Question about Kenmore 62802 Electric Dryer
Kenmore dyer my gas dyer will not start
I have a kenmore gas dyer, it will start to dry then go out and just run. you can shunt it dwn resit the timer the time it needs start it and it will lite for a cycle then go out, short burn, then out. is it a senor???? JW
Posted on Jan 21, 2009
Kenmore-ultra fabric care gas dyer runs but no heat..gas is
It is most likely the thermal fuse watch this video your unit is made by whirlpool and these are very common to fail
Jun 20, 2011 | Kenmore 62602 Electric Dryer
Kenmore gas dyer, model 11170092991. Won't start. Control panels lights work. when "start" button is pressed nothing happens
If your dryer doesn't work or start please check the bellow link to troubleshoot your problem :-
Please get back to us if you have further query else please accept the suggestion.
Feb 02, 2011 | Kenmore Elite Oasis 7808 Gas Dryer
The dyer is working, but the dyer is not blowning any hot air
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
Dec 27, 2010 | Kenmore 600 7962 Dryer
I have a Kenmore gas dyer that has developed a burning smell
check vent line,either check outside to see if flapper is blowing open or disconnect vent line from back of dryer and see if it helps.if not there are two thermostats Number: 660036 Substitution: 279048 and
Number: 3387134 ,this one is on blower wheel housing and the other is in the back,take back wall off and you'll see it on right hand side on heater vent duct
Nov 03, 2009 | Kenmore Dryers
Gas dyer not heating up
Most of the gas dryers have everything accessible by simply releasing the spring clips atop the toe panel and getting it out the way.
Here are some repair pix with manual
Sep 05, 2009 | Kenmore 63942 Dryer
Dyer is not heating turns on and runs but it just does not heat up i took off hose and clean . also looked in back of dyer by taking off clover to look for fuse please help .
Kenmore dryers have what we call a thermo fuse, usually on top on the burner area - I would check continuity on this unit and replace if nesessary.
If the thermo fuse is okay and dryer heats up with gas, check your igniter and/or gas unit coils.
If dryer heats up with electric elements check continuity at both element ends and/or high limit thermostat.
Sep 01, 2009 | Kenmore Dryers
Kenmoore 80 series heavy duty (gas dyer) no heat.
If you still need help please post your model number. Gas/Electric?
May 25, 2009 | Kenmore 63942 Dryer
Kenmore Model 97310100
Are the coils getting voltage do you know? Or you can check the thermal fuse to see if its open.
Oct 23, 2008 | Kenmore 62602 Electric Dryer
Kenmore 62802 Electric Dryer Logo
123 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
