failure.
This could have been caused a brief power outage OR may be an indication that the connections to the oven, either at the stove or at the plug are loose.
Posted on Jun 10, 2008
Press and hold the Clear/Off button for three seconds . A beep wil sound and Door Loc will flash until the door unlocks. That's what my maual says. Not sure if we have the same oven...
Frigidair Pro series.
Posted on May 09, 2010
The "lock" light came on and my oven door will not open. I do not have an owners manuel as we just
bought the house and the previous owners did not leave one. The previous owner suggested that we
unplug the stove and replug it. This has not helped. Can you tell me what to do?
Posted on Sep 16, 2008
My oven is always flashing PF what does that mean
"PF" stands for Power Failure. There should be a reset procedure in your user's manual. I cannot specify this since you don't give the manufacturer or model number of your oven.
Jun 24, 2015 | Ovens
What does the message PF mean?
PF = Power Fail. Possibly damaged control board.
Dec 23, 2014 | Whirlpool 30" Self-Cleaning Freestanding...
Superba model: YKEBS208DB3 electric sove shows code PF. what does this mean?
PF stands for power failure, just hit cancel and reset clock.
Good Luck, I hope this helped.
Nov 27, 2013 | KitchenAid Architect Series KEMC308KSS...
PF code
Depending on manufacturer and model, PF can mean a number of things. On my stove, PF simply indicates "Power Fail" Yours may, too. You can clear this generally by updating the clock display. To verify that PF does indeed mean power fail for your stove, simply shut off the power for the cicuit than supplies the stove. This can be either circuit breaker or fuses. Turn the power back on after 5 or more seconds and if it displays PF again, you know it means power fail.
Otherwise, please provide the manufacturer and model of you stove for an answer.
Jul 02, 2012 | Ovens
Range won't heat up
it is a glow coil , thermocouples are on units with a free standing pilot that you have to light, if you have a range like this you may need a thermocouple if not a free standing pilot you have a electronic gas iginition system that uses a glow coil, you turn on over setting and oven glows orange then iginites if this is what you have you need new glow coil, easy to repalce
Feb 03, 2010 | Magic Chef 9122 Gas Single Oven
Kenmore gas Range -- Control Panel not working
Hi. your assessment is correct. when you have normal operations with the stove top and the control panel is blank or non operational, this will confirm either a wiring harness issue or a dead control circuit board. The wiring harness can sometimes become lose or the connectors can become corroded but, in this issue, i am sure its the ECB(electroninc control board). In this case, you will have to replace the board it self.
Please rate and god bless:)
Apr 16, 2009 | Kenmore 33464 / 33465 / 33469 Gas Single...
PF on my gas range?
PF is the nearly universal code for Power Failure. Most of the time, you will see this if you had just a momentary power interuption. Just clear it and don't worry about it.
Please don't rate this, as anything but a FixYa lowers my score, and for the most part, we do this all for free, so ratings are our reward.
Dec 10, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
Whirlpool electric range RF361 bxdn 0. error codes? PF?
hi Jon
look on the back of the unit, there should be an envelope that has a paper in it, that paper should tell you what the code means.
Apr 01, 2008 | Ovens
Ovens Logo
4,453 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
