Question about Sony Ericsson P990i Smartphone
Not charging I'm having a hard time trying to recharge my P990i phone. Whenever I try to do so, the battery icon appears to be charging. But when I check the battery meter, it still doesn't get charged.
  • 2 more comments
  • Anonymous Jun 24, 2008
    mobile not charging because of using a duplicate charger once, but no damage inside the mobile, as the mobile is working properly when charged the battery seperately so please give a good solution as im far away from the service centers
  • khizr_ Aug 21, 2008
    I have the same freaking problem any other solution except for replacing the battery, FYI im using the original charger
  • marifil Apr 13, 2009
    My P990i phone does not charge. When I plug it to the charger, the battery icon appears to be charging. But when I pull it out after few hours,
    the battery meter, still doesn't get charged.
  • Anonymous Mar 23, 2014
    my phone refuses to recharge its as dead as a dodo was on 2%yesterday tried 2 different charges now trying through p.c. nothing.ty
Change the battery
Posted on Jun 12, 2008
My I pod stopped working
How old is the battery ipod batteries can only be recharged a certain ammount of times before they need replacing
If an iPod appears not to turn on, check the hold switch on the device.
If this switch is activated while the device is off, it will not power on again until the hold switch is turned off.
If that is determined not to be the problem, the battery's charge should be checked. When the battery is no longer holding a charge, the device will not power on, but will show a battery icon on the screen for a few seconds.
If you see this icon while trying to boot up the iPod, just connect it to the USB cable and allow the battery to charge, which can sometimes take up to 30 minutes before the iPod becomes operable again.
If no battery icon appears when trying to turn on the device, try resetting the iPod.
Once reset, the device should turn on, but if it does not, the battery may need to be drained first (by leaving the iPod disconnected from power for up to 24 hours), and the reset procedure tried again.
hope this helps
Aug 19, 2012 | Apple MA146LL/A 5th Gen Video iPod 30GB -...
P 990i auto charging
CLEAN UR CHARGING SOCKET FIRST
WITH I.P.
OR PETROL
THEN TRY IT
IDRISH 911
Oct 28, 2010 | Sony Ericsson P990i Cellular Phone
Battery icon has a lightening bolt in it. Just charging it for the first time.
when you are charging the set the icon that represents is the ligtening bolt. since you are charging for the first time. so so for 12-15 hours, then use it to drain completely and recharge. do this three times. The your battery will come back to optimum condition. It is good if you can do this once every week to discharge and recharge which will enhance your battery life. do not try to charge mid way all the time but try to schedule your charging cycle. Helpful? good day
Jul 11, 2010 | Philips SA1928 MP3 Player
I cant switch on my p990i phone.
Try power cycling the phone:
1. Remove the battery and leave it out for 5 to 10 minutes.
2. Put the battery back and turn the phone ON.
If you get the same problem, contact the manufacturer for possible firmware upgrade or repair.
Have a great day!
Jul 26, 2009 | Sony Ericsson P990i Smartphone
Battery charging problem
You can get a battery for the sony ericsson P990i mobile phone here - sony ericsson p990i battery
Dec 06, 2008 | Sony Ericsson P990i Cellular Phone
Battery not recharging
All batteries die sooner or later. I believe you have a dead cell.
1) Find another machine that uses the same battery and try it or
2) try another battery or
3) Give up and buy a new battery.
Good luck.
Apr 30, 2008 | Toshiba Satellite M35X-S111 Notebook
Deleting messsage
It sounds like the Msgs are on the memory card (not the SIM card) when you did a reset you should have taken the card out first.
Try reformatting the memory card!
Jan 29, 2008 | Sony Ericsson P990i Cellular Phone
Low battery icon on Midland LXT350 walkie-talkies
Your LXT350 is equipped for using an optional rechargeable NiMH battery pack which can be recharged by inserting the AC adapter into the radio charge jack, or with the optional desktop charger.
I would make sure the radio is off, then insert the charger. Charge only for the prescribed time (no more/no less) and remove from the charger.
Charge time is initially 24 hours. Charge time is about 12 hours thereafter. For maximum battery life, it is recommend charging the battery pack when the low battery icon comes on. Remove the radios from the charger when the charge time expires.
Jan 01, 2008 | Radio Communications
Sony Ericsson P990i Smartphone Logo
177 people viewed this question
Top Sony Ericsson Computers & Internet Experts
David Payne
David Payne
Andrew Taylor
Andrew Taylor
Are you a Sony Ericsson Computer and Internet Expert? Answer questions, earn points and help others
