Question about Whirlpool Washing Machines
My whirlpool washing machines cold water is not shutting off..had the problem before and where the water connects to washer became deffective.is this a good diagnosis?
  • dgaede Jun 09, 2008
    problem solved thanks
  • 868 Answers
Replace the Water valve and your problem is gone. Please Rate this solution !!!
Posted on Jun 09, 2008
Whirlpool washing machine does not rinse just a buzzing noise
The buzzing is the water valve, the timer is sending power to the valve but no water is coming out. I would set to wash and as it is filling up change the water to cold then to hot while it's filling. I bet either cold or hot will buzz (usually hot). Once you determine which (clod or hot) shut that supply off, take that water line off the washer, put the end in the washer and turn the supply back on. If water comes out then look inside the valve where the hose connects, it could be clogged. If you have water going to the valve and you don't see a clog then the problem is inside the valve...replace valve.
Oct 21, 2014 | Whirlpool Washing Machines
How do i find out whats wrong with my washing machine? The brand is whirlpool heavy duty
check for a clogged filter screen on the cold side of the water inlet valve,the cold water shut off, or the hose kinked
good luck
Feb 28, 2013 | Whirlpool Clothes Washer Heavy Duty...
I have a wtw5800swo washer. The washer will complete the wash cycle, but then shuts off and will not enter the rinse cycle.
Be sure to guarantee that BOTH hot and cold taps are turned on. Commonly, the hoses get reversed, and dad turns off the hot water (due to high bills) and the hot is connected to the cold tap, which is used for rinse, so the machine will wait forever for the water...
Apr 07, 2011 | Whirlpool WTW5850S Top Load Washer
Hi. I've just been loaned a Whirlpool awm 5125/4 washing machine (while mines gone for repair), but it has on the back of the machine, a hot inlet and a cold inlet. My machine only requires a cold water...
Your machine can be connected for cold fill only but, you will need to connect a "Y-Piece" for it to work:
The tail of the "Y" attaches to the cold water valve on your pipework. You then attach both hot and cold water hoses to the branches of the "Y" and connect both hot and cold water hoses to your washing machine. The wash cycles will take longer when connected this way as the machine has to heat the water internally. It will also be less energy effecient.
Please post back if you need further assistance.
Regards,
BElectric
Dec 11, 2010 | Whirlpool AWM5125/1 Front Load Washer
I need a washing machine that I can set for cold tap water
just shut off the hot water at the faucet and you will get 100% COLD water I guarantee this on any machine you buy
Nov 18, 2009 | Whirlpool GSW9800PW Washer
I've just moved house and my machine is not
Hello Friend, I think your machine will work properly if you add a water line splitter. You would connect to the single cold water tap and on the other end you would have two water hoses . Connect one hose to the cold water inlet of your washer and then connect the other hose to the hot water inlet. You can get these at Home Depot. Happy to help, Tim.
Jun 29, 2009 | Whirlpool Washing Machines
Cold water in the rinse cycle of the washer just trickles
Sounds like cold water solenoid is not opening all the way, its easy to replace, and is found inside the wash machine where the hose connects
Apr 25, 2009 | Whirlpool LSQ9600L Top Load Washer
Maytag performa washer hot water runs continuously
Littleone.. please check your instructions.. some washers now dont need Hot water connection to them...they heat their own as part of the efficiency settings on the wash programmes themselves!
Regards Faggly
Mar 19, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Cold water doesn't shut off
time to replace your water (mixing) valve. the diaphram tht regulates the water is wornand will no longer close causing the water to continually come in
Oct 11, 2007 | Washing Machines
Washing Machines Logo
19 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
