Toshiba Equium 5200D
I was trying to install Windows xp pro and when it starts installing it asks for cd 2 and then it won't do anything so I just cancel it and then try again and when it goes to second screen it says CMOS Time and Date not set then asks what I want to do do F1/setup, ESC/to boot, or F2/option rom screen I have gone through everything and nothing its still the same so how would I format to go back to clean slate and just reinstall windows 98 or can I even do that?
    Sergeant:
    Champion:
  • 326 Answers
When U boot up on the XP cd it gives U the option of reformatting with a fresh install.
Posted on Jun 09, 2008
Setup did not found any hard disk installed+toshiba s100-s1133. While trying install windows xp
SATA HARD DRIVE - XP INSTALLATION
The problem is that XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
Oct 06, 2012 | Toshiba Portege S100-S1133 Notebook
How can i restore a toshiba equium l20-197 back to factory settings
System restore will not do what your asking.
However there is a way but you will need a Installation cd Assume you have Windows XP
Then you need to borrow or buy a Windows XP Home Edition or Pro
You can buy one used from Ebay.
There are two options !.Repair install this will save all files/data on your hard drive.
Follow these instructions to Repair install.
Boot the computer using the XP CD.
You may need to change the boot order in the system BIOS so the CD boots before the hard drive.
Check your system documentation for steps to access the BIOS and change the boot order.
When you see the "Welcome To Setup" screen, you will see the options below
This portion of the Setup program prepares Microsoft
Windows XP to run on your computer:
To setup Windows XP now, press ENTER.
To repair a Windows XP installation using Recovery Console, press R.
To quit Setup without installing Windows XP, press F3.
Press Enter to start the Windows Setup.
Do not choose "To repair a Windows XP installation using the Recovery Console, press R", (you Do Not want to load Recovery Console).
I repeat, do not choose "To repair a Windows XP installation using the Recovery Console, press R".
Accept the License Agreement and Windows will search for existing Windows installations.
Select the XP installation you want to repair from the list and press R to start the repair.
If Repair is not one of the options, END setup.
After the reboot
Setup will copy the necessary files to the hard drive and reboot.
Do not press any key to boot from CD when the message appears.
Setup will continue as if it were doing a clean install, but your applications and settings will remain intact.
2. If you want to do a clean install that will completely wipe your hard drive clean then follow the instructions from this site http://www.winsupersite.com/showcase/win...
You will then need to reload all Microsoft Windows Updates and find all other drivers and software from http://uk.computers.toshiba-europe.com/c...
Then wham bam you should be back in business.
hope this helps
Sep 27, 2012 | Toshiba Equium Computers & Internet
Hi i have a Toshiba Satellite Pro L300 i have reformatted the hard drive and am trying to instal windows xp Professional Genuine CD. I can access bios utility no problem and i start install for winxp it...
This because you dont have AHCI drivers required for Win XP and you set in BIOS either sata controller or ide controller to an AHCI. You must set to native IDE or anything else like that.
If you wish set an AHCI driver you must press F6 during starting windows XP setup. And put the drivers (get it here) to floppy disk, it will prompted to install required drivers..
Another way to install driver without floppy disk you must inject the driver to windows XP installation CD...
P.S : you cant put the drivers onto floppy, because it wont be read by Windows XP setup..
Aug 08, 2011 | Toshiba Satellite Pro L300 Notebook
No sound device after installing windows xp service pack 2
I think you didnt installed sound driver/ audio driver. So you just install this that the CD you got with motherboard. and restart system it will work..
Hope you will succeed...
Nov 25, 2009 | Toshiba Equium 3200M (PV1058U-4CNS2) PC...
I need to reboot my toshiba equium l10-300 laptop with no cd
Try starting in safe mode. Hold down oth the control and F8 kays and press power. Do not release Contro & F8 until it starts to beep. Then it shoud start in safe mode. If the computer will not start in safe mode you have a hardware problem. If it starts in safe mode, you have a Windows problem that re-installing Windows will solve that (to a point). Without the Original CD and install code, you have two options. Buy a new OS or.......pirate it. I do not recommend the last.
May 28, 2009 | Toshiba Satellite L10 Notebook
My equium ea60-155 needs to be reformated ; can i use xp install
Loading XP back on isn't the problem, it will be the chipset drivers that you will need for your onboard graphics, sound etc... before you format and load XP back onto your laptop contact Toshiba for the chipset drivers for your laptop.
If XP is causing you problems, why no repair the verison you already have on there? If you put the XP disk in when given the choice to press enter to install or 'R' for repair. Press R. It will replace any corrupted files to your system with new ones.
I hope this helps.
Nov 11, 2008 | Toshiba Satellite A60 Notebook
How to install XP in toshiba Satellite L45-S7423 laptop
you have to use a standard windows start up disk with cd rom support like win 98 works well so the computer will recognize a older version then insert it and boot the computer with the operating system that u want to install but be advised if you have a warranty on the machine you will void the waranty i found out the hard way i had xp on my toshiba laptop and i put windows me on it couple of months later i had a cd rom issue and sent it to the manufacture and found out that the waranty was voided because i put a different operating system on the machine
Aug 14, 2008 | Computers & Internet
I am in need to install recovery console
Here's How:
Boot From the Windows XP CD
To enter Recovery Console in Windows XP, you will need to boot from the Windows XP CD.
  1. Watch for a Press any key to boot from CD... message similar to the one shown above.
  2. Press a key to force the computer to boot from the Windows CD. If you do not press a key, your PC will continue to boot to the Windows XP installation that's currently installed on your hard drive. If this happens, simply reboot and try to boot to the Windows XP CD again.
Press R to Enter Recovery Console
When the Windows XP Professional/Home Setup screen appears, press R to enter Recovery Console.
Choose the Windows Installation
The Recovery Console is now loading but needs to know which Windows installation to access. Most users only have a single Windows XP installation so the choice is usually clear.
To the Which Windows installation would you like to log onto question, press 1 and then Enter.
Enter the Administrator Password
The Recovery Console now needs to know the administrator password for this Windows XP installation. Unless you are using a PC in a sizable business network, the administrator password is most likely the same password you use to access Windows XP on a daily basis.
To the Type the Administrator password request, enter the password and press Enter.
Note: If you do not have a password or Windows XP normally starts without asking for one, simply press Enter.
Make Necessary Changes in Windows XP Recovery Console
The Recovery Console is now fully loaded and the cursor should be sitting at the command prompt, ready for input, as shown in the screen shot above.
Make any changes necessary in the Windows XP Recovery Console. When complete, take out the Windows XP CD and type exit to restart the computer.
  1. When you reach the command prompt (detailed in Step 6 in the link above), type the following command and then press Enter.
    bootcfg /rebuild
  2. The bootcfg utility will scan your hard drives for any Windows XP installations and then display the results. Follow the remaining steps to add your Windows XP installation to the boot.ini file.
  3. The first prompt asks Add installation to boot list? (Yes/No/All).
    Type Y in response to this question and press Enter.
  4. The next prompt asks you to Enter Load Identifier:.
    This is the name of the operating system. For example, type Windows XP Professional or Windows XP Home Edition and press Enter.
  5. The final prompt asks you to Enter OS Load options:.
    Type /Fastdetect here and press Enter.
  6. Take out the Windows XP CD, type exit and then press Enter to restart your PC.
    Assuming that a missing or corrupt boot.ini file was your only issue, Windows XP should now start normally.
Show your appreciation by rating it.
May 26, 2008 | Toshiba Satellite A135-S4527 Notebook
Remove Vista OS and Replace With XP Pro
1. make sure your laptop is set to startup from a cd
2. after laptop finds the bootinfo from the cd and asks you to press any key to start from cd, press any key and xp setup will start.
3. in xp setup your going to need to delete your vista partitions, preferably all partitions and then proseed to install xp into a new partition.
4. proseed with the windows setup follow the instructions and configure your settings as you wish.
Mar 17, 2008 | Acer Aspire 5100 Notebook
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
